Is there a quick, easy way to wash a bike??
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Likes For Unca_Sam:
Quoted: 1221 Post(s)
Liked 627 Times
No trolling in this case though, the sprayer works great! I'll fill it with just hot tap water, and it's nimble and powerful. Makes cleaning the drivetrain a breeze, it's powerful enough to blast away grime on the jocky wheels, chain, cassette and chain rings.
Likes For GrainBrain:
Quoted: 4227 Post(s)
Liked 2,488 Times
GCN is to be taken with grain of salt.. Personally I would never use high pressure spray around the bearings. High pressure wash is a great way to shorten the lifespan of the bearings.
Quoted: 18397 Post(s)
Liked 15,494 Times
Liked 15,494 Times
Quoted: 2599 Post(s)
Liked 1,924 Times
My favorite technique is the Pactour "1-minute" bike wash:
OK, with the chain lube, it takes closer to 5 minutes. Requirements include:
Chain lube
rag
bucket
Dawn
brush(es)
water
OP, you or your wife can run upstairs and bring everything down to the parking lot.
Chain lube
rag
bucket
Dawn
brush(es)
water
...like the title asks, is there a fast and easy way to wash a bike? My wife has a Trek Marlin and has been riding several times a week on a bike path that has a section that is compact dirt, the rest is all paved or compact gravel. Because its been so dry the compact dirt section is coating her bike with dust, it's very fine dust that has gotten into everything. We looked up washing your bike and had a good laugh. We live in an apartment so no bike stand, no place to hose it down, wash it, rinse it, all using multiple buckets, multiple brushes, bike polish, chain washers, etc, etc.
Any thoughts or suggestions would be helpful, thanks.
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,203 Times
I wouldn't put the nozzle right at the bearing and spray but the pressure reduces very quickly after the water leaves the nozzle. It's not really an issue but using a car wash is quick and easy.
Stuart Black
Stuart Black
If in doubt, the car wash usually has a low pressure setting. For those sensitive areas.
Likes For rydabent:
Liked 4,203 Times
Lots of times a “damp rag”, just don’t cut it. Ridin’ through the herd is just one of those times
DSCN1270 by Stuart Black, on Flickr
Stuart Black
Stuart Black
Likes For cyccommute:
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,857 Times
A sponge, a small bucket of soapy water, and a big bucket of straight water. BUT, this is just for getting rid of the dust and sweat. Probably won't remove the lube from your chain, but also won't remove the dirt from your chain, either. So it's mostly just cosmetic and you'll want to figure a way to do a real wash.
Quoted: 164 Post(s)
Liked 44 Times
i personally run sram chains so i can just take the chain off , and soak it in gasoline or lamp oil for a full chain clean, you can just use old bottles and throw the excess away or bring it to a disposable place if you are eco lunatics , for on bike drive train clean spray it with the cheap wd40 lube and scrub the cassette and chain with a hard brush using the ratchet motion of hub then use a rag and spin the crank until the black comes off . RELUBE WITH WAX !!!!!! i use parafin wax most of the time , slow heated over the stove in some tins !
you could just go to the car wash every two weeks and use those hoses .
for polish just use organic coconut oil and a soft rag , and it will take off any dirt , but it will collect some dust !
It's a bicycle! Everything about cleaning it is quick.
A lot of good suggestions here. I would just get a couple of buckets with soap in one and take it outside. A chain cleaner like the one from Park Tool us good to have. Don't forget to lubricate the chain!
Bikes: Diamondback Haanjo Trail, Fuji Team Road
Quoted: 160 Post(s)
Liked 68 Times
I was in the same situation. I went to a self service car wash with a bucket of water, sponge, and chain cleaner. I did the dirty stuff in the parking lot with the bike on the rack (long line of cars), then pulled into the wash bay to hose it all down (rinse setting, not jet spray). Worked fine.
Advanced Slacker
Quoted: 2761 Post(s)
Liked 2,534 Times
When I lived in an apartment with a similar situation, before coming inside I’d knock of the big chunks that might come loose on the way in, then put something down on the floor under the bike where I kept it in the apartment.
Every so often I’d wash it off outside with a bucket, but only when it got bad.
I just lived with a dirty bike. As long as the dirt stayed on the bike, I did not see a real problem with it.
I am of the school of thought that from a mechanical perspective, washing a bike usually accomplishes nothing. As long as the chain (and rings and cassette) are OK, everything else is fine.
Likes For Kapusta:
One local off-road rider used a pressure washer. It was quick, easy, and very, very bad for the bearings.
Bikes: Trek Madone 5.2, Trek Singletrak, Cannondale 500, 1976 Motobecane Grand Touring
Quoted: 10 Post(s)
Baby Wipes
Liked 4,203 Times
We may not agree on much but I agree with you here. This obsession with making sure a bike doesn’t have a speck of dirt on it is silly. Bikes are meant to be ridden. A dirty bike is a bike that gets ridden.
Stuart Black
Stuart Black
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
I clean my bike every week which is about 150 miles. I do it for multiple reasons:
1) I find problems before breaking down
2) a clean drivetrain lasts longer. I have 26,000 miles on a Sram Red cassette and at $400 to replace i'm way ahead of the game.
3) a well maintained bike simple performs better
4) personal pride, just like you don't wear dirty cloths when you're out in public.
Buy yourself a ParkTool foldable bike stand, take your bike and the stand out to a parking lot or other open space, and follow the instructions on the below YouTube video. This has worked like a charm for me since 2015.
Shake the mix bottle with the alcohol and spray where you want to clean. Wipe with a rag, then rinse the rag in a bucket of warm water. Continue the process until completed. I hope this helps
