Rear tire skidding
Bikes: Dawes Lightning DLX, 1988 Klein Performance, 1991 Peugeot Safari, 1985 Raleigh Alyeska, Carrera Phantom, 1973 Raleigh Record
Quoted: 282 Post(s)
Liked 129 Times
I agree with most of the other replies. Additionally, don't be afraid to get off the seat and move your weight around to where you need more traction (generally scoot back a little on descents). Back in 1987-ish I did manage to use too much front brake on a long descent and suddenly found myself flying over the handlebars, then saw the bike flying over me. Fortunately, I never repeated that, but I took to shifting my weight rearward on descents, and I've been afraid to add luggage on the front of the bike. I've always used both brakes in all conditions, but I'm conscious of how much pressure I'm using on either brake lever and modulate to suit conditions.
Braking before you turn is good advice on a bike, motorcycle, or in a car. Some people do like to drag the rear brakes a little in a turn to adjust the balance of the vehicle rather than to slow down.
Habitual User
Quoted: 4930 Post(s)
Liked 8,062 Times
Effective bike handling skills include developing a feel for when and how much of each brake to use in a particular situation.
Likes For Eric F:
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
I rocked a pushie with just a front brake for a while... it was fine like 98% of the times I braked, but that other 2% was scary. Sometimes you need to throw that back wheel out.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
Thanks everyone - I've been favoring the front brake and life is much more safe
bike whisperer
Liked 716 Times
You want to be good enough with it that say if you're braking on a turn and it starts to skid, that's not enough to make you drop the bike. Emergency stops should have your back wheel hovering.
Likes For Kimmo:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4369 Post(s)
Liked 3,001 Times
I think a lot of peopel on this thread know more than me on this subject, but as a matter of habit, I almost always use both brakes at once for most situations. the balance between front and back then comes from "feel", such that I can't tell you in a given situation that that was 70% front, 30% back - it was both and the relative pressure I was applying is what gave me the feeling of greatest control.
Maybe I'm doing it wrong.
Oh yeah there are also those hard-braking moments - usually something like coming to a sudden stop at an intersection - when the rear wheel lifts off the ground a bit. Those are always fun.
Likes For MinnMan:
bike whisperer
Liked 716 Times
Each tyre only has so much grip; when you're braking you're using up some proportion of that grip, so it's generally best to share the load. And when descending, you have to manage heat buildup too. 70/30 wouldn't be far wrong, but of course it's gonna vary.
If you have rim brakes, you might also want to think about whether you want to spread the rim wear or concentrate it on the front. If your back rim wears out first, you're doing it wrong.
Likes For Kimmo:
Quoted: 1079 Post(s)
Liked 1,019 Times
Using both brakes is more ‘effective’ at keeping the front and rear brake wear even. For hard braking or emergency stops though using 100% front is correct. Maybe if you can get enough of your weight behind the saddle you could use a little rear brake but the vast majority of weight will be on the front tire and the braking force available from the rear is small.
I use a lot of rear brake, I do a lot of descending and I am a heavier rider. I can't think of many times I have locked the rear wheel, it almost never happens.
While it's true the front provides 70% or more of the stopping power, careful use of the rear on a steep descent can aid in your control and help keep the front from getting too hot. Sometimes when I just want to scrub speed I will alternate front to back.
There is a steep grade I do which is twisty and a bit off camber. I use lots of both brakes on that thing.
Avoid these two things. As others have mentioned, speed should be scrubbed before a turn, if you have to brake through one you need to use light pressure on both wheels so you don't lose grip. Braking is a dynamic process, you need to shift your weight or position to allow the brakes to do better. When descending through curves I try not to sit and if you watch a lot of racers the fastest ones are moving on the bike to keep their weight optimized and allow the knees to soak up small bumps so the tires track better. Being crouched on the pedals slightly also lets you respond to the bike under braking better.
Likes For Russ Roth:
just another gosling
Quoted: 3885 Post(s)
Liked 1,938 Times
In my youth, riding my motorcycle way too fast in the Alps, I found that starting with the a light rear brake to sort of steady the bike and then adding as much front brake as necessary worked best. Testing has shown that under extreme braking on a road bike, using only the front brake gives the fastest stop. My guess is that having one's full attention on only one thing is the trick.
Of course just like on any racing machine, brake before the turn, never during if you can help it.
Results matter
Results matter
Likes For Carbonfiberboy:
climber has-been
Quoted: 3416 Post(s)
Liked 3,544 Times
The fastest deceleration occurs when the rear wheel begins to lift off the pavement. At that point, the rear brake is useless.
Ride, Rest, Repeat. ROUVY: terrymorse
Likes For terrymorse:
Liked 1,019 Times
Proof? Cause that sounds like a load of BS to me. If you're rear wheel is off the ground you're doing it wrong. Get your weight back and use both brakes.
climber has-been
Liked 3,544 Times
A simple force diagram shows that maximum braking force occurs when the rear wheel begins to lift off. I won't waste my time proving something so patently obvious.
Liked 1,019 Times
Go practice some emergency braking in a straight line, on dry pavement. You'll quickly discover that the rear brake is essentially useless in that situation.
climber has-been
Liked 3,544 Times
A bike is at maximum deceleration when the rear tire begins to lift off the pavement.
Brake as you wish, but if you claim that using both brakes is the fastest way to stop, you are wrong. Physics says so.
bike whisperer
Liked 716 Times
If you're doing everything you can to get your weight back as far as possible, what happens when you're braking as hard as you can without going over the bars?
The back wheel comes up. A full-blown emergency stop is you balancing the whole bike around the head tube while you hope the fork is up to it and the back wheel is a passenger.
First time this happened to me BITD, it was the second time I had to make an emergency stop with a fancy new dual pivot brake. The first time, I went straight over the bars, and I was totally stoked that now this was a thing I could do.
Hmm, maybe a faceplant is the fastest possible stop?
bike whisperer
Liked 716 Times
It occurs to me that perhaps both brakes can get you quicker to the point the rear brake is useless, but since that happens in a fraction of a second, it's pretty academic.
bike whisperer
Liked 716 Times
Dunno how you ride your bike, but that's always taken care of itself for me
Likes For Kimmo:
Quoted: 282 Post(s)
Liked 129 Times
I expect the rear brake will have some effect *before* the rear tire lifts off. Breaking doesn't begin with a stoppie.
Liked 3,001 Times
Seems to me that what others have said is right: in that instance, there isn't any harm in also using the rear. In the best case, it helps you shed speed and you doesn't lift off. And if it lifts off, what have you lost?
Cheerfully low end
Quoted: 644 Post(s)
Liked 1,044 Times
This lesser point will surely be lost and buried in this thread, but I run the same tire pressure in front and rear primarily because of the issues discussed here. Since the weight transfers more to the front wheel when braking, I want the front tire to behave properly under that increased load.
Riding SS I also ride out of the saddle often with weight over the bars, so there are a lot of moments of more forward weight distribution even when not braking.
Anyway, something to consider when you set your tire pressure.
Otto
Otto
climber has-been
Liked 3,544 Times
But if you're just talking about maximum braking, that is always the point where the rear wheel is about to lift off. That situation holds at any moment, from when you first apply the brakes to the moment you come to a stop.
Cheerfully low end
Quoted: 644 Post(s)
Liked 1,044 Times
Been doing a lot of hills lately. I read or watched a video where someone recommended slowing down using the rear brake.
while doing that I’ve had a few occasions where (especially in a turn) my rear wheel locks up and I start a short skid. Luckily I’ve corrected by releasing the brakes in time to prevent losing control.
im using rim brakes and keep my but on the saddle
any tips to avoid the skids?
Second, when cornering, the available frictional force is shared by cornering forces (lest the wheel slip and you fall) and braking forces. This means you will skid all that much quicker because the act of braking has unloaded the rear wheel and you are also cornering at the same time.
Hope that helps.
Otto
bike whisperer
Liked 716 Times
For those of you experts who emergency stop only with the front brake, what's the technique to keep you from going over the bars? Getting your weight as far back behind the saddle as possible as fast as possible and hope, huh?
But the first instinct is to throw myself back hard as I grab a fistful.
Likes For Kimmo:
