What's the best way to get a 118-link 9-speed chain?
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
I'm piecing together a 9-speed bicycle that has relatively long chainstays. The correct number of chainlinks is 118 but the longest chain that I can find (without going to a $40, 140-link chain for cargo bicycles) is 116 links. I'd most like to use a KMC chain because of the quick-link but, I'm open to other brands if doing so is considerably more feasible.
Side question: Is it just me or, are 9-speed chains more difficult to splice together than 10-speed ones? Every time I alter the length of a 9-speed chain, the connection ends up stiff, whereas my 10-speed chain work has consistently been immediately successful.
Pennylane Splitter
Bikes: Yes
Quoted: 1789 Post(s)
Liked 1,438 Times
If it was me and I had a good 116-link chain I'd put it on the bicycle and see if it works on a 'worst case' scenario (front chainring/rear sprocket combo). If the 116 doesn't work I'd just buy the 140-link chain and shorten it. But if you haven't bought a chain yet, just buy the 140 and you'll be sure to have enough length/links.
Quoted: 96 Post(s)
Liked 292 Times
Sorry, thought I had a source for one with 122 links that I had seen but the ads text was misleading.
Quoted: 595 Post(s)
Liked 282 Times
If you have a local bike shop, swing by and ask if they have a couple extra links laying around, most will, and if you take them some brownies, then they'll probably put it together for you.
QR-disc must die!!!
Quoted: 397 Post(s)
Liked 199 Times
'Worst-case scenario' is how I decided on 118-links.
I actually just found a $15 9-spd chain with exactly 118-links (and one is a quick-connector). The S-Ride M300. Glad I don't have to make brownies for it. I wonder if the connector link is the infamous single-use type.
Likes For Nyah:
did you use the time honoured and reliable method of not running chain through jockey wheels, putting it on big/big and adding two links?
If unfamiliar with this, look up the excellent parks tools vid on determining chain length.
You didn't mention how you came to the chain length conclusion, why I'm asking.
Likes For djb:
Pennylane Splitter
Bikes: Yes
Liked 1,438 Times
What is your largest chain Ring and rear cog ? How long are chain stays?
Watch the video thoroughly and try the easy no Rd method with your existing old chain to see how it works out, just in case a regular chain will be ok.
I'd have to look at the KMC 9 spd chains I have in box to see how many links they have, but usually have to take off at least 2 links. Even with a 50- 32 combo I've never had a problem with a regular chain.
QR-disc must die!!!
Quoted: 397 Post(s)
Liked 199 Times
I have a chain of that length on right now, spliced from two different 9spd chains. I can't keep my spliced link from being too stiff. The chain will only shift on every-other click of the index and thus gives me access to only five of the nine cogs. There might be some other things going on that are causing the shift problem. Starting fresh with a factory chain will hopefully narrow down the number of variables. I'm glad to have found one.
Yes, exactly that method. The correct chain length is 118 links for this setup.
buy one!
https://www.ebay.com/itm/194992192768
KMC Z99 9-speed 118 Links + Sram Quick-Link MTB Road Chain for Shimano SRAM
$17.25 with free shipping from taiwanland.https://www.ebay.com/itm/194992192768
Bikes: Merida Speeder
Quoted: 233 Post(s)
Liked 165 Times
Or just buy an extra chain and take two links from it to add to a 116 link chain. Then when you change the chain, you can just take a couple more links.
Quoted: 2602 Post(s)
Liked 1,925 Times
I think I remember seeing a spool with perhaps 50' of chain on it. The idea was kind of like chain in a hardware store -- pull off what you need and shorten the (bicycle) chain. Sorry, , but that's been a while and I don't remember who carried it.
OTOH, you'd have to ride the bike for a long time to make the spool pay off. If you've found one that's long enough, buy 4-5 chains now before they take them off the market!
QR-disc must die!!!
Quoted: 397 Post(s)
Liked 199 Times
I received the S-Ride chain. It seems pretty good. Now, how do I get the shifting problem solved without resorting to the LBS? I'm using bar-end shifters and would like to use them in Index mode.
Quoted: 3458 Post(s)
Liked 1,465 Times
Before you found one (your post below), I was going to say that with an extra quick link and one worn link from your old chain you have the extra two that you need.
I bought a single speed chain for my three speed that was a hair too short, I had to use a link and the old master link from the old chain to make it fit, as that bike had long chainstays. But a new quick link would be better than the old one if you had a spare lying around.
Also as noted by someone above, bike shop might have a few spare links that were cut from other chains, but it is my experience that those go in the recycle bin pretty fast. When a mechanic might be working on 8. 9. 10, 11, and 12 speed bikes in a day, and maybe a single speed, they likely do not want to have too many spare cut off links.
Of course when you buy a lot of anything you risk the fact that the technology might change. I figure buying a 10 year supply of something guarantees they will make a much better version of it or otherwise make it obsolete. Also for some of us are getting to the age to start wondering how many chains we will still be able to wear out.
Liked 1,465 Times
I built up my first year of production LHT in 2004, at that time a lot of chains were sold for smaller cassettes and bikes with short chainstays. And the chains I bought for that bike were a few links too short.
But the world has gone to bigger cassettes. And longer chainstays are more frequent than they used to be, so I think the chain companies started making chains a few links longer than a decade or two ago.
Over a decade ago Nashbar had some eight speed tandem chains on a clearance sale. I bought several. Not as convenient as a long spool of chain, but I got a lot of chains out of it by combining the cut off parts together. But I had to buy the quick links separately.
