Repairing partial tire tear
Bikes: Canyon Ultimate CF SL Disc, Canyon Spectral
Quoted: 73 Post(s)
Liked 24 Times
I got a flat this morning. When I got home I checked the tire and found a little gash in it. It doesn't go all the way thru but it's reasonably deep. Can I put a proper rubber patch on it with rubber cement and call it good?
Thanks
Thanks
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
crazy glue
Should Be More Popular
Quoted: 22596 Post(s)
Liked 8,925 Times
Likes For datlas:
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,434 Times
To me, the tire looks pretty well used and the cut is significant. Cannot tell if it goes into the cords, but I would probably trash that tire. If you want to attempt some kind of fix, I do not think a patch and glue is proper. Even if it holds and lasts, it's likely to cause a hop that would drive me crazy. It's your bike, your ride and your body. You decide.
Quoted: 73 Post(s)
Liked 24 Times
Thanks guys. I threw some shoo goo in the tear. I'll move the damaged tire to the back rim.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
Use a cyanoacrylic adhesive. Superglue or equal. Gel or liquid. Clean well with isopropyl alcohol first. Apply adhesive then Flatten the area so the split stays closed for a day. Shoe Goo will not last as long.
Likes For biker128pedal:
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
New tire no question they are much cheaper than medical expenses. I don't fool with tires that might be a problem too much going on with them to take chance.
Bikes: SL8 Pro, TCR beater
Quoted: 988 Post(s)
Liked 584 Times
Just trash it and buy a new one. I don't mess with safety, especially with the only two things on my bike that touches the ground.
Likes For eduskator:
Likes For RiceAWay:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2579 Post(s)
Liked 5,636 Times
Trash it. Don’t risk your life or serious injury to save $30.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 5224 Post(s)
Liked 3,581 Times
Quoted: 6193 Post(s)
Liked 4,808 Times
The cords of the casing are where the strength is. So if they are damaged, then you've lost some amount of safe no matter what you do.
For the most part, the rubber material is just for traction and protecting the casing.
If the rubber was where the strength was, we'd be just riding on inner tubes.
Liked 8,925 Times
Quoted: 4559 Post(s)
Liked 2,802 Times
If the tire case is still good, I'd use a glued tube patch on the inside of the tire as a more-or-less permanent boot. And I'd keep an eye on it to watch for avulsions and imminent failure. I've done that when a tire was cut during a ride and the tire was still fine weeks or months later.
BTW, don't Google "avulsion" unless you have a strong stomach.
Likes For canklecat:
OM boy
Bikes: a bunch
Quoted: 514 Post(s)
Liked 642 Times
fast deflating flat on any downhill ??? bbrrrrr.... front or rear, ugly idea... of course, you only ride on closed courses... little bit O skin, will heal...
Likes For cyclezen:
