Can You Convert Shimano SL-R400 Shifter To Friction
Quoted: 955 Post(s)
Liked 1,619 Times
These look great and are affordably new. Anybody know of a way to convert these over to pure friction shifters to be used with non-indexed derailleurs and freewheels?
Shimano SL-R400 8-SPD Downtube Shifters
Not sure if this has been covered before...
Quoted: 836 Post(s)
Liked 1,058 Times
No, according to Shimano. SI-6CW0B-001-ENG.pdf (shimano.com) Look where it says "SIS Operation" on the lower right side. Looks like all but your model can convert to friction. Bummer.
Quoted: 1943 Post(s)
Liked 2,164 Times
Maybe a bit OT, but the best inexpensive Shimano friction lever, in my experience, is/was the SL-L422.
They are spring loaded, with a micro ratchet ring, that can be removed if desired.
The stem model needed to be modded for downtube application, but the downtube model should just bolt on.
John
John
Quoted: 2026 Post(s)
Liked 1,095 Times
Rivendell sells their "Silver" downtube shifters for $37 each and both front and rear are friction only. They are a modern take on the old Suntour "Power Ratchet" design and should work quite well.
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
I have a set of 1056 dt levers that can be switched to friction mode. I do not have the mounting bolts for available for them. Pm me with interest.
