Internal Frame Cable routing
Bikes: Wilier GTR SL, Wilier Jena Hybrid ebike, Cannondale Scalpel
Quoted: 9 Post(s)
I'm getting ready to remove the front and rear derailleur cable end caps to pull cables back for installation through a new frame. I would like to keep cable ends from fraying while reinstalling, passing them through cable housing and frame downtube. I am considering super glue or wrapping the ends tightly in clear tape. What works best.
Likes For rhenning:
Quoted: 303 Post(s)
Liked 136 Times
super glue 'might' work, but tape won't fit through the housing. To echo rhenning, if pushing the cables through results
in fraying/unraveling use the old RD cable for the FD and get a new RD cable. Old RD cable unlikely to unravel enough to
be too short to cutoff the bad part at the FD. OTOH if cables are a few years old better replace as the normal failure is
within the brifter, which is the worst place for a cable to fray/break.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
No no no. Use new cables AND housing. Do not cheap out on this, it makes no sense.
Likes For cxwrench:
Quoted: 569 Post(s)
Liked 581 Times
If you are doing something like moving shifters that have new cables to a different bike tape will not work, super glue can work.
Quoted: 9 Post(s)
I hate trying to route the new cables through the Campagnolo Ultra Shift shifters . There's a tough bend positioning the cable end to come out of the housing and into the opening where the cable housing accepts the cable. I'm going to order a new RD cable and see if I can re use the existing cables first using super glue.
Clark W. Griswold
Quoted: 4347 Post(s)
Liked 3,984 Times
Sometimes routing cables sucks but when building a new bike it is always good to start with fresh cables and housing to get the best out of the bike. Buy less coffee or one less CD from Columbia House or something like that, don't cheap out on cables and housing.
Quoted: 4199 Post(s)
Liked 3,851 Times
Internal routing? Housing liner slid over the inner cable before the cable is pulled from the frame is a big friend. If you can't slide the inner end into the liner due to fraying then replace the inner. Andy
AndrewRStewart
AndrewRStewart
Quoted: 94 Post(s)
Liked 151 Times
I usually just use the old housing to fish the new housing through the frame. I first cut off any ferrules from the ends of the old housing then I tape the end of the old and new housing together using a good strong duct tape then I pull it through the frame by carefully pulling the old cable while pushing the new cable.
Likes For ARider2:
Friendship is Magic
Bikes: old ones
Quoted: 26402 Post(s)
Liked 10,374 Times
...heatshrink tubing (the stuff electricians use) is your friend. Works very well to join the end of the old cable and the new one for the pull. But I have never tried to get it to go through outer housing, and suspect it won't work for that. My pulls have always been for internally routed cables where the housing ends at the internal frame insertion.
Likes For 3alarmer:
Quoted: 581 Post(s)
Liked 921 Times
Unless it's some sort of emergency, I never re-use cables that have been pulled out (except for sometimes converting a cable from R to F duty). As others have said, cables have a finite life, are not expensive, can be a pain to reinstall, and if they fail they are likely to cause other problems.
Likes For Geepig:
Quoted: 1607 Post(s)
Liked 2,216 Times
I once paid $30 for a full set of Campagnolo cables. I thought it was too much but the bike it was going on was worth it to me. Best cables I have run into with nearly no perceptible resistance. Would buy them again for the other bike that is all Campy. Wait... all the road bikes are! Ouch!
Quoted: 581 Post(s)
Liked 921 Times
I am the same.. I patch tubes, keep old spokes bundled together have a pile of worn tires for trainer or emergency use, and stop and evaluate abandoned bikes by the side of the road for usable bits. Nothing that comes off a bike is necessarily going in the bin EXCEPT for rear inner cables. My cost-benefit analysis includes the potential time and hassle of trying to fed a frayed cable through the housing, and the likelihood that it'll seem OK but problems will materialize when trying to set the thing up. I can tolerate the risk in a cable that has been cleanly cut into a shorter cable, but that's my limit.
Likes For ClydeClydeson:
Friendship is Magic
Bikes: old ones
Liked 10,374 Times
