Road bikes and handlebar pinch bolts.
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
I know it’s not the end of the world. I understand if your riding 100 miles every ounce probably counts.
That said, I get annoyed when I see that one pinch bolt and know the bars have to slide all the way through to separate the bars from the headset.
Quoted: 6193 Post(s)
Liked 4,808 Times
So you don't like vintage bikes. Or does that anger transfer to the riders too?
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
I think vintage bikes are cool.
I think the C&V thing is cool.
Breathing new life and your own touch into something to make it go better than new is cool.
Quoted: 1944 Post(s)
Liked 2,164 Times
You can get a quill stem with a removable faceplate for an older bike.
I admit is is a pain if you are trying out different bars. But it is kind of a moot point once you have dialed in your setup since it might stay that way for decades.
And some people just prefer the elegance of a single bolt stem.
John
John
Likes For 70sSanO:
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
John
John
I did think about it from the other side. “For the guy who puts thousands of miles on his bike- The PITA factor to miles traveled is probably a good ratio.”
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Everything's a trade-off: Quill stems allow for greater and easier height adjustability, but they also flex more. Threaded headsets are a PITA to adjust, but quill stems look cooler.
If you swap out handlebars a lot, you learn not to tape them until you're sure.
Quoted: 18373 Post(s)
Liked 4,509 Times
I really don't take my bars on and off of the bike very frequently. Put them on once, and ride and ride and ride.
The issue I have with the old pinch bolts is that they don't work with all styles of bars, especially the flat top bars which I tend to prefer.
Likes For CliffordK:
IDK ... I disassembled my C&V bike last year, and all I did for the bars and stem was take the levers, tape, cables, bars, stem, brakes off as a single assembly. Reassembly was a breeze.
But I think I understand the problem. I'm contemplating new 'bars this year, and the biggest impediment is that I don't want to go through the hassle of threading new 'bars through the stem ... modern stems make switching bars so easy! OTOH, I think I last threaded bars through the stem in 1984, so it's not that big a deal.
Liked 4,509 Times
If you are switching bars, you generally also have to switch the brakes, so not so much time saved avoiding taking everything apart.
And there is only one bolt to worry about, rather than four, and no faceplate to get lost.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Likes For cxwrench:
Liked 4,808 Times
Likes For Iride01:
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,896 Times
Likes For genejockey:
Liked 4,808 Times
Likes For Iride01:
Quoted: 4806 Post(s)
Liked 3,928 Times
I'm a quill stem guy. I love the ease of raising and lowering. I used to do it in my racing days. As the season progressed, the bars went down. Got slammed for criteriums. (They all had dents in their throats.) My first ti custom got a threadless 1" steerer and steel fork. The next (my logo) got similar fork and steerer BUT threaded. While it was being built, I picked up a wide set of pista bars. Set them up as climbing bars with huge hooded levers (that I later learned were V-brake) and dual pivot calipers.
That setup didn't have the best on-the-hoods position, so I made up another cockpit and brake with regular road bars and levers mated to Superbe side-pulls. This made for a really good flat ground setup.
The real joy (and where quill stems absolutely rule!) is swapping the two. I take off the front brake; still cabled up. Disconnect the rear cable. Loosen the stem and lift off everything. Reverse process with the other cockpit. Swap the rear caliper and connect. Done. 10 minutes or less. With a piece of tape (or existing scratch) on the stem; nothing to measure, adjust or fuss with. Rear brake cable adjust is so non-critical and the little wheel adjust is right there. (Plus both the Shimano DP and the Superbe have cam lever releases that can be use 1/2 open; allowing for fine tuning as you ride and keeping that swap to 10 minutes even on a bad day.) With a long quill, getting the bars straight is easier than with those fatter threadless stems. Stem bolt torque? On those quills, almost every torque you can imagine works. No one ever used to use a torque wrench with them. Failures were/are rare and most happened with really cheap stems or stems several decades old.
In 10 minutes, I can completely change the complexion of the bike. And I can do it immediately before I leave for my ride. Never a headset I didn't quite dial in or second thoughts about stem bolt torques.
Oh, that first ti bike? When its headset dies, it's getting a threaded headset and Nitto Pearl stem; going back to the builder to have the stem cut and tapped. (A little sad. When George W sent us all that check, I spent mine on a custom and gorgeous ti threadless stem. The Pearl will be heavier and more flexible, but a lot more graceful.)
Likes For 79pmooney:
climber has-been
Quoted: 3427 Post(s)
Liked 3,563 Times
I'll stay with the modern design.
Guest
Liked 3,270 Times
I don't run quill stems these days either, but the "flaw" is
(a) not fatal
(b) easily prevented
(c) the same as a seatpost, yet somehow we've survived
Likes For Rolla:
climber has-been
Liked 3,563 Times
It is not easily prevented. Let some sweat fall from your brow onto your stem, rock the wobbly and creaking stem back and forth so the sweat can penetrate, deliver that sweat to the snug AF tightener bolt at the bottom of the quill.
It is not the same as a seatpost, which doesn't get sweat deposited upon it regularly, doesn't pump sweat into the depths, doesn't have a tightener at the bottom of the post.
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
Stem not headset.
It could be easier to replace the stem and leave the bars in it. That makes sense.
Thank you all for the different ways of looking at it.
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
I don’t remember it ever happening on a BMX track, but that would’ve been interesting.
Quoted: 6963 Post(s)
Liked 10,962 Times
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
Clark W. Griswold
Quoted: 4352 Post(s)
Liked 3,989 Times
If your desire is to remove the quill stem at some future date, it is fatal.
It is easily prevent by our good friend grease and regular maintenance like onewould do on their bike normally.
You don't sweat from your buns or fleshy fun bridge? Certainly have had triathlete piss (yes some do pee while riding and drop their bikes off for service before cleaning and sanitizing) on them so I can't imagine you wouldn't get sweat as well, would be tough not too. But again like the quill stem you can grease it and pull it out once and a while to check it not hard and not a long process and will save you from seizing.
They also did have quill seatposts, not very common now but they did exist not that it matters. The important thing is grease and some occasional but regular checking. If you are saying this stuff is so bad imagine what is going on with the rest of your bike that you don't maintain.
Likes For veganbikes:
