Classic Rims, Maybe Even Vintage Rims
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 760 Post(s)
Liked 1,562 Times
Okay, thanks for the price checks. At the prices I quoted the rims and spokes plus tax and shipping have been $300 just for the parts and I'd still have to build the wheels.
Velo Orange has rim and wheel options, as do many other shops. The VO wheels look to be relatively heavy rims with straight gage spokes and the wrong spacing, so not a good fit for my needs.
So, if I bought an assembled wheel with 126 mm spacing, Can I simply remove a spacer to fit the hub into a 120 mm frame? There is also re-dishing required, correct?
The hunt is on!
The hunt is on!
It's pretty simple to cold-set a frame from 120 to 126 (the Sheldon 2x4 method or the threaded rod method.....)- if you stick with 5sp after that you may need a spacer behind the freewheel to keep your chainline, or you could then go to a 6 or 7sp freewheel...
I think you're about right with the pricing- I've built a couple sets of wheels from new parts over the past year (V-O rims & hubs, Sapim spokes), and shopping around and waiting for sales (V-O seem to have a 20% or 25% off sale a couple times a year....) they've come out to about $300 a set. In terms of parts quality, if you DIY you'll get a much nicer wheel for the $ than spending an equal amount on a pre-built set. Build quality will of course be up to you!
I've found building wheels to be kind of fun. The Roger Musson book is a great resource, and if you're reasonably handy the truing DIY truing stand design is easy to make, too....
Quoted: 1557 Post(s)
Liked 1,732 Times
If you want new wheels built to vintage specifications (aka "obsolete"), you'll have to find a vintage friendly bike shop.
In Southern California (Long Beach) I recommend: https://www.thebicyclestand.org
Likes For icemilkcoffee:
Quoted: 2362 Post(s)
Liked 1,746 Times
Correct, you'd have to re-center the rim across the locknuts, and also cut 6mm from one end of the axle, unless it's a solid/nutted axle.
I think it'd depend on the hub whether you could just remove the spacer(s), and yes, with a 6mm difference you'd have to re-dish.
I have everything I need to build wheels - truing stand with a dial micrometer, dishing gage,... I even have a spoke wrench.
Quoted: 702 Post(s)
Liked 671 Times
Do you have a spoke tensiometer?
Quoted: 702 Post(s)
Liked 671 Times
I should have said, straighten the spokes, not flatten them.
You need a flat surface, I use my cast iron table saw but a stone countertop or heavy piece of glass works as well. If the rim does not lie flat, you have to find the high spots and bend them down until the rim does not wobble when pushed with your finger at any given point.
You want to start with straight spokes as well as "true" (flat and round) rims before lacing them because if you rely on the spokes to pull the rim true, you will never achieve uniform tension for the spokes, which is key to having a durable wheel.
Quoted: 1946 Post(s)
Liked 2,004 Times
You have everything you need but spokes and rims. Regularly check the local CL, OfferUp, FB market, etc for 6 speed wheel sets. If the eyelets aren’t too rusty, the brake tracks look “good”, and they are pretty true, you have found your rims. A few days of liquid wrench at the spoke-nipple interface and you might be able to use the spokes.
Bikes: 2017 Sage Skyline, 2015 Co-Motion Periscope Tandem, 2012 Soma Smoothie, 2006 Kona Jake, 1986 Miyata Nine Twelve, 1977 Peugeot UO18c, 1977 Peugeot PRN10, 1974 Allegro Schweitzermeister Model 76, 1972 Hugo Rickert Spezial
Quoted: 114 Post(s)
Liked 585 Times
Su M13 polished from Carson City Bike Shop
A number of people have mentioned this rim and I concur. They sell them in polish and satin and you can get them in 700c and 27 and 32 or 36 spokes My go to place is Carson City Bike Shop at their online store. About $30 a rim. Their interface is very unwieldy but the price is great and shipping is reasonable in USA.
https://carsoncitybikeshop.com/compo...riceasc&page=4
Quoted: 114 Post(s)
Liked 585 Times
Here they are on my Allegro and PX10
Likes For Sactown_Albert:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3869 Post(s)
Liked 6,460 Times
I wouldn't want to do that based on the spoke length differences between the two o.l.d.s, especially after shelling out for a new wheel. When I buy something new, I want it to be correct, right out of the gate.
Likes For SurferRosa:
Quoted: 760 Post(s)
Liked 1,562 Times
Quoted: 760 Post(s)
Liked 1,562 Times
Likes For Bad Lag:
Oh, man! Those are real beauties.
Bikes: 1980 Gitane sprint,1977 Motobécane C4, 1977 Carlton Clubman, 1959 Claud Butler European
Quoted: 69 Post(s)
Liked 122 Times
[QUOTE=Bad Lag;22601269]Who makes them, new production, 700C, clincher rims in the classic style - polished aluminum, ferruled spoke holes,
You know, I have the same problem. I just can’t find the “look” I want in new rims. For my own bikes I always end up buying from eBay second hand vintage rims, and that comes with a risk of getting a piece of err, rubbish.
It’s heartening to know I am not the only one and missing something every one else knows….lol.
