What tool to use for cutting cable housings?
Time Traveler
Bikes: 1983 Ross Paragon
Quoted: 204 Post(s)
Liked 98 Times
I am in the process of restoring / customizing my new to me 72 Schwinn Continental and I want to install new cables and housings. I do not want to buy a kit of pre cut cables, i want to cut them to fit, look great and work perfect. What tool is best to cut the different kinds of cable housings that will cut them without kinking or crimping them. Is there a tool like a pipe cutter that moves around the cable and cuts it perfectly round? Also Im looking for chrome ferrules to go over the ends of the housings. Can someone advise me please? So far all I know about these cable housings is that there are two kinds, the coil kind and the linear wire kind. Thanks.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
The Park CN-10 is kind of the standard, but I like my Jagwire Pro just fine.
Likes For Rolla:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1944 Post(s)
Liked 1,466 Times
Park Tool CN-10. I would have bought the well-reviewed Pedro analog to save a few dollars, but it was out of stock when my RD cable snapped.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Diagonal cutters for cables and brake housing. Housing cutters for shift housing only.
From top down:
Small flush cut dikes for zip ties
SRAM shift housing cutters
Knipex diagonal cutters (cables/brake housing)
From top down:
Likes For cxwrench:
Expired Member
Quoted: 3667 Post(s)
Liked 5,420 Times
You can also use a Dremel with cutting wheel for housing. You may have to punch out the melted stuff with something pointy.
Quoted: 1088 Post(s)
Liked 1,024 Times
Park is good, but I like this one better
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
About the same price as park but a slightly better gap between the handles so when you have a tough section of compressionless brake housing or der housing and you squeeze real hard the skin of your hands doesn't get pinched in the handle. I've only done it a couple times with park, pedros in my experience sucks for this and so do other cheap knock-offs. Except to clipping zipties, a cable cutter (really wire rope cutter) is all you need for cutting any cable or housing cleanly and will last decades in a home environment.
Liked 1,466 Times
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,217 Times
The ferrules don’t really need crimping at all. I don’t know of any tool for crimping the ferrules.
Stuart Black
Stuart Black
Likes For Jeff Neese:
Guest
Liked 3,270 Times
Quoted: 1943 Post(s)
Liked 2,164 Times
I have all the time in the world. Dewalt side cutters, a bench grinder to square things up, sometimes a fine flat file for a potential burr, an assortment of lapel pins, scribes, stick pins, etc. to open up the end on the liner.
A cheap wire crimp tool for the end caps.
Has worked without issues for a long time.
John
John
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Felco C7
Likes For dedhed:
Likes For Crankycrank:
Time Traveler
Quoted: 204 Post(s)
Liked 98 Times
wow! That was fascinating. Im gonna try that! I went with the Park Tool CN-10. Thank you everybody for your input! Now I need to figure out where to get some old style huret shifter cables and the right size housing. I think it takes 4mm. I heard Jagwire makes some cables with those ends and a 4mm housing but not sure where to get just a few cables. I think the cable is 1.2mm. Also need the ferules for the housing ends but not the cable end caps because Im going to use the twist welding method.
Quoted: 1083 Post(s)
Liked 686 Times
+1. And twist welding to keep cable ends from fraying. You could even get away without cable cutters as Twist Welding does the cutting but the cutters are nice to have. Twist Welding Cable (How To) - YouTube
The problem with tools like the Park CN-10 is when used on brake cable housing is they crush the spiral wound metal housing.
They work fine on shift cable housing. I have the Pedro's version.
Dremel with a cut off wheel avoids this. I have also used a hacksaw with some success.
Likes For jnbrown:
Quoted: 6193 Post(s)
Liked 4,808 Times
You can cut your cable housings with all kinds of stuff. However the important thing, even if you use the best cable cutters money can buy is to look at the end of the housing you just cut and round it back up if needed.
A very small punch or awl with slowly tapered sides works great for me.
Quoted: 2026 Post(s)
Liked 1,096 Times
I cut shift housing and all inner wires with my Shimano TL-CT12 but Park's or Pedros' work just fine. Felcos are the top choice if cost is not a consideration. I cut spiral wound brake housing with a sharp pair of side cutters, working one blade between the coils and finishing with a flat file to smooth the cut. Housing ferrules are not crimped and inner wire caps are crimped with the Shimano's crimper. A thin nail or sharpened spoke is useful to round out cut housing and its lining.
Quoted: 836 Post(s)
Liked 1,061 Times
Yes, it's extra time and not worth it to everyone but the advantage is that if you need to remove the cable and re-install it for whatever reason the strands won't unravel and no cable end needs to be removed and replaced.
Bikes: lots
Liked 2,932 Times
Damn you folks tend to overthink pretty much everything. 'Twistwelding'? Please. Dremel? Overkill.
Clark W. Griswold
Quoted: 4350 Post(s)
Liked 3,989 Times
Knipex or Felco is the way to go but honestly my Jagwire cutters work well (which are the same as cxwrench 's SRAM cutters but without the SRAM logos)
Quoted: 5224 Post(s)
Liked 3,581 Times
same thing I use on cables: entrapping blade, compound grip cable cutter. think there are better ways tho that do less damage to the cut ends. I think I've had to trim a bit, with side cutting pliers, or reshape the cut end to round w/ regular pliers. it's been a while. maybe it's more about placement & technique? I see below ppl suggesting spare cable in the housing to maintain the shape. I'll try that!
this is mine
MIDWEST P6300 Cable Cutter
this is mine
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
I have a Park CN-10 but you can't beat the sparks shower from using a Dremel cutoff wheel. Not for use by folks who use gasoline for cleaning parts.
