Velo Orange Grand Cru seatpost problems??
I am not sure if this is the correct category or not.
Because of a bike with too steep a seat tube angle, I need a post with the greatest amount of setback and Velo Orange Grand Cru with 3.2 cm of setback would seem to address that need. Once mounted, the saddle would have to be slammed back as far as it would go.
I read a review that claimed when the saddle is mounted as far back on the rails as possible, there is a problem with saddle adjustability in that the way the clamp is designed, it limits how the seat angle can be adjusted.
Has anyone used this seatpost encountered that problem or any others?
Thank you.
Walt
Thank you.
Walt
Constant tinkerer
I have this post on a bike. And although my seat isn't slammed all the way back, I haven't had any problems adjusting the angle or anything else. I've had a couple different saddles on the bike and it holds them very securely.
The two-bolt setup is quite a bit slower to adjust than a single bolt. But once you dial it in, you never touch it. So, whatever.
Likes For FastJake:
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
I have that seatpost. Angling the saddle downward does move the clamp forward, but you can still move the saddle aft-ward as far as the rails allow. The offset of the clamp does depend on saddle angle. I don't know if the advertised 32mm offset is when the saddle is angled up all the way, angled down all the way, or in the middle.
There's an older version of the Gran Cru seatpost in which the offset doesn't change with saddle angle, if you can find one.
The IRD WayBack has the most offset available, I think.
https://www.interlocracing.com/shop/...t-wayback-2418
edit: looks like there were some issues with that old style Grand Cru seatpost: https://velo-orange.blogspot.com/201...per-clamp.html
Likes For tyrion:
Quoted: 4204 Post(s)
Liked 3,861 Times
The usual issue with seat post clamping rails at the far front end of them is there's so much leverage being placed on the rails with so much seat hanging out back of the clamp. We see many bent seat rails (and this really effects seat angle) on customer bikes because of this. Andy
PS- There's about a 1 degree per cm of set back relationship at the top of a seat tube. So for a seat to be well placed (per rider's preference) and also need 3+ cm of post set back AND all the rails' set back range means to me that either the fit is weird (although swept back and upright handle bars do want more seat set back then drop bars do) or that frame has a REALLY steep seat tube angle. Unless the rider is using seat position to get their reach to the bars better (which we know is not what set back is meant to address).
I do wonder about the rider's fit, trguardless on the bike's seat angle.
AndrewRStewart
AndrewRStewart
Liked 2,011 Times
Likes For tyrion:
Quoted: 6193 Post(s)
Liked 4,809 Times
When you have to go to seat posts with more setback, then I have to believe you bought the bike more for it's looks than for the way you ride it or how it fit.
But yes you don't really want to have the saddle at the extremes of the rail position in the clamps as a normal thing. The heavier you are or the bumpier your riding conditions the higher stress they'll have to handle or they'll bend or break.
So yes you need to find some seat post that has more setback. Does it have to be a Velo Orange? Not sure why some seem to gravitate to them when there is so many others out there.
Oh... welcome to BF!
I really appreciate everyone's help with this and for your suggestions. I am a tall rider and find 72-72.5 seat tube angle works great for me, since I have a long femur. I have an older Merlin Works titanium track frame designed by Tom Kellogg (I bought the frame used, so it was not designed for me). I have been searching for a way to make the steep seat tube angle work. With the setback seatpost, balance would not be the best, but I am just trying to get in a position where I can actually ride it.
Liked 4,809 Times
How does that make me incorrect?
Bikes models have different seat tube angles. Many people I see with saddles that have large amounts of setback are using their road bike as if it were a cruiser style bike. Cruiser will have less of an angle to between the seat post and horizontal so that effectively removes the need for more setback since the saddle will be further behind the BB than a typical road bike.
And as I said in my post, it's my belief. Not an absolute or that there aren't circumstances where it is warranted.
Liked 2,011 Times
Quoted: 836 Post(s)
Liked 1,061 Times
I also have one of the VO SP's and the adjustment can be a real bear to get just right for some setups. Also have to move my saddle almost as far back as it will go and I always dread doing anything where I have to take the saddle off and put back on again. Alternate tightening each clamp bolt a few turns at a time to get the position right and have patience is my best advice.
Liked 3,861 Times
I agree completely. Do remember these saddles were designed back when seat tube angles were slacker then is the current fashion. Also if the brooks saddle in play is in the B-66 family of shape (there have been a few variants on the wider yet short shape) these were really meant for upright barred bikes which often had 68ish degreed seat tubes. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Bikes: CO-OP ADV 3.1 aka Beeftank (stolen, RIP), State All-Road
Quoted: 96 Post(s)
Liked 144 Times
