8spd internal hub recommendation for ebike
Old 07-16-22, 07:58 PM
kracksmith
Quoted: 21 Post(s)
Liked 4 Times in 4 Posts
Presently my ebike has a 3spd mid drive so thinking to upgrade the rear wheel width along with 12ga spokes and might as well upgrade the 3spd to an 8spd. What is a durable 8spd internal hub to buy out there? I heard shimano SG-C6001-8D is the one to buy but of course it's discontinued and nobody has it for sale anymore new.
Are there any other reputable brands? I do understand I won't be changing gears when throttling to prevent internal damages.
kracksmith is offline
Old 07-16-22, 08:55 PM
2old
Quoted: 882 Post(s)
Liked 821 Times in 620 Posts
Shimano Alfine has a good rep. I'm not a fan of 12 gauge spokes, preferring 14 or butted instead.
2old is offline
Likes For 2old:
Old 07-17-22, 10:55 AM
kracksmith
Quoted: 21 Post(s)
I found a vendor in Japan to be able to get me a SG-C6001-8D. Yes the Shimano Alfine 11 Di2 is a nice choice too as the shifter is electronic. Both are said to work well with Ebikes under stress. The crème of the crop is Rohloff SPEEDHUB 500/14 but too much for me right now and maybe forever. Im curious as how well is a electronic shifter work over time with the alfine 11 di2 though. Both approximately the same price.
ok at 14 gauge spokes yes lighter and good enough.
Old 07-17-22, 03:24 PM
2old
Quoted: 882 Post(s)
Doesn't the Alfine still come in 8-sp?
2old is offline
Old 07-17-22, 03:36 PM
kracksmith
Quoted: 21 Post(s)
Yes 8spd too. I need to look into the electric shifter
Likes For kracksmith:
Old 07-19-22, 01:05 PM
Dewey101
Dewey101's Avatar
Bikes: '73 Raleigh Sports; 2017 Breezer Downtown 8 ST converted to ebike
Quoted: 35 Post(s)
Liked 20 Times in 19 Posts
How strong is your motor? I broke two Shimano Nexus 8 IGH hubs with my BBS01 motor (80nm) before switching to an Enviolo CVT this spring (see my blog post). Nexus Inter-8 & Alfine are rated to 48nm, Nexus Inter-5e is rated up to 70nm, beyond that you're better off with Enviolo Heavy Duty Cargo (100nm).
Dewey101 is offline
Likes For Dewey101:
Old 07-19-22, 01:40 PM
kracksmith
Quoted: 21 Post(s)
My motor is a CYC X1 pro Gen2 which is rated at 3000watts, but my battery setup is 52v 8ah 60A continuous which most likely doesn't use the 3000watts motor to it's fullest. Presently I got a SHIMANO Nexus SG-3D55 3-Speed Internally Geared on the bike. Everything has been running fine and I don't abuse it such as doing wheeies, or change gears while racing it. However I do speed test and race other ebikers but i change gearing when not throttling.
Reason I prefer a 8spd is to gain more top end than my current 3spd. My 3spd on 3rd gear tops out at only 41mph. I'll be satisfy to hit 50mph+.
Would you know how you may have broke your Nexus 8 IGH hub? I will surely consider a hub that can do 100nm if needed.
Old 07-20-22, 09:48 AM
2old
Quoted: 882 Post(s)
With that much power, do you need gears? A White Industries SS cog probably would suffice.
2old is offline
Old 07-24-22, 10:43 AM
kracksmith
Quoted: 21 Post(s)
yes lots of torque, and yes need to upgrade as I go. so far so good though.
Old 07-24-22, 03:11 PM
CVT
Bikes: Old school Specialized Stumpjumper, Vilano Blackjack, Burley Road Bike
Quoted: 8 Post(s)
Liked 11 Times in 9 Posts
There is a limit set by the hub manufacturer regarding the ebike motor watts as well as the spoke gauge, get those specs first before deciding which hub to buy.
CVT is offline
