What uses more energy, climb up a hill fast or climb slow??
Old 07-18-22, 05:36 AM
koala logs
Quoted: 347 Post(s)
Liked 166 Times in 136 Posts
Note we're discussing energy, NOT power. Joules vs Watts
And for the sake of simplicity, we'll ignore aero drag, ignore rolling resistance and all other sources of friction on the bike including losses due to cycling technique. Thanks.
I've been thinking lately if climbing slowly isn't doing me any favor in long rides especially when I'm trying to be home before the sun is straight up and before temperatures climbed to 100F.
koala logs is offline
Likes For koala logs:
Old 07-18-22, 05:47 AM
seypat
Quoted: 2524 Post(s)
Liked 1,580 Times in 1,022 Posts
I'm not going to pay a toll to cross your bridge. Not gonna do it.
seypat is offline
Old 07-18-22, 05:49 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4278 Post(s)
Liked 1,243 Times in 818 Posts
Play with this calculator. Seems to suggest that higher efforts, despite shortening the time significantly, use overall more kilojoules.
Bike Calculator
Sy Reene is offline
Old 07-18-22, 06:04 AM
koala logs
Quoted: 347 Post(s)
Bike Calculator
My browser is denying me access to that link, it said, "unsecure".
How much difference are we talking about. Say, comparing a climbing speed between 6 mph and 12 mph up a 5% gradient?
Old 07-18-22, 06:40 AM
scottfsmith
I like bike
scottfsmith's Avatar
Bikes: Roubaix Comp 2020
Quoted: 210 Post(s)
Liked 217 Times in 142 Posts
If you read your original question the temperature is a major issue, and there is a constant energy spent just to stay cool. Also going faster will in fact make it easier to stay cool, a couple mph of wind on a hill is still better than standing still. So my guess is that in your 100F heat a reasonably fast pace could be better than a slow pace just due to energy for cooling issues.
If the temperature was something non-hot things would be pretty close and probably some experiments would need to be done to see which factor dominates. There is a constant power needed to "run" the body just sitting on the bike, the efficiency of the human energy system at different levels of exertion is surely non-linear, it takes more effort to stay balanced on the bike when going slower, etc etc etc.
scottfsmith is online now
Likes For scottfsmith:
Old 07-18-22, 07:11 AM
koala logs
Quoted: 347 Post(s)
Looks like there are more items in favor of going faster.
Old 07-18-22, 07:12 AM
Quoted: 16067 Post(s)
Liked 10,507 Times in 5,109 Posts
African or European hill?
indyfabz is online now
Old 07-18-22, 07:33 AM
Daniel4
Bikes: Sekine 1979 ten speed racer
Quoted: 1323 Post(s)
Liked 478 Times in 319 Posts
If you ignore all types of friction and resistance, in ideal conditions, they both use the same amount of energy. It's simply the change in mgh.
Daniel4 is offline
Likes For Daniel4:
Old 07-18-22, 07:52 AM
dmark
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 142 Post(s)
Liked 128 Times in 92 Posts
...carrying coconuts?
Last new bike 1991
dmark is offline
Old 07-18-22, 07:57 AM
pdlamb
Quoted: 2022 Post(s)
Liked 1,270 Times in 808 Posts
Not quite. Climbing faster will result in more aerodynamic drag, so it'll take more energy. Of course, that's down in the near negligible range for most climbers.
Of course, you could make the counter argument that riding slower and sweating a lot will result in lower mass being lifted toward the end. But somebody's gonna have to buy me a beer before I waste any more time on this navel-gazing exercise.
pdlamb is offline
Likes For pdlamb:
Old 07-18-22, 08:18 AM
Germany_chris
Iím a little Surly
Germany_chris's Avatar
Bikes: Two Cross Checks and a Karate Monkey
Quoted: 518 Post(s)
Liked 923 Times in 479 Posts
No, Bratwurst and Brotchen
Germany_chris is offline
Old 07-18-22, 08:20 AM
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 6570 Post(s)
Liked 6,915 Times in 3,541 Posts
How long is a piece of string?
genejockey is offline
Old 07-18-22, 08:47 AM
Outrider1
Outrider1's Avatar
Bikes: Trek Emonda ALR 5, Motobecane Cafe Disc Comp
Quoted: 98 Post(s)
Liked 192 Times in 87 Posts
Where would he grip them?
Outrider1 is offline
Likes For Outrider1:
Old 07-18-22, 08:57 AM
Iride01
MotuekaCascadeChinook
Iride01's Avatar
Quoted: 4673 Post(s)
Liked 3,170 Times in 2,211 Posts
Can you keep 14 mph or better going up the hill? If not, you are going to get hotter on a hot day. So you might need to pedal one of the easier gears you have. But if you know you can bust a gut getting to the top without risking heat exhaustion then go for it so you can get some cooling going down the other side.
Your hill might not be my hill.
Iride01 is online now
Old 07-18-22, 09:33 AM
Razorrock
Bikes: Litespeed
Quoted: 81 Post(s)
Liked 31 Times in 20 Posts
You haven't mentioned gears. I would think doing the same RPM in your bottom gear or a couple gears up would result in the latter being more efficient. Grinding up in the granny gear has never felt like the best option for me unless I'm just spent and have no other option.
Razorrock is offline
Old 07-18-22, 09:38 AM
70sSanO
70sSanO's Avatar
Quoted: 1723 Post(s)
Liked 1,805 Times in 1,119 Posts
Are we talking about ebikes?
John
70sSanO is online now
Likes For 70sSanO:
Old 07-18-22, 09:57 AM
tomato coupe
Quoted: 2261 Post(s)
Liked 3,913 Times in 1,583 Posts
No. To simplify the discussion, we're only considering massless and frictionless bikes ridden in a vacuum by Vestal Virgins.
tomato coupe is offline
Old 07-18-22, 10:05 AM
asgelle
Quoted: 920 Post(s)
Liked 360 Times in 219 Posts
If, for the sake of simplicity, you ignore all speed dependent terms, speed doesn't matter. Happy?
asgelle is online now
Old 07-18-22, 10:08 AM
70sSanO
70sSanO's Avatar
Then the answer is reading this thread takes more energy than it is worth.
John
tomato coupe
You haven't considered the terms that depend on the illusion of speed.
Old 07-18-22, 10:12 AM
tomato coupe
This thread exists in an intellectual valley, so it doesn't take any energy to descend into it. Unfortunately. it takes a lot of energy to leave the Valley.
Old 07-18-22, 10:16 AM
himespau
himespau's Avatar
Quoted: 3439 Post(s)
Liked 2,192 Times in 1,298 Posts
Pushing harder on the climb and less hard on the flats causes you to expend less energy for a given average speed than pushing the same consistent effort throughout.
himespau is offline
Likes For himespau:
Old 07-18-22, 10:36 AM
70sSanO
70sSanO's Avatar
Very true.
My doctor has warned me about long BF, especially the General Cycling Discussion variant.
John
Likes For 70sSanO:
Old 07-18-22, 10:38 AM
terrymorse
climber has-been
terrymorse's Avatar
Bikes: Scott Addict R1
Quoted: 1401 Post(s)
Liked 1,254 Times in 669 Posts
Assume a spherical cyclist in a vacuum.
Ride, Rest, Repeat
terrymorse is offline
Likes For terrymorse:
Old 07-18-22, 12:06 PM
livedarklions
High Performance Noodler
livedarklions's Avatar
Quoted: 7106 Post(s)
Liked 7,221 Times in 4,048 Posts
That's no fun. I'd rather assume a toroidal cyclist in a blender.
livedarklions is offline
Likes For livedarklions:
