Go Back  Bike Forums > Bike Forums > Framebuilders
Homemade Frame Alignment Gauge!
Framebuilders Thinking about a custom frame? Lugged vs Fillet Brazed. Different Frame materials? Newvex or Pacenti Lugs? why get a custom Road, Mountain, or Track Frame? Got a question about framebuilding? Lets discuss framebuilding at it's finest.
Old 12-07-21, 10:38 AM
Tandem Tom
Quoted: 455 Post(s)
Liked 112 Times in 85 Posts
While waiting for the balance of my parts, Rene Herse is extremely slow!!, I made a wooden gauge like the one Alex Wetmore use to offer. Mine is out of cherry! As a woodworker I am use to making precise parts so I thought I would give it a go!
The holder is in process.
Tandem Tom is offline
Old 12-07-21, 01:12 PM
smontanaro
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times in 760 Posts
Interesting. Not being familiar with Alex's stuff, can you explain/show how this works?
Monti Special
smontanaro is online now
Old 12-07-21, 02:22 PM
Tandem Tom
Quoted: 455 Post(s)
I will post a pic tomorrow. I'm not in the shop.
Old 12-07-21, 03:14 PM
bulgie
blahblahblah chrome moly
bulgie's Avatar
Quoted: 1173 Post(s)
Liked 2,569 Times in 1,073 Posts
Alex's description, and a pic of it in use: https://alexwetmore.org/?page_id=1080
Probably obvious but I'll mention it for completeness: it uses a surface plate with the frame held horizontally above the surface. Not useful without a surface plate or alignment table.
Set the height of the vee to something known to be in the centerplane, say the bottom end of the seat tube, then the vee can check the height of other spots, say the head tube. The outer edges can check the dropout spacing and centering.
Alex's design later was made by Hahn Rossman and sold by Rene Herse (with Alex's blessing).
https://www.renehersecycles.com/shop...lignment-tool/
Note there are two versions, with different selections of hub widths. One of them listed as out of stock.
Mark B
bulgie is offline
Old 12-07-21, 03:59 PM
smontanaro
Bikes: many
Thanks, Mark. Now I get it. I see 100/120/130/135 and 100/110/135/142 versions. I understand what the 100, 120, 130, and 135 dimensions are for. I assume the 142 is something to do with tandems or fat bikes. I'm puzzled at the lack of a 126, and what's 110 for? Maybe fat bike forks? And maybe my assumption of 120mm only applying to five-speed rear triangles is off as well. I'm so limited in my view of the bike world (basically road bikes from the late 50s to early 80s) that some dimensions which will be immediately obvious to the rest of you just leave me scratching my head.
Monti Special
Old 12-07-21, 06:27 PM
unterhausen
Randomhead
Liked 3,696 Times in 2,517 Posts
I designed one for 100 110 120 126 130 135 142 148 150 157 170 177 190 197 spacing, but as you can imagine the laser cutter couldn't cut with enough precision to get all of the steps right
In all seriousness, I decided to go with one that had all the spacings that Alex didn't implement. I think I only need 142 and 148. Maybe I should add 110. Not sure what else I would need.
Sometimes I crack myself up
unterhausen is offline
Old 12-07-21, 06:48 PM
Cynikal
Team Beer
Cynikal's Avatar
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times in 104 Posts
142mm is the standard rear spacing for thru axle frames. 110mm is used for a newer MTB standard for front forks called boost spacing. 120mm is the current track standard for rear spacing. I don't know why anyone would build a new frame with a 126 spacing but if they did there are ways to figure that out.
I know I used the term standard several times above and I completely understand the absurdity in the use of that term in the industry but it made the most sense to use.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Cynikal is offline
Old 12-08-21, 03:09 AM
unterhausen
Randomhead
Most current mtb have 148 "boost" rear spacing. I'm not sure how many gravel bikes have 148 spacing, but 110 is becoming more common on the front, "road boost" Because 15x110 is so much heavier than 12x110
Likes For unterhausen:
Old 12-08-21, 09:39 AM
Tandem Tom
Quoted: 455 Post(s)
Here is a pic of my complete "tool"!
