Homebuilt Spoke Tensiometer
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 226 Post(s)
Liked 309 Times
An early snowfall in the Pacific Northwest has taken me off the road and into my workshop to get after a slew of winter projects. First up was the rebuild of a spoke tensiometer that I built a few years ago. This is my take on the Jobst Brandt / FSA / Wheel Fanatyk device. Like other tensiometers, it measures spoke deflection between two points under a fixed load. I built this for $0 with materials I had on hand. Looking closely at the photos of my tensiometer, you will see that the spokes are are "nested" between two ball bearings separated by a thin spacer. I think this makes it easier to use than the FSA / Wheel Fanatyk tensiometer.
My first version used much larger ball bearings (32mm OD)....'cuz that is what I had on hand. This resulted in an overall width that was awkward to place in some wheel/spoke configurations. Yesterday's rebuild involved replacing the large bearings with 13mm OD bearings. The device is now ~1" narrower and much easier to use. This prompted me to make new calibration charts for 2.0, 1.8, and 1.7mm spokes.
Soooo....here is the rebuilt tensionmeter in use.
A view of my calibration fixture.
And a close up of the tensiometer while in the calibration fixture.
Likes For Dean51:
Quoted: 980 Post(s)
Liked 582 Times
Beautiful! Nicely thought out and made. I'm getting by with the Park Tools gauge, but I couldn't build one myself.
Tuning by pitch is complicated by contact with other spokes, which can damp the vibrations. Still, $5 ain't bad!
I'll keep my gauge, thanks.
Steve
Steve
Don't make me sing!
Bikes: 2013 Specialized Crosstrail Elite, 1986 Centurion Elite RS, Diamondback hardtail MTB, '70s Fuji Special Road Racer, 2012 Raleigh Revenio 2.0, 1992 Trek 1000
Quoted: 308 Post(s)
Passista
Quoted: 866 Post(s)
Liked 721 Times
Great job! I thought about making one myself, but doubt it would turn up as neat as yours.
Since I don't use one, and probably never will, because I have no interest in building wheels, does the calibration of the tool matter? Are you measuring specific spoke tension, using what scale? Or do you just need to verify the tension difference between the spokes?
BTW, Nice polish job on the frame.
Quoted: 2026 Post(s)
Liked 1,096 Times
Interesting calibration technique, using a stress gauge to measure the spoke tension and then calibrating the deflection caused by an an "unknown" force (the spring) as a function of the known spoke load. I don't think many of us have access to a load measuring device like yours but I suppose known weights could be hung from a spoke and accomplish the same thing.
Quoted: 226 Post(s)
Liked 309 Times
Kevin.... I will take some side view and back view pics later today that will show you more detail.
Quoted: 1438 Post(s)
Liked 1,092 Times
Quoted: 226 Post(s)
Liked 309 Times
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Hillrider.... You are spot on. The loading force is unknown. I experimented with different springs to produce a range of deflection that I could observe on the dial indicator. For each spoke gauge, I measured and recorded deflection in 5 kg increments from 50 kg to 140 kg. As an example, a 2 mm spoke deflects 0.0285" at 95 kg tension and 0.0275" at 100 kg. My "load measuring device" is an inexpensive digital scale I purchased on eBay for another project. Not shown on my earlier pics....the top side of the scale is attached to an eyebolt with fine thread. To increase the load, I turned a nut on the eyebolt. Simple, and very repeatable.
Quoted: 226 Post(s)
Liked 309 Times
For Kevin and any others interested in more details....
Side view:
Back view - assembled:
Slide details:
The slide rails were 5/16" key stock. There are two guides. Each has a fender washer on each side of the key stock, with the convex side of the washer facing the slide, and a small bronze bushing that separates the washers such that there is clearance for the slide to slip through them.
Side view:
Slide details:
Quoted: 4201 Post(s)
Liked 3,860 Times
Besides the cool factor in making one's own tools what I am drawn to is the hand finishing that this tool has had. I am glad to see some still use their hands and make their own ****. Andy
Liked 1,096 Times
Quoted: 226 Post(s)
Liked 309 Times
Very clever. It looked far more sophisticated (and expensive) in the picture until you explained what it was. I'll bet you could do a nice business calibrating other wheelbuilder's commercial spoke tension gauges sort of the way other companies get paid to calibrate torque wrenches.
Dean
Don't make me sing!
Quoted: 308 Post(s)
Side view:
Slide details:
Side view:
Slide details:
Very cool! Thanks! I thought it was made from aluminum, but you went old school with steel. Very "Pittsburgh" of you! I like that. This will be one of my winter projects, and I'll post my version, when it's done.
Thanks, again, for sharing.
Always Learning
Bikes: Very Upgraded Denali 63.5cm
Quoted: 86 Post(s)
Wow
Now that is what I'd call 'Art'. You have quite a mind for design and skill in fabrication. Wonderful to see such a fine piece.
I have a band saw band (blade) tensiometer dial indicator that works on the same principle. If I had your talent I'd adapt it to spokes.
Senior member
Quoted: 943 Post(s)
Liked 658 Times
If you want to add a bit of decorative flair to your home built tools, you can give it a jewelled finish with a wooden dowel in a drill press.
Great looking tool, all around. I'm always on the lookout for dial gauges at flea markets, so this could be a cool project, for sure.
Dan, I always wondered how they made the jewel effect on (softer) metals, looks neat. That's almost sacrilege to do that to a pair of Uticas, though...of the 7-8 different brands floating around my box, from Mac, Snap-on, Wera, etc, the Utica pliers have the best finish, with the deepest luster, even with the complicated shapes.
Good candidate for jeweling, though
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Oh, and that wasn't my work in the photo. I grabbed that off the net.
Liked 1,096 Times
A company named Cratex sells abrasive rods in various diameters just for this use and other companies make holding fixtures to assure even rows of the swirls.
Senior member
Quoted: 943 Post(s)
Liked 658 Times
https://www.cratex.com/Products/Rubb...ives/Jewelling
I wonder if you could use a digital tire gauge instead of a dial guage. These things are almost free on ebay.
Speedub.Nate
Bicycle Mechanics
30
03-20-18 02:44 PM
aerodynamic
Bicycle Mechanics
5
04-14-12 04:54 PM
