Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
Show Off your Track Training and Racing Bikes (2014+)
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 08-17-21, 02:02 PM
  #976
vcletsgetit
Looks nice, what bars are those? they look very compact!
vcletsgetit is offline
Old 08-17-21, 03:49 PM
  #977
Clythio
Quoted: 74 Post(s)
Liked 15 Times in 12 Posts
Selcof Velodromo sold by Planet-X - I have 2 of it and they're very good, solid, small drop, etc.
Clythio is offline
Likes For Clythio:
Old 08-31-21, 06:58 AM
  #978
carpediemracing
Bikes: Tsunami road bikes, Dolan DF4 track
Quoted: 385 Post(s)
Liked 180 Times in 102 Posts
The bike as I'll probably race it for the 500m. This picture from this past Saturday. Experimented with a couple bars, stems, lots of experimenting with gearing. Ridden on two tracks.
NEV which is shallow banked and about as informal as doing track in your yard as can be - like if you had a big yard and a dozen truckloads of cement that's what you might come up with - and TTown which is the absolute opposite. At NEV the concrete is normal road concrete, so coarse and such, with cracks like a normal road might have. There's not enough banking to hold speed at neutral steering input, so you have to really turn hard to stay on the track. And I mean literally - if you go too fast you end up going up the bank and over the tire wall fence. I never felt comfortable doing a 100% jump there because I felt like I'd go up and over the wall.
At TTown it's how fast you can go that limits your speed. I forgot that the surface is like sheetrock, slight texture but otherwise absolutely smooth. Super fast. Huge difference from NEV.
Zipp stem to fit the 7VRN bars properly. I got an extra custom road stem (the -32 deg 14.5 cm ones) to use with a road bar but it's too short in reach, even though the Dolan and my Tsunamis are essentially identical in sizing. I have yet to experiment with toe straps on the pedals.
Last day at TTown, Sat morning racing Aug 28, 2021.
"...during the Lance years, being fit became the No. 1 thing. Totally the only thing. It’s a big part of what we do, but fitness is not the only thing. There’s skills, there’s tactics … there’s all kinds of stuff..." Tim Johnson
carpediemracing is offline
Likes For carpediemracing:
Old 08-31-21, 10:29 AM
  #979
carleton
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
That looks like a great build for the 500m. 1 note, though. I’d recommend trading out the Adamo saddle for a long standard saddle like the Arione classic.
Why? The Adamo is designed to be used in a TT aerobar position while riding on the “sit bones”. This is difficult to get (and stay) perched there while doing a full-gas, anaerobic effort. Also, there is a tendency for riders to scoot forward “on the rivet” what at max exertion. You cannot do that with the Adamo.
carleton is offline
Old 08-31-21, 12:04 PM
  #980
carpediemracing
Quoted: 385 Post(s)
I hadn't thought of the sliding forward. As it is I will slide forward on the Adamo, almost like I'm pushing back on the horns instead of sitting on top of the junction of them. Part of the reason for the Adamo is the padding - after trying it I found it quite painful to use my other saddles - previously I was using the Arione and the SLR (the latter being admittedly hard).
I am a bit disappointed in the post/setback. I would prefer the saddle be more forward, but can't do anything about it right now. On my road bike I have a zero setback post on a seat tube angle that is 1 deg steeper. This one has quite a bit of setback.
Old 08-31-21, 06:00 PM
  #981
brawlo
brawlo's Avatar
Quoted: 288 Post(s)
Liked 76 Times in 57 Posts
Guessing you've never used an Adamo? The Adamo has a wider fat nose for that exact reason. So you can be perched out on the nose of the saddle and still retain some modicum of comfort. There are long and short nose versions for use in different situations.
If you want a longer saddle, Adamo has longer versions. I have the short version on my track and the longer Breakaway on my road for the very reason that it allows me to move forward when I'm on the gas. The Breakaway is the equivalent of the PL1.0 in the newer models
brawlo is offline
Old 08-31-21, 09:02 PM
  #982
carpediemracing
Quoted: 385 Post(s)
Huh. Ironically I have a longer version one but since I couldn't get it to fit right I stuck it on the CycleOps spin bike. I'll put it on my Dolan and see how it is.
Old 09-01-21, 09:49 AM
  #983
carleton
Elitist
carleton's Avatar
Yeah, I used to have an Adamo and a Cobb longer saddle…the Adamo absolutely sucked (for the reasons stated above) and the Cobb was better because it was connected in the center-front, but the vertical padding still took some work to get settled onto at near 40mph/60kph when sitting after the standing start. Also, the sliding wasn’t as smooth as the arione. I would slide forward at the end of the event in an effort to effectively shorten my reach to the pedals and spin more to “get my legs out of the way of the pedals” and avoid applying back pressure while fatigued.
I’ve only seen one top racer use such saddles and that was Rebecca Romero (IP specialist).
It’s not impossible to use them for sprint events…but it’s an acquired taste, and IMHO, not popular for a reason.
carleton is offline
Old 09-01-21, 03:06 PM
  #984
queerpunk
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
Liked 58 Times in 35 Posts
Bike looks great!
One of my favorite feelings at TTown is being completely spun out at 145rpm and just holding on to the draft and the cadence for dear life as the uci giants in front of me rip it up, going so fast through turns 3 and 4 that the rear wheel starts hopping around underneath me. I'm I hope you get that thrill soon!
queerpunk is offline
Old 09-01-21, 03:48 PM
  #985
brawlo
brawlo's Avatar
Quoted: 288 Post(s)
On the contrary from my experience, I've seen a lot of those style of saddle around. There were quite a few in Rio and locally, the Spec Sitero is quite popular as it's easier to get and you can go and try them out at a dealer I guess. I think the "standard" saddle ergonomics are catching up though. Road saddles aren't all about riders sitting in the cruising position for hours any more, and I think the US crit scene has a big part to play in the change. "Standard" style saddles have wider softer noses than 10years ago to give you more positioning options, especially more comfort when "on the now non existent rivet". I used to love my Selle SMP on my road bike, but as I got stronger and faster and started to move around the saddle more in racing it became a horror and that was where I gave the Adamo a try and it worked for me and still does for now at least
brawlo is offline
Old 09-06-21, 05:01 PM
  #986
carpediemracing
Quoted: 385 Post(s)
Err I'm a long, long way away from that! haha. But man, I am hooked. I get out there and instantly feel like, yeah, this is it. I didn't get that feeling in SoCal or when I line up for a crit. I mean, yes, it's fun and exciting and cool and all that, but I never felt like, this is *it*. But the track... I even said to the Missus that if I lived near the track I'd be there for all the open sessions, I'd be racing there all the time... I'd live on the track. Well, one short effort at a time.
Old 09-08-21, 09:57 AM
  #987
bicievino
Quoted: 11 Post(s)
Liked 10 Times in 8 Posts
Can confirm - livin' at the track is great.
It's the last week of our season here in Seattle and I'm very bummed. Dunno what I'm gonna do on Friday nights.
bicievino is offline
Old 09-09-21, 10:17 PM
  #988
m_sasso
Quoted: 95 Post(s)
Liked 98 Times in 60 Posts
Come up to Burnaby! Lots of track time available, our fall race series will get going early October, every Friday night.
m_sasso is offline
Old 09-10-21, 07:35 AM
  #989
bicievino
Quoted: 11 Post(s)
I'll be there! Certainly for Barebones, hopefully for more.
Likes For bicievino:
Old 09-15-21, 05:24 PM
  #990
brian44
Quoted: 15 Post(s)
Liked 58 Times in 30 Posts
Got the new rig out at the end of the season for some efforts (Rock Hill, SC). I was at least able to get some baseline efforts/times to focus on improving over the off-season in spite of itching for a racing schedule.
brian44 is offline
Old 09-28-21, 05:58 AM
  #991
m@tty
Quoted: 28 Post(s)
Liked 34 Times in 21 Posts
New frame arrived today!
m@tty is offline
Old 09-28-21, 07:02 AM
  #992
carpediemracing
Quoted: 385 Post(s)
^ wowsers
Old 09-28-21, 07:11 AM
  #993
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Liked 50 Times in 37 Posts
That's a really nice looking bike on paper, glad to see pictures of it in the wild, it looks great!
Morelock is online now
Old 09-29-21, 08:10 AM
  #994
m@tty
Quoted: 28 Post(s)
^ wowsers
starting to put it together today.
really nice build quality the hydroformed tubing is very nice. I expected the down tube and seat tube to be from the same tubing to cut manufacturing costs but they are completely different and the welding looks top quality.
For anyone interested the Bottom Bracket Drop is 49mm and the Fork Rake is 30mm.
m@tty is offline
Likes For m@tty:
Old 09-29-21, 08:38 AM
  #995
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
That's really nice. Price is competitive with the other high end aluminum options (Kissena and Allez sprint) and it looks really well designed and thought out. The two reach options is really nice too.
Speaking of high end aluminum, does anyone know what happened to Fifty point One? They had a nice spec / customization sheet, but I never saw one except Colby's in a few pictures and some random promo material.
Old 09-29-21, 10:06 AM
  #996
topflightpro
topflightpro's Avatar
Quoted: 1851 Post(s)
Liked 678 Times in 429 Posts
Per https://fiftypointoneracing.com/: Fifty Point One Racing is closed as of March 2021.
topflightpro is offline
Old 09-29-21, 10:35 AM
  #997
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Ah :/ They did seem like nice bikes, but the price point (even for nice semi-custom) likely hurt. It didn't help that Colby rode his hour attempt on a T4 either I guess...
Old 10-07-21, 04:47 AM
  #998
m@tty
Quoted: 28 Post(s)
All built up and ready for use.
moving back to Glasgow next month so the Chris Hoy Velodrome will be a 25 minute drive.
m@tty is offline
Old 10-07-21, 08:26 AM
  #999
topflightpro
Why not flip the stem up and remove a spacer?
Old 10-07-21, 08:35 AM
  #1000
m@tty
Quoted: 28 Post(s)
this setup is for playing with position. There might be some new bars on the horizon soon with less drop so don’t want to cut the steerer two short yet. And I’m not a fan of upturned stems which is why I have fitted a 25mm headset dust cover.
m@tty is offline
