Raleigh "R" Cotter Pin Nut - where can I find them?
Bikes: 2008 Gary Fisher Monona, 1997 Univega Alpina 550, 1980 Nishiki International, 1993 Specialized Epic
I'm restoring a 1974 Lady Sports for my wife and I have everything I need..... EXCEPT when I went to douse the cotter pins on the crank arms with penetrating oil in preperation for removing them this weekend I found that I was missing the Raleigh R nut on one of the pins. I have looked online and can't find them anywhere, and I understand they are a 26tpi thread that is pretty much impossible to find.
Has anyone had any luck finding these anywhere? I would like to keep as much original as possible, but if I have to order new cotter pins that is not the end of the world.....
Thanks!
Thanks!
incazzare.
If you have to order new pins, I get them here: https://bikesmithdesign.com/CotterPress/cotters.html
Hope you can find a matching one, though.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Friendship is Magic
Bikes: old ones
Quoted: 26418 Post(s)
Liked 10,380 Times
Thanks!
Thanks!
where I work a shift as mechanic tomorrow.
I'll check and let you know what I find, but
honestly speaking, I'm not doing you any favors
enabling your OCD.
Likes For 3alarmer:
Half way there
Bikes: 69 Hercules, 73 Raleigh Sports, 74 Raliegh Competition, 78 Nishiki Professional, 79 Nishiki International, 83 Colnago Super, 83 Viner Junior
26 tpi cotters can be bought here: https://harmonywaterrestoration.com/cotterPin_pg.html
-G
Ha! I find that the older I get the more OCD I get! I appreciate you checking and enabling my OCD!!!!
Wow, 35 bucks for a set of cotters and nuts - crazy. I understand the desire to keep things original; however it is not uncommon for Sports to have replacement cotters with generic nuts so you would not be that far from original. I think that I may have a couple of R-nuts that I may be tempted to trade for other Sports stuff.
-G
-G
incazzare.
Eh, whatever. That's like those gun nuts who flip anytime someone calls a magazine a "clip." Yes, it's not the right term. No, it doesn't really matter.
Stupid stupid stupid frickin cotters!!!!!!!!!!!
Well I have spent the ENTIRE day hammering, drilling, torching, cussing, hammering some more, drilled some more, torched some more. Sawed, broken 4 bits, dulled 5 bits, gone through who knows how much cutting oil, and the STUPID COTTER IS STILL FROZEN SOLID!!!
The first cotter almost fell out with the lightest tap and I thought "this will be easy" - BOY was I wrong! The other one is frozen hard and I am starting to think I will never get it out. Finally gave up for the day and am going to buy some new high-speed drill bits tomorrow to try again.
So based on the results of today I won't need that R nut anymore, as the frozen cotter is basically destroyed.
Bikes: 1983 Peugeot UO14, KHS Green-Heavily modified, 1972 Raleigh Sprite 27" (work in progress)
That's why the BikeSmith cotter press is worth its weight in gold. Be sure to order one with the new cotters and save yourself endless grief.
Half way there
Welcome to the club. I have found that my bench vise is the most effective tool. Find a socket that fits over the head of the cotter (away from the threaded part). Do what you can to arrange to clamp cotter and socket in the jaws and then tighten. Here's a video: https://www.youtube.com/watch?v=mybfNsm1XwM
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
I checked and found nothing, but it looks like it matters not.
There are a number of tricks to dealing with cotters, the most
essential one being not to hammer them. But you know that now.
They can be pressed in and out with a purpose built tool,
like that Bikesmith one, or with a bench vise or even a smal
drill press vise, using the appropriately sized socket to provide
a negative space for the head end to slide into as it breaks free.
Liberal use of Kroil or PB Blaster also usually helps.
Once you've started drilling, it's usually easiest to drill
out the whole end until you're just below the crank arm
lip, then use a drift of the appropriate size to punch it
out.........at least that usually works for me.
Vincit omnia veritas.
Quoted: 100 Post(s)
Liked 57 Times
If you don't want to pay up for the original "R" nuts, you can sometimes buy reproduction "R" decals from a guy on UK eBay, stick them on nuts of your choice, and cover them with clear urethane. It was a while ago when I did that; can't seem to find the seller, now. But in any case, it looks pretty good.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I have some R nuts for cotters. Who wants 'em? I'd rather have useable cotters....
FINALLY the blasted thing is out! Took a LOT of drilling and once we got all the way through had to go back in with a little bit bigger drill bit, then hit it with the torch and the punch finally drove it out. That was one tough little bugger!!
I will either invest in a press or look into making my own with my bench vise, but as of right now I don't plan on picking up any more bikes to fix up that have cottered cranks, but time will tell I guess!!
Thanks for all the help and suggestions.
incazzare.
Quoted: 790 Post(s)
Liked 1,761 Times
Likes For larwyn:
Bikes: Trek 600 ,1980Raleigh Competition G.S., 1986 Schwinn Passage, Facet Biotour 2000, Falcon San Remo 531,Schwinn Sierra, Sun Seeker tricycle recumbent,1985 Bianchi Squadra
Quoted: 33 Post(s)
Liked 12 Times
Wow ! I'm glad I casually glanced at this thread . Never dealt much with cotters before now , but I picked up an early 70's Raleigh Grand Prix at a metals recycler yesterday . Now I have an idea as to how to get the cotters out . I do have an old drill press mech I'll customize for this .
Bikes: Fuji fixed gear conversion.
I've got a set of "R" nuts I can let go for $15 shipped if anyone is interested. Lubed and abused my cotters getting them out so I'll be replacing w/ bikesmithdesigns cotters (Can't use R nuts). Lesson learned; do research before using a hammer on a late 60's bike.
