Simple floor stand?
Bikes: 1985 Cannondale SR500, 1990 Cannondale ST600, 1993 Cannondale M700
Quoted: 171 Post(s)
Liked 277 Times
Simple floor stand?
Anyone ever use one of these? Any luck with doing simple maintenance? Thanks!
https://www.amazon.com/Sunlite-Displ.../dp/B000C17HJ4
Quoted: 380 Post(s)
Liked 106 Times
That is not a floor stand but a display stand (kick stand) for new bikes. Not for working on bikes. The ALDI sold stand is about the cheapest worth having. Roger
Likes For rhenning:
Quoted: 1438 Post(s)
Liked 1,092 Times
I have that stand and use it on a workbench when I am too lazy/job too small to set up my Performance Bike floor stand. It works fine for brake and derailleur work and the like, since it holds the rear wheel off of the bench. Just watch how you set it up so that it doesn't pinch the cables running under the BB, if you have them, makes it hard to adjust them.
Likes For dsbrantjr:
Quoted: 2026 Post(s)
Liked 1,096 Times
I had one and tried to use it for maintenance. It was nearly useless for anything but a display stand and a parking device. It got the rear wheel slightly off the ground but the crank arms hit it when attempting to adjust the shifting and it wasn't steady or strong enough for much else. Buy a real work stand.
Likes For HillRider:
Have you thought about the Scorpion stand? I am thinking of that for the balcony, when I just want to clean my chain and don't want to break out the parktool stand.
Likes For CarloM:
Quidam Bike Super Hero
Bikes: 1995 Trek 800 Sport, aka, "CamelTrek"
Quoted: 331 Post(s)
Liked 415 Times
I actually use my Saris Bones car rack by setting it over the rail of my porch. Easy, cheap and stable....
Likes For Digger Goreman:
I have no idea if it’s a regular item or not, but Aldi sells a very credible and inexpensive workstand. I happened upon it earlier this year and was very pleased.
Likes For Mogens:
Back in the BMX days we worked on our bikes at the track using a display stand. Not good for much heavy lifting, but for simple adjustments it works well.
Likes For TiHabanero:
Quoted: 1303 Post(s)
Liked 1,910 Times
TiHabarnero,
Which back in the day are you referring to? The ABA or the NBA? Smiles, MH
Quoted: 171 Post(s)
Liked 277 Times
I keep seeing references to those Aldi stands. If I ever get closer than 120 miles to an Aldi I'll have to grab one!
Aldi stand
Not a regular item, only comes out one week in May and each store gets so many, and when they sell out it is done. When May comes around, subscribe to the Aldi Weekly ads and Aldi finds, look every Wednesday during May, and when you see them advertised , bike or run to Aldis. I have one and like it much better than a more expensive one I used to use.
Likes For obeachron:
Bikes: 1984 & 1990 Marinoni Specials - 1990 Bianchi Sika - 1993 Cannondale M800 - 1996 GT Zaskar - 1993 Kona Kilauea - 1987 Ritchey Ascent - 1996 Rocky Mountain Vertex - 2008 Kona Dogma - 1976 Schwinn Suburban - 1994 Kuwahara Makai
Quoted: 36 Post(s)
Liked 203 Times
Hi have been using a Feedback Sports Recreational Work Stand for a few years which cost $150CAD. It's not as adjustable as other more expensive models but I'm happy with it.
Likes For retrodude:
