What is this bike building machine?
Bikes: 1st Track bike: 1978 Speedwell titanium 1st Road bike: 2001 Independent Fabrication Crown Jewel
Quoted: 97 Post(s)
Liked 116 Times
I came across this photo in a current article in Bicycle Retailer.com about bike designer Mike Burrows who recently passed.
What is this beast of a machine and what does it do? It's got to be way more than a drill press!
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
Google Lens tells me it's a vertical mill.
Photo Index - Kearney & Trecker Co. - Model 2HL Vertical | VintageMachinery.org
My Bikes
My Bikes
Likes For P!N20:
Regarding what it does, well, it's a metal working analog of a woodworking router.
That is, it cuts material which is traveling across the cutter in a direction perpendicular to the spin axis of the cutter. It can also cut across the bottom of the cutter to create a flat surface (flat bottomed cutter) or profiled surface (with profiled cutter). It can also cut across the sides of the cutter. You can also use its flat-bottomed cutters to cut downward and make flat-bottomed holes. It differs from a drill, in that twist drills cut downward along their spin axis.
With a properly sized cutter, you can use it to miter frame tubes.
Likes For Bad Lag:
Quoted: 4511 Post(s)
Liked 6,378 Times
And with an expert hand like Mike at the controls, it can do extraordinary operations not normally achieved.
Quoted: 1106 Post(s)
Liked 1,328 Times
It is a "machine tool", the essential quality of which is that it can make another like itself.
(Milwaukee 2HL, you want a solid base for that thing.)
SE Wis
Quoted: 2747 Post(s)
Liked 3,394 Times
Quoted: 3464 Post(s)
Liked 2,829 Times
I would prefer to have a Bridgeport Mill
but that is what I learned on.
would not even need a digital readout and power feed... but would be nice!
Likes For repechage:
Quoted: 97 Post(s)
Liked 116 Times
Fascinating! Thanks for all the info - I knew you guys would know. So this is what we had before there was CNC machining?
Liked 6,378 Times
