Zwift KOMs are Ridiculous
#51
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I just assumed that nobody would ever take Zwift KOMs even slightly seriously.
#52
climber has-been
Quoted: 3427 Post(s)
Liked 3,563 Times
The counter argument are the other riders [i.e., your truly] whose first impression of Zwift are the ludicrous KOM numbers, who then dismiss Zwift as a non-serious toy game.
#53
Perceptual Dullard
Quoted: 918 Post(s)
Liked 1,149 Times
Yes, this is what I'm saying. They could at least make a minimum effort to flag the ridiculous speeds. Just look at the Strava leader board for the Hilly KOM Forward segment. Page after page of impossible 28+ mph speeds, all with sensible power numbers. A simple filter would flag those with "nobody can go that fast with that little power".
#54
Perceptual Dullard
Quoted: 918 Post(s)
Liked 1,149 Times
WRT 8 or 12 strain gages, you would only have to modify 2 or 3 since they are in pairs of 4 to form a wheatstone bridge. Adding the appropriate resistance in series to each bridge should get the cheater's job done. I've never disassembled, so, this could be all rubbish but I do know there are wires from the PT electronics into the shell where the strain gages are mounted. Many modern smart trainers do not use strain gages. In any case, few have the inclination or knowledge to monkey around at that level. I'm probably wrong and just not willing to mess around with one of my PT hubs, they are too valuable.
#55
climber has-been
Liked 3,563 Times
It should not be so difficult for Zwift to filter out the junk before it releases ride data to Strava.
#56
Habitual User
Quoted: 4944 Post(s)
Liked 8,085 Times
Let your needs dictate what Zwift is. Just because you can up your pace to draft a passing rider, go for a sprint/KOM, or use some of the more game-y features, doesn't mean you have to.
Likes For Eric F:
#57
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
Yes. I set it to around 25-35% on long climbs, and can sit and spin all the way up. With low watts, I'm still spinning instead of mashing slow cadences -- then my road speed can be down to 2 mph quite easily. Riders never fall over on Zwift.
Kickr trainer resistance is quite different from climbing in real life. It's continuous resistance all around the pedaling circle. Out on the road, there's way less resistance in parts of the pedal rotation, with momentum of the bike+rider carrying through that brief amount of time. On the trainer, these higher cadences are much easier on my knees.
The Kickr has improved my pedal stroke out on real roads, I think.
#58
Bikes: yes, i have one
Quoted: 1136 Post(s)
Liked 1,182 Times
but do you really need to mess around at that level? being a developer i can think if a much easier way to cheat. of course that assumes that the configuration is very similar to mine at home with respect to the wireless bits.
#59
Liked 1,182 Times
its not just zwift. i'm not using it anymore but i recall taking some hair pin turns at well over 40 mph that in real life would have put me in an ambulance or a coffin. of everythign i've tried only RGT put on the brakes during the ride. even rouvy appears to have a top speed of something like 44.7mph.
#60
Perceptual Dullard
Quoted: 918 Post(s)
Liked 1,149 Times
There *are* much easier ways to cheat -- what's hard is doing it in a way that's hard to detect. I don't want to reveal too much, but years ago (way before there was a Zwift) a guy who didn't believe me made several copies of a power meter data file and altered all but one of them (i.e., there was an original version and several altered versions) and sent them to me. It took a little bit of effort but not a lot to figure out which was the original unaltered file. I wouldn't want to do that for thousands or tens of thousands of files but if there was a suspicion about a particular user and someone was paying for my time, it could be done.
#61
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,896 Times
I'm curious what the cheat is that allows SO MANY riders to ALL do it in 1:11 at 28.4 mph. According to Bike Calculator, a 100 lb rider on a 16 lb bike would have to put out 700w.
#62
Quoted: 1461 Post(s)
Liked 1,481 Times
Zwift has 17 pages of rules that lay out all of the protocols for high level e-racing. I have no idea how we're 60 posts into this thread and people are still talking about how easy it is to cheat on Zwift without having any knowledge of how difficult it actually is.
Are Zwift riders cheating on KOM's and in unregulated races? Probably. The same happens with Strava KOM's. I see local segments near me all the time with KOM's that are clearly recorded from a car, or an e-bike, motorized scooter, etc. Using this to dismiss all e-racing as cheating would be no different than assuming PGA players are shaving strokes off their scorecards because your buddy uses a foot wedge and calls anything within 5ft of the hole a "gimme".
- Racers are required to submit power verification tests completed prior to the race, along with heart rate and cadence data.
- Racers are required to register an eBioPassport account that tracks all of their power numbers over time, so any wild fluctuations would be easy to spot
- Zwift and USA Cycling both have committees to monitor and analyze performance data during races, so anything inconsistent with a rider's previous efforts would immediately be flagged for review.
- Racers are required to submit videos of weigh-ins/height measurement and power verification tests.
- Racers are required to record power data with two different sources - direct drive trainers (from an approved list) as the primary source, and power meter as a verification/backup. Calibration of both has to be done on video as part of the power verification process.
- All verification and race data is also all made public so anyone can look at this.
- For Zwift races - smart trainer difficulty must be set to at least 50%.
- Power verification data has to be submitted within 6 months of an event, and all equipment has to be verified 5 days prior to an event.
Likes For msu2001la:
#63
Liked 1,481 Times
These results particularly caught my eye. Given that speed in Zwift is ostensibly a function of power output, rider mass and height, and imaginary incline, I can't see how it's possible to do that climb at 28.4 mph pushing 23w. For that matter, I don't see how it's possible to do that climb at 28.
I'd put my money on a glitch/software malfunction of some kind, rather than malicious cheating. 4 of those happened in a 4 day period. All of them in 2021?
EDIT: I didn't check all of them, but the first handful seem to be from group meetup rides. I've seen some weird stuff happen with "ruberbanded" groups on Zwift, which is designed to keep a group together regardless of how slow the slowest rider is. It's entirely possible that riders fell behind a lead rider and got pulled up this hill at a ridiculous pace as they system banded everyone back together. This probably gets weeded out of Zwift data, but not Strava. Regardless, none of this looks like malicious cheating to get a KOM. https://www.strava.com/segments/12109030
#64
Liked 1,182 Times
heck, just noticed the first guy came across dead. not bad.
#65
Liked 11,896 Times
Did you look at any of those rides? Is the entire ride suspicious or just that particular segment?
#66
Liked 11,896 Times
Yeah. Normally I don't feel dead till AFTER I cross the line.
#67
Quoted: 4233 Post(s)
Liked 2,948 Times
#68
Quoted: 6963 Post(s)
Liked 10,962 Times
#69
Habitual User
Liked 8,085 Times
#70
Liked 10,962 Times
#71
Habitual User
Liked 8,085 Times
It's just different racing. Hell, they have e-sports F1 racing. Apparently, it's kind of a big deal.
#72
Liked 11,896 Times
I'm too old to trust my bones to other people's bikehandling skills. But, yeah - it's a completely different animal from actual racing. Good exercise, and fun, though.
#73
Quoted: 4400 Post(s)
Liked 4,847 Times
#74
Randomhead
Liked 3,696 Times
only thing the zwift kom's are good for is I know on my best day I'm going to do them in about twice the time.
#75
Liked 1,481 Times
I believe it was a Zwift software bug allowing those super high speeds in some specific scenarios. I don’t know the details, but I’ve heard people discuss it before. I presume the bug was fixed long ago, but it borked up the Strava KOMs. I never experienced it first hand.
I've done a few of these, and there are definitely times where slower riders who fall behind and get gapped will suddenly get a big "push" from the software to catch them back up. It seems entirely plausible that these Strava KOM's were recorded during one of these situations.
Zwift probably filters this out and doesn't record it as a KOM in their software, but Strava didn't catch it. I don't see any new ones, so my guess is that this has been "fixed" or the rubber band feature is less abrupt than it used to be.
To be clear, I don't actually think there's anything malicious going on here. Calling this "cheating" is a massive stretch.
