What BB for 42 mm chain line with Sugino RD cranks?
JuNKie! bike junkie!
can some on help a brother out?
what size bb does a stock bianchi pista run?
i think it the same cranks, right?
thanks
thanks
www.cranks505.com
www.cranks505.com
THIS SPACE FOR RENT
Only the '05 Pista had RD's, and they were the old style RD's and had the chainring on the inside from the factory. I don't know what size the BB actually was on those, if the 103 works the ring will need to be on the outside.
thanks 103 it is.
www.cranks505.com
www.cranks505.com
Bikes: 05 Bianchi Pista, 07 Niner Air 9
The sugino 103 bb did work on my conversion with RDs but the chainring is on the INSIDE.
THIS SPACE FOR RENT
Some '05 pistas definitely came with it on the inside. Hell, the one on the web site had it that way. I think maybe they used different BB's at different points or something and moved the chainring accordingly.
I've been tracking this issue with the RD's for a while, the next to last piece of the puzzle is that the current production, which are stamped RD2, are speced to have a 45mm chainline on the Sugino 103 bottom bracket. So your choices are to deal with that or get a 107 bottom bracket and move the chainring to the inside. The final piece, which I suspect but have not yet confirmed, is that the RD-5000, which are stamped D-5, sit at more like 42 on the stock BB. The 103 bottom brackets are JIS taper, maybe a hair smaller than Shimano.
Square-o-dynamic
Bikes: something fixed, something broken
The RD's I just got from ben's cycle are stamped RD3 and have the new Sugino logo on the arm, not the text "sugino" like the RD2's. I'm using the 103 sugino BB, ring on the outside, and the chainline is dead on!
https://www.benscycle.net/index.php?m...roducts_id=528
https://www.benscycle.net/index.php?m...roducts_id=681
Bikes: 1972 Paramount Track, 1972 Paramount P13 Road, 1972 Paramount Tandem, 1986 Paramount Road, Merckx MXL, Gunnar Cross Hairs, Samson Illusion NJS, KHS Aero Track, Titus Racer X 29er, Tom Palermo Custom Touring
My RDs w/ 103 give ~ a 45mm chainline.
King of the Hipsters
Bikes: Realm Cycles Custom
My 2005 Pista came with the chain ring on the outside position of the RD cranks, and had a poor chain line.
I moved the chain ring to the inner postion, and it worked great from then on.
I think a 103mm crank bearing spindle with the chain ring on the inner position of the RD crank gives an almost perfect 42mm chain line; or, as perfect as it gets.
im going through this right now with my Bianchi San Jose... but dont really want to put orgin8 or sugino rd's on adn its not i dont mind paying for the dura or sugino 75s its finding a pair thats for actual decent or good deal.
anybody know if you can toss some Paul Cranks or Phils on there? Or perhaps old Campy records/super recs?
Your cog is slipping.
Your frame has a standard 68mm English-threaded BB shell. You can use any crankset you want as long as you use the correct bottom bracket for the crankset.
Likes For Scrodzilla:
Quoted: 336 Post(s)
Liked 309 Times
The chain ring is currently inside the spider, which the previous owner probably did to “fix” the chain line when they used a narrow hub.
Likes For aggiegrads:
You seem to be confused. Rear chainline is measured from the center of the hub, not from the dropout.
Adding a spacer to each side doesn't change the distance between the freewheel and center of the hub, thus having no effect on chainline.
Quoted: 336 Post(s)
Liked 309 Times
Yeah, fair point. I would actually go further and say that it is measured from the center of the frame, as there is no guarantee that the hub is centered in the frame.
Especially if someone like me has respaced the hub or if someone has cold-set the frame.
Sure, but you've already mentioned that you have a 120mm track hub. Why would you ever want or need to space it so it's off-center?
Stop over-thinking this and just do it correctly by adding a 5mm spacer to each side.
so basically if you dont have the proper spaced rear (or front) hub spacing you are going to have to add spacers correct?
I would love to keep the San Jose as true as possible and not bootleg fix it when i have the ability to have it working right as intended. just finding a crank set up has proven difficult with frame rub and striking.
anybody have exp with the san jose and the cranks?
