Stronglight 49d crankset chainline.
Hello Im brand new here but I was wondering if anybody knew how to get a 42mm chainline with a stronglight 49d crankset. Ive heard somewhere in between 110-115. would it change if i used a campy bottom bracket?
Quoted: 823 Post(s)
Liked 1,395 Times
I used a Stronglight 113mm spindle with Stronglight cups with a Stronglight model 93 crankset and a single chainring to get a 42 mm chainline on a succession of fixed-gears. Getting it to work with other spindles can be a bit tricky. Currently I'm running a 113mm Phil Wood BB with French adapter rings and it works but is sub-par - I had to flip the BB around and run it with the long side on the left to get it to work. I think a 107-108 in those would work better.
The Campy will be ISO taper, if memory serves, while I think the Japanese JIS taper is closer to the old French Stronglight/T.A. pattern - but I bet someone with a copy of Sutherland's handy will chime in soon!
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
Bikes on Flickr
Quoted: 3811 Post(s)
Liked 3,336 Times
The 49D sets I have opened up which came OEM usually were fitted with the 120 spindle.
Another option for a single plateau drive is the T.A. nr. 314 spindle.
Quoted: 823 Post(s)
Liked 1,395 Times
Very timely post and glad someone alerted me to it as I asked this question to some friends this week. I have a model 93 with a track ring that I plan to use on a 50s frame in single speed mode (110mm reset to 120mm) with a standard fixed/fixed 120mm hub. I have a 113mm Shimano cartridge BB in my drawer that I was going to try. Am I reading your post correctly that the 113mm JIS taper should be about right?
Jimsl78
Classic & Vintage
5
03-30-15 09:44 PM
bbbbbbb
Bicycle Mechanics
3
09-04-10 06:43 PM
