FS: Suntour Superbe Pro Hubset Last Generation
lurking nightrider
Late 80's early 90's Suntour Superbe Pro Front and 8-Speed Rear Hub, New Old Stock. 32 Holes F/R 130mm Spacing. No Front Skewer.
sold Paypal F/F
Price includes shipping
sold Paypal F/F
"If there hadn't been women we'd still be squatting in a cave eating raw meat, because we made civilization in order to impress our girl friends. And they tolerated it and let us go ahead and play with our toys." Orson Welles
Can these hubs be used with Shimano cassettes and indexed shifting, or do they require a proprietary Suntour 8-speed cassette?
Check out www.djcatnap.com for articles on vintage Japanese & French bicycle restorations, components and history.
Quoted: 3807 Post(s)
Liked 6,676 Times
^ I have the same question. Those are gorgeous!
Edit: Looks like from the VeloBase listing that they require a SunTour Powerflo cassette?
lurking nightrider
If anyone has successfully managed to convert a Shimano cassette to work I'd like to hear how they did it.
Suntour AP cassettes are still available if you're patient. The pins that connect the cogs together as a collective can be removed so that other cogs can be swapped out. The appropriate spacers will also be needed.
Expect to pay a premium for the shifters.
Liked 6,676 Times
lurking nightrider
I have an example around here somewhere. I'll post a show-and-tell in a new thread if you are curious.
Wrench Savant
I presume that somebody, somewhere, in the last 30 years has attempted to put a Shimano freehub body on a Suntour hub. I am guessing it did not work.
Likes For balindamood:
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
No skewer?!
Last gen Suntour was about their Accushift indexing, which was not linear. The highest two shifts have a wider spacing than the first 4 (on a 7 speed cassette). Last generation also added Micro-Drive, which was a compact crankset paired with smaller cassettes where the last 2 cogs were a single piece to screw onto the freehub, rather than a single cog. I would double check the boxes to see if the hubs are listed as MD and AP, or just AP.
You can use these with the appropriate cassette with any shifter you'd like, in friction mode. For a full accushift indexed experience, you'd want at least a RD and rear shifter. FD and shifter are both friction anyway.
oooh yeah please do. i'd like to buy this set but seeing the prices for a matching cassette on ebay is scaring me off.
Quoted: 1163 Post(s)
Liked 442 Times
BTW, if the buyer of these hubs is unable to spec a set of the Accushift 7/8 speed Superbe Pro down tube indexing shift levers, they could also search for a set of the 7/8 speed Accushift "Command" paddle shifters. Both will be nearly unobtainable for years at a time on eBay but if you are patient enough, they eventually do materialize only to be snatched up pretty quickly.
The dropped
Liked 1,014 Times
I am also interested in this NOS cassette from the LBS. I took an AP 7 speed cassette and made it into an 8 speed by taking an extra cog and spacer from a 2nd one and it works well.
BTW, if the buyer of these hubs is unable to spec a set of the Accushift 7/9 speed Superbe Pro down tube indexing shift levers, they could also search for a set of the 7/8 speed Accushift "Command" paddle shifters. Both will be nearly unobtainable for years at a time on eBay but if you are patient enough, they eventually do materialize only to be snatched up pretty quickly.
Liked 442 Times
The dropped
Liked 1,014 Times
Liked 442 Times
Sorry, No.
I mean HERE. In the other sales section.
https://www.ebay.com/itm/26268972573...mis&media=COPY
This is the style I am referring to, it these are for 7 speed. Obviously, the price makes them not very interesting to me.
12-26 AP Accushift 8 cassette
The down tube levers are “SL”.
8 speed Accushift downtube levers.
Edumacator
Quoted: 2436 Post(s)
Liked 3,119 Times
Coimmand shifters direct link https://www.bikeforums.net/sale/1254...hift-plus.html
lurking nightrider
Close up of Superbe Pro spline pattern
A 21 tooth cog from a microdrive cassette. All Suntour cogs are interchangeable except for the lock ring cogs.
A 3mm plastic spacer
The main cassette body drops next
The first loose cog
Last cog/lockring. Voila! 8-speed
Likes For LittleGinseng:
Wrench Savant
I dumped 2-3 NOS Suntour 7/8-speed cassettes at the local bike coop last year. I can see if they are still there.
Quoted: 4802 Post(s)
Liked 3,922 Times
Drool. I'm passing on 8-speed. Went 7 to 9. But I've got the shifters - the top-mounted DT Superbes that sit on the box. I'd have to dial in the friction for 8-speed. )
lurking nightrider
not sure if the hubs have sold, but i was going through my freewheel bin and found an 8 speed APII cassette, 11-28, nos w/ instructions.
so if that helps sway someone toward a purchase of the hubs, send me a pm about the cassette and we can work out the pricing on that.
However, one could remove the pins on that cassette and use the cogs for The Superbe hub in conjunction with an AP 7-speed cassette with a single lock ring cog.
Thank you for the effort though, hazetguy. Oh! And the hubs are still available.
lurking nightrider
I'm now including the 7-speed Suntour cassette (CS-AP00-S7U) 12-13-14-15-16-17-19 plus the extra spacer and 21 tooth cog to make it an 8-speed cassette, inclusive in the price of $150. You'll still need the Superbe Pro 8-speed shift levers for indexed shifting.
Shipping to USA only, Paypal friends and family.
lurking nightrider
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,054 Times
What a pretty unicorn. It's likely the last combo to be offered up on this forum. Can't remember another.
lurking nightrider
