Squeaky rear derailleur under force
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
I think my rear derailleur is squeaking. It only happens under stronger forces, like 8% grade pedaling. I thought it was my bike shoes/cleats but I lubed that to no effect and it seems like the sound is coming further back. It is much more pronounced on my right stroke which made me think it was the shoe/pedal on the right side.
Anyway the next thing I was going to try was to clean/lube the jockey wheels. Any other suggestions? The chain is new and recently lubed.
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
Yep, something else. When the RD wheels need lube, they squeal during a shift.
Do you get the noise when you're out of the saddle?
How loud is the squeak?
I recently chased down a squeak that dissapeared when I got out of the saddle.
It was my shorts on the saddle.
Looking for noises can be a proper rabbit hole.
I like bike
Quoted: 267 Post(s)
Liked 283 Times
EDIT: chain ring bolts were surprisingly loose.. just tightened them and about to commute home to test..
I like bike
Quoted: 267 Post(s)
Liked 283 Times
OK the verdict is in .. chain ring bolts! It was completely silent up all the hills. Thanks Clyde it would have taken me a long time to get to that point at the rate I was going.
Likes For scottfsmith:
I like bike
Quoted: 267 Post(s)
Liked 283 Times
Um .. gotta roll that back. I only had 6% max hills going home, the 8-12% are on the way in to work only. It was squeaking again this morning. But, I did notice that it only happens in the biggest ring in back, shift one gear over and total silence. I was not noticing this before as I am always in the biggest ring on 8+% hills.
I think the limit screw may need some adjusting, not sure why it is squeaking from that but I can't see what else could be the cause. The chain looked like it might not have been perfectly centered on the teeth so I tightened the screw a bit to get it centered. If this doesn't do it I will take apart the cassette, and lube and re-install the rings. Other suggestions welcome..
Quoted: 2604 Post(s)
Liked 1,932 Times
It's probably worth the time to remove and regrease the pulleys, though I can't see how that would affect only the right stroke. My next guess would be a hassle; your bottom bracket may be wearing out.
To paraphrase Click and Clack (the Tappet Brothers), turn up the radio and keep riding. If it's the BB you'll find out soon enough!
Licensed Bike Geek
Slightly lube the pivot and contact points of your rear skewer. There’s a lot of torque/pressure on those when applying your massive power <grin> and often can result in noises.
I like bike
Quoted: 267 Post(s)
Liked 283 Times
EDIT: Yes that was it, did several steep hills with no squeaks. Check that off my list! Thanks for all the suggestions.
