Help IDing this steel Specialized - Rasta Sequoia?
Hi,
I"m hoping some of the old heads here might be able to help me out in finding where in the world this frame came from. I picked it up today and I've been scratching my head for hours. From what I can narrow down from the serial number and 600 New EX downtube shifters, this is a 1986 model. However, since there doesn't seem to be any catalog scans from that year on the whole Internet, I've unable to verify the exact model. Signature "flag" triple crankset, Deore deer-head half-step FD, Strong seatpost, Gran Compe Royal brakeset makes me lean towards this being a Sequoia, There's some weird paint melt effects going on, likely as a result of 35+ years in LA sunshine - wondering if this is a respray, or if S really did a Rasta paintjob back in the day.
Likes For Ayyyyy:
Bikes: Bike Friday PRP, Bike Friday NWT, Bromton M6R, 1991 Miyata 914, 1991 Miyata 1000, 1986 Raleigh Portage, many more frames
Quoted: 215 Post(s)
Liked 347 Times
Certainly looks like a Sequoia, especially with the recessed rack braze-ons. More pics would definitely help. Maybe it's just me, but it looks like there might be some crash damage, judging from what looks like a ripple on the underside of the downtube and top tube. If possible, I would strip the nasty paint job to see if it really is buckled or if it's just the poorly applied paint.
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,434 Times
From the pictures, IMO, Phil is likely right about some damage. Not sure what is being shown at the IALI of the down tube decal. Is that a bad rust spot above the ZED of the same decal. I have no info on the bike itself.
Quoted: 4722 Post(s)
Liked 3,036 Times
Yes, based on the limited description that's a good match for a 1986 Sequoia. It was spec'd with Shimano New EX shift levers paired with Deore XT derailleurs (1986 would be the 1st genration, a.k.a. deer's head). The brakeset was Dia-Compe Royal Gran Compe 500 calipers with Dia-Compe Aero Gran Compe 250 levers.
Fun Fact: The images on the 1st generation Deore XT derailleurs depict the Sika deer, indigenous to Japan. The rear derailleur has an image of the male (buck or stag), while the front derailleur has an inage of the female (doe or hind). So when referring to Shimano derailleurs, it appears to be proper to refer to the rear derailler as as "he" and the front derailleur as a "she".
Likes For T-Mar:
Bikes: BMC Road V2; '17 Marin Pine Mountain 2; '91 Marinoni Special TSX; '89 Specialized Stumpjumper Comp; '98 Salsa La Cruz; '79 Centurion Pro Tour; '77 Romic custom sport-tour; '77 Centurion Semi-Pro; '23 Kona Sutra LTD
Quoted: 62 Post(s)
Liked 220 Times
Frame details & components are a match for my '86 Sequoia. The paint job looks like it was done in the early-mid 90s though
Thanks everybody, I'm now pretty well certain this was a respray. Seller is claiming ignorance of the bike's history.
I think I might turn this into a pet project - hopefully it doesn't track off-center too much with the impact damage. Ordered a replacement 46t ring, Lambda saddle, and the matching Deore RD, now to find a matching rear wheel.
The frame/fork damage doesn't seem *that* bad, and according to St. Brown it may be repairable by re-alignment rather than replacement of tubes...we'll cross that bridge when the time comes.
Likes For Ayyyyy:
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
Quoted: 4510 Post(s)
Liked 6,377 Times
Something very hinky going on here with this paint "job".
Pet project is exactly what this should be, seems like it had to be a real thing at one time. Even if not, its cool as ef and will be just plain bi***in rebooted.
Partially Sane.
Quoted: 972 Post(s)
Liked 643 Times
Sorry, not the best pic ever, I'm obviously still touring. Didn't want to completely forget, hence a bad pic is better than none. 😉
Hope I'm not bumping too far out of the past...just wanted to give an update.
I started chipping away some of the VERY thick clear coat and the black paint, only to find the yellowed original paint underneath. Luckily, it appears that the damage noted above is only paint deep and the tubes and fork blades are straight.
I found the quill stem was seized, but the nice folks over at the Bike Oven let me use their bench vice and a junk front wheel. That "POP" was pretty satisfying! I was afraid that the steerer might be bent due to the seized stem and how the headset was moving, but it's also fine - I guess 40 year old grease lubes bearings like taffy.
I'm proceeding to Jasco away the thick clear coat and the old paint - stay tuned.
Likes For Ayyyyy:
