Should I replace my large chain ring?
Old 08-07-22, 08:34 AM
Esos1
Should I replace my largest chain ring in the front? I can't quite tell if they are spiky enough or look like shark fins? I also included a picture of my cassette since I read that that is supposed to wear out faster but it doesn't seem to be? Please let me know if you think I should replace that too. Everything is original to the bike and the bike (2012 Trek Lexa) has maybe 10,000 miles on it? It's hard to say honestly though since I haven't been keeping track of the mileage until recently. TIA!
Esos1 is offline
Old 08-07-22, 08:49 AM
base2
Doesn't brain good.
base2's Avatar
Bikes: 5 good ones, and the occasional project.
Quoted: 1238 Post(s)
Liked 905 Times in 529 Posts
10,000 easy miles is a lot different than 10,000 hard & neglected miles.
Some people have a favorite cog. This is the one most likely to skip under load. If you are someone who uses all your cogs, you'll get more miles.
Big gears (larger diameter) are under less tension, which makes for less friction & less wear. The smallest chainring is the most likely to wear out first unless it is a much stronger material than the others or used significantly less than the others. Chain-suck where the teeth are too tall to cleanly release the chain is the biggest tell-tale sign that a replacement is necessary.
I wouldn't change anything until a fresh or relatively unworn chain misbehaves.
Car dependency is a tax.
base2 is offline
Likes For base2:
Old 08-07-22, 11:15 AM
Iride01
Plz hurry Dec 22!
Iride01's Avatar
Quoted: 4873 Post(s)
Liked 3,391 Times in 2,352 Posts
If you want to you can change it, but any remaining mileage on that ring will let you go that much further before adding to your maintenance expenses.
I'd just let it go until your chain starts to skip over the ring when you put some power into the pedals. Usually that happens after putting a new chain on. But if you do something that is so important you don't have time for such failures such as competitions or races, then change it.
You have been changing your chains regularly when they measure as worn haven't you?
Iride01 is online now
Likes For Iride01:
Old 08-07-22, 11:26 AM
Esos1
I didn't know what this was so I had to look it up and yeah, I think this has happened to me a few times?
Esos1 is offline
Old 08-07-22, 11:33 AM
Esos1
Umm no 😬😅 I changed the chain for the 1st time almost exactly 1500 miles ago. As I get more and more into cycling I'm trying to get better about regular maintenance. I definitely plan to in the future is what I'm saying! I did measure the chain last week and I'm pretty sure it's not stretched? If it was stretched past 12 inches it was just barely, maybe a millimeter.
Esos1 is offline
Old 08-07-22, 11:37 AM
Iride01
Plz hurry Dec 22!
Iride01's Avatar
Shhhhh! don't use the word "stretched" in the same sentence with chain. Some people here take the word stretched too literally. And they get very confrontational about how a person can't stretch a chain.
Wear is a much safer term around here! <grin>
For 11 speed chains, I've started replacing them when the pin closest to the 12" mark gets to be about 1/16" further. For the old bikes with 7 speeds and less, I never worried much about either chain or cogs, just replaced when one didn't work with the other.
Chains are about the only thing with the drive train that I do preventative maintenance on. I'm happy to let the rings and cogs go until they show me issues. Which is usually the chain skipping or slipping on them when putting some power into the pedals to accelerate rapidly from a stop.
Likes For Iride01:
Old 08-07-22, 11:40 AM
Esos1
Thanks for all the info by the way! By cogs here do you also mean the gears on the cassette too? Because I think this might be happening on one of those too. One of my middle gears in the back tends to skip under load, I know that, but I just figured my indexing was off or something?
Esos1 is offline
Old 08-07-22, 11:42 AM
Esos1
Thanks for the tips by the way! I guess I'll try to pay close attention on my next ride to see if this is happening on that large chain ring
Esos1 is offline
Old 08-08-22, 08:35 AM
KerryIrons
Quoted: 221 Post(s)
Liked 234 Times in 142 Posts
Cogs are on the cassette in the rear. Chain rings are on the crank in front. Measure chain wear with a ruler and when it reaches 1/16" in a nominal 12" section, replace the chain. If the chain skips on the cogs when you pedal hard then the cassette may need replacing. You can ride a couple 100 miles and if the chain is still skipping, replace the cassette. If the new chain skips easily on the cassette, replace the cassette immediately. Your chain rings are worn but not seriously so. Put a new chain on the chain ring and see how much it "rides up" as it wraps around. That is the best indicator of chain ring wear.
KerryIrons is offline
Likes For KerryIrons:
Old 08-08-22, 04:19 PM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 5149 Post(s)
Liked 2,694 Times in 1,595 Posts
No, your rings don’t look worn. They still have the original machining present. Modern chainring teeth can have a lot of different shapes depending on where the teeth are on the ring in relation to the lift pin. Perhaps you shouldn’t ride to the point where the chainring teeth look like the ring on the left but yours can go quite a while longer.
worn vs unworn by Stuart Black, on Flickr
Stuart Black
cyccommute is offline
Likes For cyccommute:
Old 08-10-22, 09:33 AM
bblair
Bikes: Lynskey R230, Trek 5200, 1975 Raleigh Pro, 1973 Falcon ,Trek T50 Tandem and a 1968 Paramount in progress.
Quoted: 223 Post(s)
Liked 179 Times in 120 Posts
I wouldn't.
My usual protocol is to replace my chain yearly, about 4k miles. My cassette has about 20k miles and I plan to replace it soon. I keep everything very clean and lubed and I am certainly not the biggest or strongest guy around.
Chainrings? Rarely, if ever.
bblair is offline
