SRAM campy compatibility
Old 09-17-22, 02:57 PM
luke55
Has anyone tried to use the SRAM yaw front derailleur with any other shifter than sram.Just wondering if a campy escape ergo might work I believe it has no trims just up or down like friction.Curious but reluctant to buy and have it fail.
luke55 is offline
Old 09-17-22, 07:58 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1918 Post(s)
Liked 2,832 Times in 1,449 Posts
Why?
ETA: No, haven't ever thought to try it.
ETA2: This is a mechanical question and should be posted in the proper section, not GD.
cxwrench is offline
Likes For cxwrench:
Old 09-17-22, 10:44 PM
veganbikes
Clark W. Griswold
Quoted: 3162 Post(s)
Liked 2,424 Times in 1,610 Posts
SRAM made some of the most hated front derailleurs on the planet so bad that even SRAM said yeah 1X is better because they with all their engineers and money couldn't solve the problem.
Not sure why you would want to mix SRAM and Campy. The only real good part from SRAM is their single speed brake levers and I guess S-group compatible chains and cassettes but beyond that I wouldn't want to run their drivetrain bits except maybe AXS and only because Di2 right now has been a bit tough to find and the new mountain stuff hasn't come out in Di2 not that I really want 12 speed as I am fine with 11 but I know that is less likely to happen.
If I were going to own Campagnolo stuff I would use the complete groupset or if using rim brakes I would go with eeBrakes but I would do that with Shimano as well. I wouldn't want to mix and match unless it were some sort of odd adaptive situation but I cannot think of one that would need to mix Campy and anything.
veganbikes is offline
Likes For veganbikes:
Old 09-18-22, 11:18 AM
luke55
Originally Posted by cxwrench View Post
Why?
which section do you suggest I will repost.
luke55 is offline
Old 09-18-22, 12:30 PM
alcjphil
alcjphil's Avatar
Quoted: 1536 Post(s)
Liked 1,212 Times in 722 Posts
If you are asking about bike mechanics there is a specific sub forum for that. That is not to say that you won't get some good answers here, but you may get more in the bike mechanics sub forum. You can also ask the moderators to move this question. They are very good about helping you out with that. In fact, that would be the best solution. Asking the same question in multiple sub forums is not encouraged
alcjphil is offline
Old 09-18-22, 12:43 PM
luke55
Thank you very much I am new to forums can you help me with how to contact moderators to move question to proper forum.
luke55 is offline
Old 09-18-22, 02:40 PM
cxwrench
cxwrench's Avatar
Bikes: lots
The way to get your thread moved is to report it and ask.
cxwrench is offline
Old 09-18-22, 03:55 PM
rosefarts
With a mighty wind
Quoted: 839 Post(s)
Liked 562 Times in 337 Posts
A lot (all?) older Campagnolo front shifters are up or down, so it should work.
Nobody has tried it, because it’s a weird idea.
rosefarts is offline
Old 09-18-22, 07:00 PM
luke55
just curious got a good deal on a sram red 22 crankset all other drive train components are campy record.Original crankset is campy record 34/50 and shifts like an old 1970 friction set up terrible. Just thought a new red yaw mech might be what the Dr.ordered unconventional but Maybe highly functional.
luke55 is offline
Old 09-19-22, 06:17 AM
bluehills3149
bluehills3149's Avatar
Bikes: depends what week it is..
Quoted: 136 Post(s)
Liked 53 Times in 41 Posts
I use Sram yaw on my Campy 10 spd shifters - Veloce utrashift 10spd which were same shape as the first gen 11 spd. Cranks are 10spd Campy compact. Shifting is fine but it takes a decent shove on the lever.
bluehills3149 is offline
Old 09-19-22, 07:18 AM
rosefarts
With a mighty wind
Quoted: 839 Post(s)
Something is set up wrong. It should shift fine.
Old 09-19-22, 07:29 AM
luke55
Thank you very much thought it might work ,nothing is worse than unpredictable front shifting especially in a race.Want to be loyal to campy but if it doesn’t work have to improvise.
luke55 is offline
Old 09-22-22, 11:15 AM
DMC707
DMC707's Avatar
Bikes: Too many to list
Quoted: 1691 Post(s)
Liked 987 Times in 661 Posts
Something is wrong with your setup. My 1991 era Campagnolo Record setup shifts better than modern SRAM
DMC707 is offline
Old 09-22-22, 12:57 PM
BillyD
Administrator
BillyD's Avatar
Quoted: 10230 Post(s)
Liked 4,228 Times in 2,344 Posts
Don’t worry about it, this forum is a good place to start in this case.
BillyD is offline
Old 09-22-22, 01:32 PM
luke55
Yes something is definitely wrong even the Campy techs are confused.Just for kicks I borrowed a matching set of 50/34 sram power glide rings ,shifts like a dream . Set it back with the campy rings and same old sluggish terrible shifting ,a real deal breaker in a local crit.
luke55 is offline
Old 09-22-22, 03:24 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Hilly crit? Where is it?
cxwrench is offline
Old 09-22-22, 04:11 PM
luke55
yes indeed Santa Ynez Valley near Solvang Cal.
luke55 is offline
Old 09-22-22, 04:51 PM
luke55
another real favorite is in Park City Utah I remember back in the day riding with Levi on that one .What an incredible climber he was .
luke55 is offline
Old 09-22-22, 09:07 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Nice! I've ridden down there a little bit, very cool spot.
cxwrench is offline
Old 09-22-22, 10:19 PM
rosefarts
With a mighty wind
Quoted: 839 Post(s)
So you actually already solved the problem without realizing it. Something is wrong with your chain rings. Worn shifting ramps, generic with no ramps, totally worn out, something.
This experiment proved the derailleur is fine and you need new rings.
Follow that rabbit hole, not the derailleur that seems quite capable of “shifting like a dream”.
Likes For rosefarts:
