Go Back  Bike Forums > Bike Forums > Utility Cycling
Question about Burley trailer hitches
Utility Cycling Want to haul groceries, beer, maybe even your kids? You don't have to live car free to put your bike to use as a workhorse. Here's the place to share and learn about the bicycle as a utility vehicle.
Old 04-29-21, 08:21 PM
agmetal
agmetal's Avatar
Bikes: Bianchi Volpe, ANT 3-speed roadster, New Albion Privateer singlespeed, Raleigh One Way singlespeed, Raleigh Professional "retro roadie" rebuild, 198? Fuji(?) franken-5-speed, 1937 Raleigh Tourist, 1952 Raleigh Sports, 1966 Raleigh Sports step-through
Quoted: 248 Post(s)
Liked 26 Times in 18 Posts
A friend of mine is shopping for a new bike. One of her criteria is trailer-pulling capability, and she's run into a snag with this because of how the trailer gets used. I have looked all over and can't find an answer to this question, which is frustrating because it seems like it would make for a simple solution to my friend's problem of needing to be able to quickly and easily use the trailer with multiple bikes of different types:
The Burley "classic" hitch has the Flex Connector attached to the hitch with a bolt and nut. The standard/steel/whatever-they-call-the-axle-mounted hitch uses a pin to attach to the Flex Connector. Is there any reason that the Classic hitch can't be used with a pin?
agmetal is offline
Old 09-25-21, 06:29 PM
owgreenb
Bikes: 1980-some Cannondale ST400 touring bike
I'm taking a look at mine and I can't see a reason immediately. Maybe the big ol' plastic hitch design makes it bump the key on tight turns... if so, actually making such a turn might bend the key and make it a pain to get off.
From a design standpoint, my instinct here is that Burley made this giant connector for the purpose of being able to put it on and take it cleanly off quickly, so putting a pin in it to allow you to keep the hitch on the bike defeats the purpose a bit. After all, there are much easier and more intuitive ways to connect if you don't want to bother with taking the entire trailer off quickly and leave nothing behind (such as the forged hitch, as you mentioned).
I know that logic doesn't really help with what you're looking for, but is there something specifically you're having trouble with for taking the entire classic hitch on and off? It should take about 15 seconds tops, even without practice, unless there's something one of us is missing! Maybe I can help you solve that problem and bypass the other one.
owgreenb is offline
