Evolution of the Humble Steering Tube Plug
If I understand you correctly, you have filled the entire internal volume at the top of your steerer down to the bottom of the stem clamp with epoxy and embedded a star nut (with its OD ground down) at the bottom of this epoxy cylinder, which is supported by a rubber plug. Do you then drill a hole through the axis of this epoxy cylinder so that you can thread a top cover bolt through the embedded star nut? How to set preload?
Preload is no different than an expanding plug. The top cap can't bottom out on the epoxy. I've had to use a countersink bit to add a bit of clearance.
Likes For DaveSSS:
Quoted: 4396 Post(s)
Liked 1,555 Times
It is worth noting that no matter what sort of glue-in system you use (including the factory Cervelo alloy tubes), that you MUST let the epoxy cure with the stem loose. The clamping force does shrink the inner and outer diameter of the steerer tube, and when you loosen the stem bolts the steerer will expand and break the bond.
I experienced this with my first homemade plug and then saw it later when I started working in a Cervelo shop.
If you are doing the DaveSSS method, another approach is to use a long bolt with cap, grease the threads and screw it into the trimmed down starnut. Put the foam in the steerer, pour some epoxy, then insert the starnut assembly and pour the rest of the epoxy around the bolt with the cap held high. When you're you're several MM from the top, stop pouring an lower the also greased cap to the steerer to keep the bolt centered. When cured, the greased bolt is simply unscrewed from the starnut and the epoxy that formed threads around it. The threads in the epoxy aren't strong, but they don't need to be. The starnut will to do the work. You could add sawdust, chopped carbon, cotton or the like to the last epoxy poured if you want to decrease the weight.
Remember to sand and degrease the inside of the steerer to start.
It's easiest to do the epoxy plug during the initial build, before integrated bars and brake hoses are all in, but I just did it with the stem on, but of course loosened up. I masked off the stem, but its still hard to keep JB Weld epoxy off the top of the steering tube and the 1mm of exposed stem ID. I like to mask off the bolt so it drops right in, down to the star nut. For a 40mm depth, I mix about 35 grams of epoxy and don't use it all.
The bike also needs to be propped up so the steered is plumb.
Likes For DaveSSS:
pan y agua
Quoted: 1447 Post(s)
Liked 724 Times
You can always go with one of these: https://www.fairwheelbikes.com/extra...nder-plug.html
You could get lost and die.
You could hit a tree and die.
pan y agua
Liked 724 Times
I’ve had mixed expereince with this. My mtb has the expander and top bolt completely removed, to facilitate the di2 wiring. That headset has never come loose.
We had a co-motion however that used an expoxied in sleeve in the steerer tube. That headset would never stay tight. Turned out the glue had failed, re glued and the headset stayed tight. So on that bike at least the top bolt was helping to keep the right load on the headset.
Liked 1,555 Times
We had a co-motion however that used an epoxied in sleeve in the steerer tube. That headset would never stay tight. Turned out the glue had failed, re glued and the headset stayed tight. So on that bike at least the top bolt was helping to keep the right load on the headset.
Likes For retswerb:
That's my picture. I used a countersink bit to add clearance for the top cap. This one probably used core foam to plug the steering tube and a 6mm thread insert that's normally used to add threads to wood, rather than a star nut. It's more difficult to get centered.
Likes For DaveSSS:
climber has-been
Quoted: 3427 Post(s)
Liked 3,564 Times
To each his own, but that seems to be a rather elaborate and labor intensive solution to provide something as simple as bearing preload.
Likes For terrymorse:
Quoted: 3949 Post(s)
Liked 7,295 Times
Likes For tomato coupe:
There are people who have cracked the top of a steering tube, hence the suggestion to use a 5mm spacer and extend the steerer 2-3mm above the stem. There are also those who worry about over tightening the expanding plug, or leaving it too loose and slipping. The newest plugs sit on top of the steerer and force the use of a spacer on top. I like no spacer above the stem. This solves all of those problems. It might take 30 minutes to do, but I find it worthwhile. To each his own.
Liked 1,555 Times
Liked 7,295 Times
A bog-standard Wolf Tooth compression plug costs $15 and weighs 26 g. A plug of epoxy with the same dimensions weighs about 16 g, not including a threaded insert or star nut. Not much of a weight or cost savings, if any ...
I don't do this to save weight. I've used this same technique to extend the length of a steering tube by 10-15mm. 20mm would be stretching it. All you do is use a no-stop copper tube coupling, for 1 inch pipe that has an ID of 1-1/8. Lightly grease the ID of the coupling, slide it over the steering tube and tape it so it doesn't slide down. Fill with JB Weld epoxy and allow to cure.
I did this only once on a LOOK KG461. I rode it many thousands of miles with no problems.
Now you have fuel for more whining.
Liked 7,295 Times
Liked 1,555 Times
10 grams seems like a very small number, but that's 10 grams for free. Compare that to most of the things people put on their bikes to save weight or decrease drag and it seem like a no-brainer.
No one is suggesting everyone should glue in their plug. But no one has really made an argument for not gluing it in.
Liked 7,295 Times
Liked 1,555 Times
Do it, don't do it, whatever. If my headset works loose, I like knowing that I don't have guess whether the expansion plug slipped. (But it never gets loose.)
Reasons to do it:
1. Can't be over or under tightened.
2. Won't slip.
3. No 5mm spacer above stem needed.
This has all been stated before. Short memory?
2. Won't slip.
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
I can think of a few confounding factors like maybe the presence of anti-seize on the threads acting like a lubricant or maybe a questionable torque wrench or limited duty cycles, or whatever...I think the lesson here is steer tubes are thin & extra support to keep inside/outside forces balanced on the steer tube is hardly a bad idea.
I have another one that came with another headset. I don't have any plans to use it on a unsleeved carbon steerer any time soon. The bulge in the steer tube from a 5mm tall plug, to me, says that there is too much force in too small of an area. A taller plug would have the same grip at a lower pressure over a larger area. Had I not hade a component failure following instructions & using proper tools & witnessed such obvious structural stress to the steer tube, maybe I'd have more confidence.
Liked 7,295 Times
1 and 2 aren’t really an issue for compression plugs (assuming you have some minimal mechanical aptitude), so it seems you’re mainly motivated to get rid of that 5mm spacer. What is the advantage of eliminating the spacer?
Liked 1,555 Times
2. The stack limitations imposed by a previously cut steerer.
Liked 7,295 Times
You can't argue with aesthetics, if that's the motivation. But, the limitations from a pre-cut steerer tube are kind of throwing spaghetti at the wall. The 5mm spacer is only needed to accommodate 3mm of steerer tube that extends above the stem. With an epoxy plug, you could make the steerer tube flush with the top of the stem, and you'd gain 3mm of stack. That's a difference very few people would even notice, and it's a very low probability scenario.
climber has-been
Liked 3,564 Times
I have an aversion to anything that can't be unbolted, removed, and replaced. Stuff happens.
You can see that bulging of the steering tube with the more substantial compression plugs, too. Although it may seem that steering tubes are rigid, they are flexible. Everything flexes under load.
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Oh FFS, how much does an expander plug weigh?
Yeah, everybody is looking at my extra spacer.
Stack limitations are made for specific steerers regardless. The fork on the bike I'm currently building says no more than 35mm of spacers under the stem. So you're saying I can have more spacers under my stem with your method? I certainly wouldn't mind being higher up, but have to question the safety.
