‘76 Dur-ace chainring
Old 09-26-22, 02:35 PM
halfmile
halfmile's Avatar
Bikes: '76 ROMIC Touring Pro 100
Quoted: 16 Post(s)
At 73, small rises are now hills, looking to change my chainring from 46-41 to 46-?? and the cogs are 14,17,22,27,34….will I need to modify my chain length?
Thanks
Halfmile
halfmile is offline
Old 09-26-22, 03:06 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3582 Post(s)
Liked 3,394 Times in 1,928 Posts
Hard to say. Chain length is a function of gearing, derailleur capacity, and chainstay length. If your derailleur can wrap the current length with a smaller inner ring, no worries (check on small-small combination). If it can't fully wrap the chain on small-small, take a link or two out, check small-small again for wrap, if good, check large-large to be sure that you're not running the chain too short. If it is too short on large-large after cutting a link, you'll need a rear derailleur with more wrap capacity.
JohnDThompson is offline
Old 09-26-22, 03:07 PM
repechage
Quoted: 3463 Post(s)
Liked 2,826 Times in 1,994 Posts
46-34 will be the chain length primary control
I saw long ago 40t Dura Ace. Not sure on smaller
repechage is offline
Old 09-26-22, 04:06 PM
pastorbobnlnh
Freewheel Medic
pastorbobnlnh's Avatar
Quoted: 1451 Post(s)
Liked 2,183 Times in 960 Posts
If your BCD is 130mm, 39T chainrings are available.
Bob
pastorbobnlnh is offline
Likes For pastorbobnlnh:
Old 09-26-22, 04:21 PM
bikemig
bikemig's Avatar
Quoted: 5885 Post(s)
Liked 3,468 Times in 2,078 Posts
I’d run a different crank with a smaller bcd, so that you can run a 50/34 or a 46/30
bikemig is offline
Old 09-26-22, 04:59 PM
thumpism
Bikes are okay, I guess.
thumpism's Avatar
Quoted: 2647 Post(s)
I put an early DA crank on my PX10 and later put a 39 and a 45 on it to replace the stock rings but I'd want a triple these days.
thumpism is offline
