Shimano 600EX crankset - 52/42 replacement
My JH Wilson steel frame currently has a 52/42 on the front and 11/32 on the rear. I live in the Peak District so some of the hill climbs are a real challenge with the current setup. Does anyone know of a replacement that might make it a bit easier? A 50/34 or 52/36 etc?
I'm after an older looking solution as the bike is from the 70s/80s.
Thanks
Thanks
Quoted: 790 Post(s)
Liked 1,761 Times
While a finding one may be a bit more pricey than a more modern looking crank set the Sugino Maxy's took 110 bcd rings allowing for a 34 small ring and are a close match cosmetically to the 600ex.
The main things you should be looking for is a crank set with 110bcd which would allow you to run a smaller modern inner ring and iso/jis spindle tapper.
Quoted: 790 Post(s)
Liked 1,761 Times
For more gearing while staying cosmetically and vintage correct you could also change to Suntour V-GT long cage rear derailleur and a wider range modern 6 or 7 speed freewheel. Which would alloy you to bic up about 30 percent more gearing while keeping the nice crank and most of the 600eu stuff. Id did this on a old Jeunet to get 34/30 low gear.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Thanks
Thanks
I've found that going small on the chainrings doesn't necessarily provoke comments from people unless I deliberately draw attention to them. Being able to keep up with the faster riders in the group speaks for itself.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
I've "built" several compact cranks, using a Sugino double with 110 spacing, and then "borrowing" the two largest rings from a MTB triple. Visit a few co ops and you will likely find some good candidates.
Please don't confuse ebay "asking" prices with "selling" prices. Many sellers never get their ask price. some are far from it. Value is determined once an item actually SELLS. Its easy enough to check SOLD prices.
Quoted: 790 Post(s)
Liked 1,761 Times
+1 while this thread is getting a bit off track using vintage MTB cranks I have built gearing as low as 38/26 front 32/13 rear for short range cargo bikes.
