Venge VIAS Handlebars on Older S-Works Venge?
I have a 2012 S-Works Venge and would like to get the newer VIAS handlebars on it. Will this work? I can't find any posts online about someone doing this, or any pictures of those bars on other bikes. I see the VIAS stem is custom to the VIAS, but the bars look like they attach just like any other bars.
Thoughts?
Thanks,
CBR
Thoughts?
Thanks,
CBR
Bikes: CUBE Acid 29er, Salsa El Mariachi SSGT Avalanche X 2009, MMVZ Minsk 1980, Trek 4300 custom, HVZ Ukraina 111-411, Cannondale Trail 5
Quoted: 22 Post(s)
Hi there! It's not hard change bar. You need pull off old bar ribbon, next
loosen the screws switchs and pull out theyre from bar. Next loosen srews stem and pull bar.
Build in reverse sequence. If i will in US i will help you
