8 speed friction thumb shifters?
Bikes: 2019 Trek Stash 7, 1994 Specialized Epic 1986 Diamondback Ascent 1996 Klein Pulse Comp, 2006 Specialized Sequoia Elite
Quoted: 418 Post(s)
Liked 521 Times
My Klein Pulse's 8 speed LX Rapidfire shifters are beginning to fail. I've replaced them once before and would prefer to replace them with simple friction thumbshifters and linear pull v brakes. I'm having a hard time finding nice friction thumbshifters that won't cost a fortune. Hopefully, I'll be able to find some used shifters at a bicycle coop. If not, will the Microshift cnc thumb shifters for Alfine/Nexus 8 work? These look nice, but are a lot of money. I'm not seeing anything else out there that is of decent quality, but not too expensive.
If its truly a friction shift lever, what 'speeds' count does not matter... you can find a simple thumb shifter in a packaged pair for $20..
My LBS carries them, I am using a set on one bike, now.. (6 speed freewheel on it.. )
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
What about Sunrace SL-M10: SunRace | SLM10
Not the prettiest, can be had for $10 a pair. I run one for the front (triple). It gets the job done.
Sunrace also makes SL-M96, which are nicer.
Quoted: 418 Post(s)
Liked 521 Times
Thanks guys,
I saw the SunRace shifters on Amazon. Apparently they have been known to rust - I'm not sure if that's true or not. The SL-M96 is sold individually. To get the right and the left shifter would be about $50.
These are $37 for the pair, but it say's they're indexed for an 8 speed internal hub. I'm not sure if they can be switched to friction mode.
I hoping a trip to the bike shop will yield some indexed shifters that can be switched to friction mode.
Really Old Senior Member
Did you try flushing your shifters with WD-40.
Quoted: 418 Post(s)
Liked 521 Times
I haven't. Think it might help?
What's happening is the shifter is failing to engage every once in awhile. When it fails to engage, I'll try another two or three times and it'll finally engage. Could my shifter cables be the problem?
Here's a video about fixing a shifter this way:
This isn't the same shifter you have, but the basics still apply.
The Sunrace SL-M96 comes in 8spd indexed, and generally a little cheaper on ebay: https://www.ebay.com/itm/SUNRACE-138...Qu3c:rk:1:pf:0
If you can find a set of NOS Suntour thumb shifters, they're the best ever.
https://www.ebay.com/itm/SUNTOUR-ALP...pa6:rk:45:pf:0
Insane Bicycle Mechanic
Quoted: 802 Post(s)
Liked 703 Times
Jeff Wills
Jeff Wills
Quoted: 418 Post(s)
Liked 521 Times
Quoted: 1572 Post(s)
Liked 643 Times
Quoted: 418 Post(s)
Liked 521 Times
I prefer friction also. I have some vintage Suntour shifters set to friction mode on the mountain bike I converted for touring and it's by far the simplest, easiest to work on, and most trouble free shifting system. It's especially nice on tour when you may be gone for a couple of weeks.
BikeEveryday
Classic & Vintage
35
09-27-17 12:29 PM
AceH
General Cycling Discussion
4
06-24-10 04:29 PM
