Perhaps vintage is not the best choice
Well, after a ride yesterday I went to move the bike into the garage and noticed that the seatstay has snapped on the drive side near the top tube/seat tube junction and on the other side the stay separated from the frame at the weld contact point. The snapped portion was definetely the tube and not the weld. I'll get some photos up soon. It's a good thing it happened near home, I presume. This means, as of right now NO BIKE to ride.
This is the 3rd old mountain bike frame I've had fail thus far and I'm thinking going with of something newer now, perhaps with less metal fatigue. These old mountain bike are good in the sense that they are robust (for most) and are relatively inexpensive (definetely a bonus). It has come at a bad time (end of season) and I was about to prep this bike for winter duty. I'll have to build up that Maruishi frame now (see sidebar). I'm not rough on bikes; strictly pavement, no curb jumping etc. A trailer is a pain. The rider is not overly heavy (6'4". 210). But, I do haul on them and yet nothing outside of what they should be able to handle. Bit of a puzzler there.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Likes For hose:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Quoted: 1324 Post(s)
Liked 927 Times
I had a bicycle that I was riding one night and thought that I had got a flat in the rear wheel as the bike suddenly felt squirmy. I got off the bike and felt the rear tire and it was hard. SO I figured maybe loose hub cones or broken axle. I pulled on the wheel. Wheel felt fine but moved a bit. Shone my headlight on the frame and saw this. Both seatstays had torn off the seattube. Sometimes bike frames just wear out.
Cheers
Cheers
Likes For hose:
I’m a little Surly
Quoted: 698 Post(s)
Liked 1,292 Times
I like my Karate Monkey a great deal, you can put on together fairly cheaply if you have a parts bin
Quoted: 4494 Post(s)
Liked 6,300 Times
Many things are possible, top of the list for me would be climate and location or just plain old bad dumb luck.
If you are near a MTB hot bed or coastal salt, humidity, those could be key factors, if not then hard to say.
Very strange IMO.
Likes For merziac:
Quoted: 767 Post(s)
Liked 1,897 Times
Best choice? Eh, maybe, maybe not. It sucks that those have been your experiences for sure. But one can find plenty of examples of much newer stuff that has failed, regardless of material.
Might not be worth it to some, but a competent welder or frame builder can repair a lot of these failures. I have a 48 year old frame here that had a hole worn into the inside left chainstay from rubbing. I had a local welder fill it in. Cost me $35. Good for another 48? Maybe?
Quoted: 1629 Post(s)
Liked 814 Times
I always wondered why most steel bikes just seem to have the smallest area of brazed or welded unterface between the seatstay ends and seat lug, being that there's a lot of weight shifting around there that would flex those joints constantly while riding.
The way some British bike makers wrapped and brazed the seatstay ends around the seat lug seems to make a lot of sense, because of this.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
Randomhead
Liked 3,664 Times
Back in the '70s, I used to reattach seat stays and brake bridges pretty often. But I'm pretty sure it was only on cheap bikes. Usually lower-end French bikes.
Likes For unterhausen:
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
Maybe time to try mass-produced aluminum. I've always had a theory stiff, alloy frames last longer with trailers than steel.
Quoted: 3449 Post(s)
Liked 2,800 Times
I was expecting to see one of those infamous Trek's with the investment cast top eyes and too little material.
From the appearance the tube failed, but from the rust there was fair warning if you had been watching.
While just a closeup, the bike appears quite weathered and not paid attention to, if cleaned often where problems might show up with inspection.
It has a rack, no idea on your mass and or how much load the rack sees.
Riding style too. Some guys just ride "heavy" never lift their weight off the saddle when an abrupt change in road surface. pothole, driveway apron with 1" lip up is encountered.
Liked 2,800 Times
Likes For repechage:
Cheers
Cheers
Quoted: 18320 Post(s)
Liked 4,489 Times
Photos will be interesting. The construction of many bikes is to have a seat stay cap that is about 1" long or so. Thus you may have a joint an inch or so below the end of the seat stay.
Quoted: 2332 Post(s)
Liked 2,094 Times
Well, not doubting your program but something odd going on here, if you've broken 3 bikes. I would bet less than 1% of the members, bikes, etc, whatever have had a frame failure.
Very strange IMO.
Very strange IMO.
Liked 927 Times
What surprised me was that I was able to continue on to the store I was going to and then ride home. I guess I could have had those brazed back on but I just scrapped the frame instead.
I have a 1980's Miele rigid frame/fork MTB that I've converted to a dropbar and V-brakes and it's still going strong even when loaded.
I guess that broken frame of mine was just bad luck. It's the only frame of mine that has broken.
Cheers
Cheers
Likes For Miele Man:
Liked 6,300 Times
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
That can be fixed fairly easily from the looks of it:
Bicycle Frame Seat Lug Repair at Yellow Jersey
Typical Seatstay Repair at Yellow Jersey
Yellow Jersey has a dozen more pages of this stuff.
Liked 4,489 Times
Over the last 20 years or so there has been more emphasis on oversized tubes and shaped tubes. Plus gusseting. Likely some manufacturers have taken failures to heart and have taken steps to make their frames stronger and better.
Keep in mind that while cycling has been around since just before 1900, the MTB craze is relatively recent, with the big boom in the 80's and 90's.
Early MTBs highly resembled road bikes with fat tires. And, likely through a lot of trial and error, those models have highly evolved.
Of course the old MTB frames may be dirt cheap so you could go through quite a few $50 frames before you pay for a $1000 frame.
Liked 2,800 Times
There was one customer of the bike shop who could break anything, 280#, never lifted his weight off the saddle, under-inflated tires, dented lots of rims too.
Today, he would be best on a fat tire bike.
Liked 6,300 Times
Heavyweights get a bit of a pass but they are the ones that would benefit most from these strategies.
And we can't always be proactive, gonna miss one or misjudge one once in awhile but again, riding light in the saddle can save you from them often.
Likes For merziac:
The Elkhorn (subject bike) has always been used on flat terrain for the time I've ridden it. In fact, I haven't even put that many miles on it myself. I'd bought the frame, built it up and had it sit as standby in case I needed an extra. I was going to use the Elkhorn as the main 3 season bike, and the other (a BRC) as the winter ride. But, last fall the BRC failed so this Elkhorn was called into winter duty. I've used it one winter. I also treat my frames to Rustcheck spray from the inside, and spot treat bare surface metal. Messy, but it doesn't rust. I'll have some photos of the Elkhorn damage up tomorrow. I think this situation could be welded or brazed back into place no problem. I see so many bikes built with basically just an apparent tacking of the seatstay to the seat tube. Elegant looking, but maybe something a little more robust with more surface area contacted would be better.
