Removing locknut from freehub
Quoted: 10 Post(s)
Hi guys,
I have a freehub that uses a locknut on each side requiring a 17mm cone spanner to be placed on each side to unscrew. It isn't the typical kind where you can place two cone spanners on the locknut on the same side to unscrew. The axle itself is circular -- no hex shape for an Allen key to fit in.
The thing is, when I unscrew one of the locknut (by placing one cone spanner on each side, and turning counterclockwise), the locknut on the looser side comes off easily. However, I no longer have any leverage to make sure the axle stays still. As a result, I can never remove the locknut on the other side. As somehow the locknut on the non drive side is always slightly looser than on the drive side, I can never remove the locknut on the drive side.
I tried using an adjustable spanner and a needle nose plier to clamp the axle while trying to remove the locknut on the drive side, but the axle always slips and I'm afraid of stripping the threads.
Is there any way around this?
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
You need another cone wrench to loosen the locknut from the cone, typically the cone uses a 15mm cone wrench and only has two "flats" for the wrench to lock on to. Also as you mentioned it is a rear wheel, it may be easier to first remove the freewheel or cassette gear assembly, that should give you access to the cone on the drive side. grease or dirt on the cone may be blocking you from seeing the flats of the cone itself.
Maybe this video will help you
https://video.search.yahoo.com/searc...2&action=click
Quoted: 10 Post(s)
Thank you. Unfortunately, the design of the lock nut is such that it covers the entire axle (see attached photo -- the lock nut and the conical base below is actually one piece), so there is no way I can insert two cone wrenches on the same side. Basically, I need to find a way to stabilise the axle so that I can unscrew the locknut but I am not able to figure out how to do so.
EDIT: I can't seem to post photos yet, so I have uploaded a link here: ibb.co/R9jmPSx
Quoted: 1815 Post(s)
Liked 1,693 Times
Who made the hub? Knowing how to service something starts with knowing what you are working on. Different hubs require different methods
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12740 Post(s)
Liked 7,652 Times
Some axles have an Allen wrench fitting inside, sometimes you can use an axle vise.
Quoted: 10 Post(s)
Quoted: 10 Post(s)
It is by this brand called Litepro. It is a Chinese brand, so details are scarce. This is a 20" 451 wheel by the way, so parts are perhaps a little unconventional.
Bikes: everywhere
Liked 7,652 Times
Quoted: 10 Post(s)
To be honest, no reason at all. I just want to figure out how to assemble and disassemble a bike. I've managed to learn everything else except this and it bugs me that I can't figure out how.
Liked 1,693 Times
Have you considered that the drive side is not supposed to be removed? Possibly after removal of the non drive side locknut the axle can be pushed out of the hub on the drive side
Quoted: 10 Post(s)
Anyway, I think I will get one of these to see if it gives me enough leverage to grip the axle, while I attempt to remove the locknut on the other end: https://www.amazon.sg/dp/B08818RC7C?...02_02_t_img_lh
Bikes: everywhere
Liked 7,652 Times
I removed it once the first time I tried it and was able to access the freehub body. It's just that after I tightened it back up, the drive-side locknut became tighter than the NDS locknut and I can no longer remove the freehub body.
https://www.amazon.com/Park-Tool-AV-...a-564598579111
There's also a bigger axle vise that does more sizes.
Quoted: 6178 Post(s)
Liked 4,795 Times
What's the other side look like? Maybe what you are showing us it all one piece that goes thru to the other side and the nut and locknut on the other side and maybe some other stuff on the drive side need to be taken off first.
Though removing the disc might show some other clues.
I'd look for any identification or numbers on that hub and google every which way I could think of for a service manual or assembly drawing. Failing that a youtube video.
Quoted: 10 Post(s)
So my question is how do I grip a round axle in place without stripping the locknut threads. Seems like an axle vise is the solution.
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Quoted: 10 Post(s)
I feel that my issue is more mechanical in nature (rather than something I need to resort to a manual for) and I do know how to remove the locknut on each side. The trouble is that I tightened the locknut on the drive side a little too tight previously and as a result, I can only loosen the non-drive side locknut.
Attached below is how the axle looks like on the non-drive side with the locknut removed. Basically I need to find a way to grip the axle such that I can remove the locknut on the other side.
This is how the locknut on the drive side looks -- basically a replica of the non drive side
The locknut on the drive side can be removed -- because I removed it once before, just that now I have tightened it a little too much that I no longer have the leverage to loosen it.
Apart from getting a bench vise (a little bit of an issue because I do not have a solid table), are there any alternative methods I can try?
Liked 4,795 Times
Now that you have one side off, it looks and seems as if you can just pull the entire axle whatever is attached to it out from the other side. That's what we use to do with axles on freewheel equipped bikes. Though not knowing for certain what that freehub is.... watch for small parts falling out or scattering to parts unknown.
Liked 1,693 Times
That looks like an aluminum axle. Even using an axle vice you might easily damage the threads of that soft metal. I would be looking to see if the axle can be pushed out the drive side before doing anything else.
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
My only other thought is to thread on a couple of nuts or possibly even three nuts on to the non-drive side, locking them very tight to each other BUT NOT against the sealed bearing and then putting a wrench on the outer INNER nut while trying to loosen the drive side locknut. You might get lucky to free the drive side lock nut.
Quoted: 10 Post(s)
My only other thought is to thread on a couple of nuts or possibly even three nuts on to the non-drive side, locking then very tight to each other BUT NOT against the sealed bearing and then putting a wrench on the outer nut while trying to loose the drive side locknut. You might get lucky to free the drive side lock nut.
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
My only other thought is to thread on a couple of nuts or possibly even three nuts on to the non-drive side, locking them very tight to each other BUT NOT against the sealed bearing and then putting a wrench on the outer nut while trying to loose the drive side locknut. You might get lucky to free the drive side lock nut.
I should have said ......"and then putting a wrench on the INNER nut while trying to loosen the drive side locknut."
I will also edit my other reply to reflect this.
Quoted: 10 Post(s)
I have no idea why I said the outer nut..... that would break free the easiest, the inner nut would take some force to move the 1 or 2 outer nuts as it is locked against it.
Haven't got the chance to get a suitably sized nut yet... But I applied a bit of blue loctite on the non drive side and now I can remove the drive side locknut. Well, at the expense of the non drive side I guess. But I think getting access to the drive side locknut is more crucial in case I want to service or replace the freehub body down the road.
Liked 4,795 Times
So if you pull on the freehub, it and the axle don't just come out of the hub?
Maybe give the axle a tap on the non-drive side with a mallet.... not a hammer. If you use a hammer, then put a piece of wood or plastic between it and what you hit.
Maybe do it over a towel or bowl to keep any thing loose from getting lost forever
Likes For Iride01:
Quoted: 10 Post(s)
I think the cartridge bearings are press fit which is preventing the axle from coming off
