Fuji Touring (2015 model)
contiuniously variable
Likes For TransitBiker:
It was one of the ones that I was considering when I purchased my Kona Sutra: the others were a Brodie Elan and the Cinelli Bootleg Hobo. The Hobo was my favourite but I got a great deal on the Kona and I couldn't find a dealer (in Toronto, in 2013) that had a Hobo.
Quoted: 5888 Post(s)
Liked 3,471 Times
For the price on a new touring bike, it's hard to beat, period.
That said, I picked up a 2009 fuji touring second hand recently. I was not overly impressed with the quality of the parts on the bike but the parts on the '015 model are frankly better (real shimano hubs and not some junky fuji knockoff and a much better choice in a crank).
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
I thought you "were sooo done with rim brakes!". This isn't a bike that could be easily converted to discs. The rear disc is just plain out. I suppose that you could have someone add disc tabs to the rear but that isn't going to be cheap. It may not even be possible. The tubes on the nondrive side may not be strong enough to withstand the braking force.
You could put discs on the front but that's still going to be expensive. You'd need a new fork, a new wheel and a disc caliper. All in you'd be looking at $150 to $250 depending on the quality of the parts. If you don't install the parts yourself, you are looking at another $150 to $200 for labor. That's adding a lot to the cost of the bike and getting it pretty close to the price of a LHT Disc Trucker.
Bottom line: It's a good bike as it sits. It's not necessarily a good bike for you if you start fiddling with it.
Stuart Black
Stuart Black
I don't think that I like to ride home with a new bike wishing that I had something else.
Bikes: 1997 Kona Hahana Race Light, 2010 Surly LHT(deceased), 1999 Rocky Mountain Turbo
Quoted: 86 Post(s)
The bike is nice enough and sits right in the touring category.
But my first thought was, "There are no disc brakes."
FWIW, the BikesDirect "Windsor Tourist" is generally acknowledged to be a knockoff of the Fuji Touring. Depending on which sub-model you get and the particular component selection, it can be a better deal.
Disclaimer: Bought the Windsor for my teen a couple of years ago. Very, very good value.
Knows the weight of my bike to the nearest 10 pounds.
Sunshine
Quoted: 10957 Post(s)
Liked 7,487 Times
The Windsor Tourist is very differently specs though. The Windsor comes with Sora/Tiagra STI and a crank with a 30t small ring. It's also has some no name hubs.
The Fuji has Deore hubs and crank with a 26t small ring, and also has bar ends for shifting.
Pretty different specs.
Sunshine
Liked 7,487 Times
The 16 Fuji Touring is a really solid entry level tourer. I could see it bei g great for commuter duty too.
It's an okay bike that's a pretty good value. Nothing too special but not too many warts either. However...
As dead set that you were to switch to disc brakes this should be a deal breaker for you. This isn't like buying a bike with tires that you don't like or a saddle that doesn't work for you. This is something that you will have to live with. Are you ready to invest in a bike that is missing one of the major features that you were looking for.
- Andy
Quoted: 86 Post(s)
Who are we critiquing it for? There is a usual assumption when one posts a new bike with a call for opinions that the bike is for you.
It may have been better to ask, "So I'm looking at a bike for____, opinions?"
It looks like a great entry level bike. A solid frame and good components. I've personally found bar ends not practical for my riding style, how does this person ride? I do think discs are the way to go these days. That being said rim brakes are more than adequate and not going anywhere.
In general it's a solid bike and would be more than sufficient to most people wanting to get into commuting and touring and weekend rides without a large financial burden.
Liked 4,218 Times
And you got them. It's a fairly good touring bike of good value for someone who isn't adamantly against rim brakes. It's not a bike that is worth trying to retrofit for disc brakes.
Stuart Black
Stuart Black
I am sure i didn't use the brakes properly on my breezer. It isn't meant to speed down trails in a park like my cruiser could, my cruiser had a beefy coaster brake. I did that for the first 3 months and nearly ruined the rims. Next thing i will need is a new set of both rims and spokes.... IF i cannot afford that, i'll be SOL.
- Andy
Bikes: Breezer Uptown 8, Jamis Renegade Expert
- Andy
Liked 4,218 Times
- Andy
- Andy
I suspect that you are dragging the brake on downhills. Learn a different technique. Let the bike roll, hit the brakes hard to scrub speed and then get off them. Don't just clamp on the brake at the top of a hill and keep them on until you reach the bottom. Even with a coaster brake...especially with a coaster brake...dragging a brake from top to bottom is a way of wearing out the brakes. With a coaster brake, it's a way of not having any brakes at all when the mechanism overheats.
Stuart Black
Stuart Black
I was riding the brakes on fairly steep downhills. Oops!
The rims are not the bad guy here, the way I was using super hard brake pads is the problem. I have since corrected my technique. I also have stopped trying to slow on hills where I don't need to.
I plan to replace the rims when needed with similar if not same model, as i am very happy with them overall. The new back tire is a 58 psi continental touring plus (26 x 1.75), which does not push on the rim wall as much as the old kenda kwik (26x1.50) at 80 psi. It's a great setup, because it gives me some more suspension especially with loaded grocery bags.
- Andy
- Andy
