Quarq TyreWiz
Quoted: 20808 Post(s)
Liked 9,450 Times
The other device that I'd alluded to, the Scope Atmoz, actually reads *and* changes pressure on the fly. It could, in theory, be really beneficial for courses where there are differing conditions (cobbles, long stretches of smooth pavement, etc)... but that costs prolly 10x as much as the devices being mocked here.
Quoted: 3241 Post(s)
Liked 2,512 Times
During a race? No. He's talking about pre-riding a course and having the data to select the pressure that provides the best/desired balance for the course when it's go time.
Quoted: 1455 Post(s)
Liked 1,477 Times
For now, I guess I'll continue to use one of these, which is like $10:
Perceptual Dullard
Quoted: 915 Post(s)
Liked 1,132 Times
Once again, I don't think the TyreWiz's main target is road racers (though reportedly some teams did tests using them in the run-up to Paris-Roubaix). And, as noted above, we were trying to use it during some CdA/Crr testing (but for other reasons we had to skip it). The manometers on most pumps are notoriously poor. I have a Silca Tattico BT that shows 0.5 psi increments, but each time I remove it from the valve stem I lose a little pressure, which is irksome. For those times when I'm doing experiments, I wish I had something like the TyreWiz -- but I know this is an unusual usage so I try not to project my needs and preferences onto others.
Liked 1,477 Times
Totally agree that the gauges on most floor pumps are not particularly accurate or precise. My Topeak Joe Blow floor pump can easily be +/- 5psi and I also lose a bit of air when removing the chuck.
My handheld gauge has a release valve that makes it easy to deflate small amounts of air to get within 1psi, and doesn't let any air out on removal. I don't know if it's super accurate, but it's definitely more precise and gives me repeatable numbers that are useful for setting pressure before a race.
I don't think TyreWiz solves any problems for me, as it would just be $400 worth of electronic gizmos that do the same thing that a $10 gauge can do, but I can see some usefulness for people riding extreme ultra distance races where pressure would potentially vary over many hours, and stopping to check and/or carrying a gauge isn't desirable.
Likes For msu2001la:
climber has-been
Quoted: 3414 Post(s)
Liked 3,543 Times
FYI, almost all the air you hear rushing out when you remove the chuck is the air in the pump hose, so your tire pressure really doesn't drop when you remove the chuck.
Ride, Rest, Repeat. ROUVY: terrymorse
Should Be More Popular
Quoted: 22577 Post(s)
Liked 8,919 Times
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
If I had to choose buying a well reading pump that's more expensive and not buying these versus owning a cheaper pump and owning this, I would own the nicer pump. I thought about these for time trial aero and CRR testing. Decided against it.
I thought folks have had success getting pretty accurate pressures with the electric pumps? Set target and it pumps it up to that.
