How far to ride Tubeless Tire plugs?
Curmudgeon
Bikes: Specialized Diverge Comp
Quoted: 157 Post(s)
Liked 32 Times
I have a puncture in my tubeless road tire. It will be days or weeks until my replacement order arrives. I have STANS tubeless plugs. Are plugs general good for hundreds of miles or general only meant as an emergency repair for short distances?
Quoted: 6959 Post(s)
Liked 10,960 Times
Sounds like you're gonna be riding it...So perhaps you can come back and give us the answer.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
What's the advantage of tubeless if the plugs aren't a permanent fix for punctures?
Likes For JohnDThompson:
Quoted: 896 Post(s)
Liked 2,063 Times
So YMMV.
Likes For downtube42:
Quoted: 4201 Post(s)
Liked 3,856 Times
My answer is sort of a non answer. Plugs work well till they don't. Assume you can tide a plugged tire till it leaks from the plug again. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Liked 10,960 Times
JusJohnDThompson 's post with new eyes, and am wondering if he was posing a rhetorical question. If so, my apologies!
Likes For Koyote:
Liked 2,966 Times
Question: Are tubeless plugs a permanent solution when addressing a flat tire?
Answer: It really depends on the plug and puncture, sometimes they will last for the life of the tire, and sometimes you'll see them start to leak again when you refresh the sealant. Generally our Dart tool and plugs are the longest lasting, as they actually react with the sealant & form a solid plug of sealant around the actual insert.
Question: Would it be ok to treat the plugged tire no different than if it were never plugged as long as there are no leaks from the plug insertion area?
Answer: As long as it isn't leaking &the plug is secure, than yes it is no different than an intact tire.
Answers were from: Isaac Smith at notubes
-Oh Hey!
-Oh Hey!
Likes For Troul:
Quoted: 2026 Post(s)
Liked 1,096 Times
Installed properly, a plug should last until the rest of the tire wears out. As JohnDThompson noted, If a plug isn't a long-term fix, why bother? I haven't plugged a bike tire but I know from experience a car tire, properly plugged, is good for the rest of it's normal life span.
Likes For HillRider:
Liked 2,966 Times
my takeaway is, *IF* the sealant is not relatively fresh or is lacking some, then it might behooved of you to "top off" the tire with some additional new sealant at the time of inserting a plug.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Putting in a plug is a pretty rare occurrence. It's for a gash, not a simple puncture from a thorn or tire wire. Sealant alone takes care of those. If you are doing it, it's reasonably likely you are plugging damage severe enough you'd want to consider replacing it whether it was tubeless or not. The same situation where in a tube clincher tire you might use a boot (or a candy wrapper or a dollar...) And then it's not really about the sealant or leaks. It's whether or how many of the cords were cut and how you feel about that. In a MTB tire that runs at 20 psi or less you might worry a lot less. Some people even sew them up. In a road tire you are running 4x that pressure. I think I'd hit the pause button.
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
Back on the original question, yes they should last until the tire needs replacing.
LR÷P=HR
Quoted: 865 Post(s)
Liked 1,204 Times
Points system
+5 points if the type is MTB
-7 points for a road tire
+10 points if it's a rear tire
-15 points if it's a front tire
+10 points if the damage is in a good spot to repair
-30 points if it's in a bad spot for a repair
-1000 points if you can afford to just replace the tire and move on
+5 points if it's a little hole and the sealant has chosen not to to cooperate today.
Unless you only maintain & top off the sealant after it's all gone and you flatted. then +Tubes for you!
-15 points if it's a big hole and you should know better.
Come on... What did I miss
Barry
Quoted: 836 Post(s)
Liked 1,061 Times
IMO I would just put a proper tubeless patch on the inside and be done with it. No worrying if it's going to fail. Plugs are great for roadside repairs though.
Likes For Crankycrank:
Maybe a patch to reinforce it? I had a little gash in my tire in this thread. It had one of those little sticky patches on it which got me home. I've since replaced it with a patch from a Park VP-1 kit... it's the best I could find that was available locally. They're not tubeless specific but certainly beefier and I wanted something with a vulcanizing adhesive. So far so good.
Likes For Ryan_M:
Likes For Atlas Shrugged:
ignominious poltroon
Quoted: 2238 Post(s)
Liked 3,430 Times
A couple of days ago I rolled over a mass of white chewing gum about 3 miles into a 52 mile ride. I stopped twice to scrape it off as best as I could, but it was incredibly adhesive. Maybe instead of a tire boot, we should carry some chewing gum. Tire goes flat and sealant doesn't do it? Just chew on a stick of gum for 5 minutes, pull it and any fillings out of your mouth, and jam it into the hole from the inside. Maybe that plus a plug would last indefinitely.
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
Likes For vespasianus:
Quoted: 222 Post(s)
Liked 303 Times
I've had the basic bacon strip plugs work themselves out before I could finish the ride. I'm sure the effectiveness varies with source and perhaps age of the material. I switched to Dyna plugs, and they have worked until the tire is worn out. For leaks that don't seal well, but I don't need to plug to complete the ride, I remove the tire and apply a common inner tube patch to the inside of the tire at the leak. These also last until the tire wears out.
Likes For Mtracer:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Liked 3,430 Times
This kind of thing seems to happen whenever I put on some new $$$$ Rene Herse tires.
When I first heard/felt/saw it, it was this big blob of white rubbery crap, and I thought "oh, I must have had a puncture" and then I realized there was no possible way that was Panaracer sealant.
