Honjo Fenders on Super Sports?
Bikes: 73 Super Sport, 86 Tempo, 86 Peloton, 87 Super Sport, 83 Peugeot PFN10, 76 Super Course MK IV, 94 Univega Alpina 5.5
Quoted: 175 Post(s)
Liked 70 Times
Does anyone have Honjo Hammered Fenders on a Fillet Brazed Super Sport? What size fender? What sized tire? Pictures?
afraid of whales
Quoted: 347 Post(s)
Liked 5 Times
Limit to Super Sport's tire size is the chainstays width, you'll have around 42mm to fit the tire, 33~35mm actual tire width is close to the limit with 5mm per side clearance. I don't have Honjos, but 45mm Planet Bike or SKS are as big a fender as I am able to fit. The front fork and rear chainstays are limiting the max fender width.
BTW, these measurements are from several Super Sport/Sports Tourer frames I have, actual measurements from frame in question.
Buh'wah?!
Bikes: 2014 Giant Trance
Well, Super Sports came with 27x1 1/4" tires, so... 27"x32mm. So you'll probably want 43-45mm fenders.
-Gene-
-Gene-
You know i have been contemplating putting honjo's on a raleigh sports.
is it a possibility ? what do you guys think?
Sorry hope i'm not derailing the topic
the ones i have are seriously bent up....
Buh'wah?!
Maybe the VO variants? I've never seen 26" Honjo's.
https://www.velo-orange.com/vo60fefor26w.html
-Gene-
-Gene-
Quoted: 175 Post(s)
Liked 70 Times
I acquired an unused set of 35mm Honjo hammered fenders along with some fitting hardware.
Would these fit my 73 Schwinn Super Sport equipped with 27x 1” Panaracer Pasela Tourguard tires?
It has Sun CR18 rims.
1973 Schwinn Super Sport
1986 Schwinn Peloton
1976 Raleigh Super Course Mk II(for wife)
1983 Gitane Super Corsa
1991 Trek 750 Multitrack
Quoted: 360 Post(s)
Liked 323 Times
It has been 12 years and you still don't have an answer? I think the only way to tell for sure is to slide them one and check the clearance. Considering that a 1" tire is around 25 or 26mm, the fender should work in general. The real question is whether or not there is clearance in the frame.
Andy
Andy
Dunno if this helps but 35mm honjos fit nicely on my early '70s Cinelli
The tires are 28mm Panaracer Paselas
Rims are Mavic Open Sports laced to some Phil Wood hubs
mycocyclist
Quoted: 910 Post(s)
Liked 811 Times
Ask And...
"The wheels are 105 5700 hubs laced to 700c Sun CR-18s with DT Swiss champion spokes. I had the Champions in stock and couldn't afford to get butted spokes, though I wish I could. I figure when it's time for that I will go all out and build a set out of something shiny and tubeless compatible if possible, with hubs made in USA. For tires I went with 35c Panaracer Paselas in a folding bead. Even though they allegedly are a similar diameter to a 27x1 1/4, They are the largest size that fit the fenders. This added a lot of time and profanity to the fender install. Next time I will likely do 32c just to retain what sanity I have left.
The fenders by the way are velo orange,..." (Quoting from OP in their Thread.)
"Don't Know."
(An SS from February 1964 languishes in The Queue,,,)
Likes For machinist42:
Quoted: 175 Post(s)
Liked 70 Times
That is a beautiful Super Sport. He did a beautiful job with wider tires and fenders. Installing my 35mm Honjo fenders may be my winter project.
Here is the thread to my Super Sport restoration:
https://www.bikeforums.net/classic-v...ort-build.html
Likes For vonfilm:
Quoted: 175 Post(s)
Liked 70 Times
Quoted: 360 Post(s)
Liked 323 Times
I can understand that. I go with pre drilled fenders. SKS if I want plastic and Velo Orange if I want metal. I would never be happy with my ability to center holes or smooth the cuts. I lack those skills.
Andy
Andy
Quoted: 175 Post(s)
Liked 70 Times
I slid the Honjo 32mm fenders over the 27x 1” Pasela today and they conformed like a glove. I think these were made for 700 C.
I think it’s entirely doable though. The narrow fenders might even be easier to mount than wider ones. I don’t anticipate having to snip away large portions of fender.
Does anyone know the size and threading of the fender eyelets on the front and rear dropouts?
Bikes: 2017 Sage Skyline, 2015 Co-Motion Periscope Tandem, 2012 Soma Smoothie, 2006 Kona Jake, 1986 Miyata Nine Twelve, 1977 Peugeot UO18c, 1977 Peugeot PRN10, 1974 Allegro Schweitzermeister Model 76, 1972 Hugo Rickert Spezial
Quoted: 114 Post(s)
Liked 585 Times
Imo
Is it limiting for me to think that faceted or smooth fenders correspond with European bikes and hammered fenders fit the vibe of Japanese bikes?
Quoted: 175 Post(s)
Liked 70 Times
A Super Sport is an American bicycle fillet brazed in Chicago.
framebuilder
Those Honjo are beautiful fenders! I recommend Wald - made in Kentucky - smooth fenders. They look like the ones Schwinn equipped on their made in Chicago bikes.
www.theheadbadge.com
Quoted: 2420 Post(s)
Liked 4,381 Times
FYI, I briefly test fitted a pair of Handsome Cycles' 35mm-wide 700C Mud Butler hammered fenders on a '73 Super Sport with 27" wheels (no pictures, sorry). They fit fine on stock-ish tires and cleared the fork crown without issue.
I would assume 35mm Honjos are a similar story.
-Kurt
-Kurt
