This inner tube is close enough in size right?
Old 08-01-20, 04:35 PM
prime winner
Bikes: Trek Verve 2
Quoted: 35 Post(s)
Liked 23 Times in 10 Posts
I went to go for a ride this morning and realized I had a flat. I had just rode a 10 mile neighborhood ride two days ago, but something got me without me noticing it and the tire was completely flat. I thought I had a spare tube, but not even close in size, my flat tube was a 29 x 1.9 - 2.35. I went to the Giant dealer that I bought the bike from and they said they did not have my size, so I went to another dealer (Trek). The guy brought out a Bontrager 29 x 1.75 - 2.125 and said it should work, so I bought two.
So it's a 29 x 1.75 - 2.125 close enough to my original size of 29 x 1.9 - 2.35. My tire shows 29 x 2.20 on the side.
Thanks in advance!
prime winner is offline
Old 08-01-20, 04:56 PM
kevrider
kevrider's Avatar
Bikes: way too many
Quoted: 61 Post(s)
Liked 5 Times in 3 Posts
i'd use it and wouldn't lose any sleep over it.
kevrider is offline
Likes For kevrider:
Old 08-01-20, 06:10 PM
prime winner
Bikes: Trek Verve 2
Quoted: 35 Post(s)
Thanks kev, I'll roll with it
Old 08-01-20, 07:27 PM
AnthonyG
AnthonyG's Avatar
Quoted: 3450 Post(s)
Liked 420 Times in 289 Posts
Going a "little" bit smaller in tube size is OK. The tube will inflate to fill the void although there are limits.
Going larger in tube size however is a problem as the tube is likely to kink and wont fill the void evenly.
AnthonyG is offline
Old 08-01-20, 08:03 PM
wolfchild
Quoted: 4227 Post(s)
Liked 2,488 Times in 1,286 Posts
It's ok to use a smaller tube. It will stretch and fill the tire up. I've used 700x32 mm tubes inside 700x45mm tires without any problems.
wolfchild is offline
Old 08-01-20, 10:31 PM
katsup
katsup's Avatar
Bikes: 1995 ParkPre Pro 825 2021 Soma Fog Cutter v2 and 2021 Cotic SolarisMax
Quoted: 607 Post(s)
Liked 560 Times in 318 Posts
I use "close enough" size tubes in tires all the time.
katsup is offline
Old 08-02-20, 09:13 AM
wphamilton
wphamilton's Avatar
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times in 228 Posts
No problem with a slightly small inner tube.
Even with too large a tube it still works fine. Air pressure will be equalized regardless of folds and kinks, but if it is folded the crease may eventually wear cause a flat.
wphamilton is offline
Old 08-02-20, 04:53 PM
prime winner
Bikes: Trek Verve 2
Quoted: 35 Post(s)
I checked the tire and didn't see a hole so there's a win. When I was airing up the new tube I heard two seperately pops after 45 psi. Is that the sound of the beads snapping on the rim?
Old 08-02-20, 08:30 PM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2761 Post(s)
Liked 2,534 Times in 1,433 Posts
That pop would be normal and is what you guessed it was.
A deafening boom would be something different.
As far as sizing the tube.... go by the size of the actual tire, not the tube that was in it.
Kapusta is offline
Old 08-03-20, 09:32 AM
prime winner
Bikes: Trek Verve 2
Quoted: 35 Post(s)
Thanks Kapusta, and everyone that had input, I appreciate everyone's help!
Old 08-03-20, 09:39 AM
Kapusta
Advanced Slacker
Kapusta's Avatar
It kind of cracks me up that something as forgiving as the high limit of a tube is specified to 3 decimal places.
Kapusta is offline
