Replacement Hoods Shimano please help
Old 10-25-21, 03:32 PM
bikemike73
Quoted: 211 Post(s)
Liked 199 Times in 147 Posts
Hi
I measured the hoods that are on the bike now and are 3 inches long by 2 inches wide.
Cane creek measures at 4 inches in length.
Is there any other replacement hoods the size I need 2 x 3 ??
These are for a Univega Nuovo Sport.
Late 80s I'm guessing
Appreciate any and all help
Few pics attached
bikemike73 is offline
Old 10-25-21, 03:41 PM
bikemike73
Quoted: 211 Post(s)
Will these work **********
https://www.ebay.com/itm/12336813906...BoCxesQAvD_BwE
Old 10-25-21, 05:01 PM
daverup
daverup's Avatar
Bikes: A bunch of old bikes.
Quoted: 277 Post(s)
Liked 857 Times in 413 Posts
I'll bet these will work,
https://velo-orange.com/products/dia...4-brake-levers
daverup is offline
Likes For daverup:
Old 10-25-21, 05:29 PM
smontanaro
Bikes: many
Quoted: 1439 Post(s)
Liked 1,377 Times in 755 Posts
I have a pair of the early SOMA hoods on my Univega (Shimano 600 levers - almost certainly not what it was originally equipped with). They were a bit loose. I wound up wrapping a couple layers of bar tape around the lever bodies. Still not perfect, but pretty decent.
I also don't know if SOMA redesigned them. I bought mine right when they first came out. YMMV
smontanaro is offline
Old 10-25-21, 10:54 PM
SurferRosa
señor miembro
SurferRosa's Avatar
Bikes: '70s - '80s Campagnolo
Quoted: 3854 Post(s)
Liked 6,448 Times in 3,188 Posts
Originally Posted by daverup
I agree, but, with shipping, it's probably less expensive on eBay:
https://www.ebay.com/itm/11204203861...YAAOSwBRdcf-eC
https://www.ebay.com/itm/15452164022...gAAOSw-ARg5V45
SurferRosa is offline
Old 10-26-21, 03:30 AM
plonz
plonz's Avatar
Quoted: 654 Post(s)
Liked 466 Times in 300 Posts
If the trash bin is the alternative, I’d scrub them with acetone. I’ve had white hoods like those clean right up. Surprisingly didn’t turn them to goo or dry them out. Not recommended for routine hood cleaning but worth a shot.
plonz is offline
Old 10-26-21, 06:58 AM
bikemike73
Quoted: 211 Post(s)
Thanks surferosa and all the other responses.
I ordered the ones from the Ebay link.
Very much appreciated
Stay/be safe my friends 🚲🚲🚲🚲🚴‍♂️🚴‍♂️🚴‍♂️🚴‍♂️🚴‍♂️🚴‍♂️🚴‍♂️
Old 10-27-21, 06:39 AM
pastorbobnlnh
Freewheel Medic
pastorbobnlnh's Avatar
Quoted: 1451 Post(s)
Liked 2,183 Times in 960 Posts
As an alternative, try cleaning with a Mr. Clean Magic Eraser sponge. Not as caustic as plonz 's suggestion about acetone, IMO. Your original, ones, while dirty, do look to be in good shape.
Bob
pastorbobnlnh is offline
Old 10-27-21, 06:45 AM
bikemike73
Quoted: 211 Post(s)
Thanks pb and others who suggested the Mr. Clean
I ordered the m Mr. clean eraser sponge the other day and will try that.
If it works...that will be great, I'll have the new hoods as back -up
Old 10-27-21, 09:31 AM
jdawginsc
Edumacator
Quoted: 2427 Post(s)
Liked 3,084 Times in 1,944 Posts
I have done this as well, and as long as it is not something funky staining it (certain oils/tar/grease), it works decently well. I've also had some success with simple green.
jdawginsc is offline
Old 10-27-21, 11:24 AM
RustyJames
Quoted: 561 Post(s)
Liked 1,038 Times in 538 Posts
I cleaned up a set of white Hunt-Wilde style grips with regular ‘ol dish soap, warm water and a toothbrush. It worked great! I did the same with the grips on my 55 year old Raleigh Sport and same great result. Simple Green would probably work as well if not better.
RustyJames is offline
Old 10-27-21, 11:52 AM
mprince
Dont fix whats not broken
Bikes: Steelman Stage Race, Dura-Ace 9s
Quoted: 95 Post(s)
Liked 166 Times in 93 Posts
I've used scrubbing bubbles (bathroom cleaner) and an old toothbrush on white hoods in the past with good results.
mprince is offline
Old 10-27-21, 12:57 PM
bikemike73
Quoted: 211 Post(s)
UPDATE!!!!!
I used the Mr. clean eraser.
2 sponges fell apart....
This did not work for me.
I will use a toothbrush....
I used this a few years ago but left the hoods sticky.....
Old 10-27-21, 01:12 PM
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 10392 Post(s)
Liked 11,844 Times in 6,062 Posts
Originally Posted by bikemike73
UPDATE!!!!!
Talcum powder. I use it on my gray Sante hoods every so often.
genejockey is offline
Old 10-27-21, 01:56 PM
noobinsf
noobinsf's Avatar
Quoted: 1088 Post(s)
Liked 1,204 Times in 700 Posts
I had good luck on some old white hoods using mild dish soap and Bon Ami (gentle) abrasive cleaner. A small can of it should cost under $1 at Target.
See starting on post #50 here, on page 3: https://www.bikeforums.net/classic-v...t-night-3.html
noobinsf is offline
