New GP5000 S TR coming soon
Old 10-15-21, 11:54 AM
  #51
burnthesheep
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times in 974 Posts
Lots of this has to do with keeping the tire sizes aero matched to the wheels they'd be run on. Folks running this tire aren't exactly 100kg dudes trying to make the front group of the B-group weeknight hammer ride. It's folks racing or in time trial or triathlons.
If the CRR and aero does appear to pan out, I'll go TL on my front HED 9+ TT wheel with and buy a newer rear HED disc that I can run tubeless. The disc I have now they claim cannot run tubeless for some reason.
Not sure why the HED Belgium in older 23mm width cannot do it but newer in 25mm can. That's the spoked wheel under the skin of a HED disc. I couldn't get an answer as to "why" from them the 23mm cannot do it.
burnthesheep is offline
Old 10-15-21, 01:20 PM
  #52
smashndash
Quoted: 850 Post(s)
Liked 344 Times in 247 Posts
Originally Posted by Sy Reene
It could also mean you might just fit the next sized up tire and negate these differences. But indeed curious. In fact the new TR shows an inflated height measurement of only 22mm -- not sure if this is maybe the lowest profile '25mm' tire I've seen in his testing? I guess the size is part of the contributing reason for lower weight. Puncture resistance is down, but importance of this is lesser I suppose if you're running sealant and not a tube.
Well, it wouldn't "negate" the differences. The BRR test favors larger tires because larger tires are firmer at the same pressure. So in this matchup, the old GP5000 has an unfair advantage because it's a larger tire being pumped up to the same pressure as a smaller tire. If you compared a 28mm GP5k S to a 25mm GP5k, the 28 would certainly be faster at the same pressure. I think the 5k is actually a watt faster when you control for pressure, size etc.
This is all in the context of steel drum tests. I think steel drums do a great job of illustrating the *minimum* amount of power loss from a tire. I believe real world tests have shown that the power loss is greater than steel drums show and that more supple tires tend to have a disproportionate advantage on rougher roads relative to how they do on steel drums. I'd still go with a corsa speed for a TT.​​​​​
Uh... not sure where you're drawing that conclusion from. Every fred on the road is gonna be using these tires for their weekend rides. I'm actually very confused as to why Continental is marketing this tire as acceptable for every imaginable road use from daily casual rides to the literal TT world championships. I simply refuse to believe it's possible to create a tire that is optimal for all of those scenarios. Someone is getting screwed somewhere.
Hell, I know a guy who uses the old 32mm (34mm actual - huge) GP5k for gravel. It's preposterous.
smashndash is offline
Likes For smashndash:
Old 10-15-21, 01:46 PM
  #53
HTupolev
Quoted: 1974 Post(s)
Liked 1,298 Times in 630 Posts
That's news to me.
HTupolev is online now
Likes For HTupolev:
Old 10-15-21, 02:11 PM
  #54
scottfsmith
I like bike
scottfsmith's Avatar
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times in 191 Posts
Originally Posted by msu2001la
Has anyone seen these for sale anywhere yet?
I was at a local shop yesterday and they hadn't gotten any yet and had no idea when they would. I don't see them available anywhere online.
Some of the German online places have them. I was thinking about buying some but decided to wait, my current tires have plenty of miles left.
https://www.bike-discount.de/en/buy/...702/wg_id-8922
scottfsmith is offline
Old 10-16-21, 10:27 AM
  #55
burnthesheep
Newbie racer
Originally Posted by HTupolev
That's news to me.
I guess I confused "used by" and "designed for". Lol.
I concede you are likely correct, anyone with a wallet and need for speed might be onto it.
Old 10-16-21, 01:31 PM
  #56
Branko D
Quoted: 338 Post(s)
Liked 408 Times in 252 Posts
Originally Posted by smashndash
https://www.bicyclerollingresistance...prix-5000-s-tr
Interesting. BRR measured the same-ish rolling resistance for a given pressure, but the tire has also gotten ~1.5mm smaller, which means you'd have to run it at a slightly higher pressure. So the tire is probably slightly faster. Maybe like 1 watt.
Jarno also mentions that the casing is stiffer. afaik the old gp5k wasn't exactly known to be supple (relative to other race tires) so this might not be great news.
Mind you, BRR got somewhat better results for the old GP5000 TL compared to aerocoach rolling resistance tests (which showed also old GP5000 is great, but not that close to the best of the TT specific tires), so there's that and the now smaller size.
The new 25mm GP5000s should fit on my rims better aerodynamically which is welcome news indeed. Got a lot of mileage left on current ones so no hurry to toss them.
Branko D is offline
Old 10-16-21, 01:37 PM
  #57
GhostRider62
Quoted: 2333 Post(s)
Liked 2,097 Times in 1,314 Posts
100Kg dude here.....the B group riders love my rear wheel.....shod with 25 mm GP5000
GhostRider62 is offline
Likes For GhostRider62:
Old 10-19-21, 09:20 AM
  #58
Branko D
Quoted: 338 Post(s)
Aerocoach just published their findings that new GP5000 roll 1.2W better per pair at 45 km/hr. So, really not much in it, but better.
I like they're slightly narrower and lighter, too.
Branko D is offline
Old 10-23-21, 02:37 AM
  #59
GhostRider62
I have a set of 25 mm GP 5000 S tubeless on their way, going to try tubeless once again after a miserable 2016 on them. Should have them early next week.
Old 10-23-21, 07:33 AM
  #60
robbyville
robbyville's Avatar
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times in 156 Posts
hope you enjoy them! I’m on my second or third GP5000 TL. Definitely one of the harder tires to install on my brand of wheels (I actually have to use a lever), but seats even with a hand pump and I’ve really liked the performances. Definitely one of my faves.
have fun and ride safe!
robbyville is offline
Old 10-24-21, 07:34 AM
  #61
itchyjoe
Bikes: S Works Aethos/Spec Roubaix/S Works Tarmac
Quoted: 13 Post(s)
I plan to get a set of these for next season. Will 25 mm work on my rims which measure 29/22 or would a 28 mm tire be safer? Thanks!
itchyjoe is offline
Old 10-25-21, 12:59 AM
  #62
smashndash
Quoted: 850 Post(s)
I would go with the 28. I have a 25mm corsa control on my 23i rim and that tire has a carcass width of 70mm. The GP5k S has a 64mm carcass.
Too small of a tire = more sidewall cuts, more exposed rims to gravel, and potentially compromised handling. These tires are just not designed for such wide rims.
Also, there is almost no change in tire height with wider rims. Which means that the effective height of the "spring" (tire) is almost the same regardless of rim width. So going with a narrow tire on a wider rim is not going to give you the same cushion as a wide tire.
That being said, I highly doubt you're at any risk of a blowout purely due to the rim width. If all you care about is aero, go for the 25.
Old 10-25-21, 04:56 AM
  #63
itchyjoe
Quoted: 13 Post(s)
I appreciate your very thorough response! I have seen a couple of charts generally showing 25 mm tires are marginal on 22i rims..so 28 does look to be a better choice.
itchyjoe is offline
