Shimano 600 headset nut
Bikes: Masi Gran Crit, Bianchi Campione D' Italia 84, Eddy Merckx Corsa Extra, Ibis Ripley, Co Motion Tandem, Merlin Agilis, Ritchey Breakaway, Bianchi Infinito CV, Colnago Master
Quoted: 68 Post(s)
Liked 129 Times
Does anyone have any hacks on how to remove a Shimano 600 headset top nut? It is the 8 point nut. My LBS doesn’t have a wrench that fits for this and recommended pliers. I’m pretty sure pliers will scar it.
I have standard headset 32mm wrenches, so I am better off than pliers but would welcome any input.
Dedicated Detritus Dodger
Bikes: Some mighty fine ones at that!
Quoted: 191 Post(s)
Liked 603 Times
Large vise grip set judiciously with a shop rag to keep from scarifying.
Worked for me once on one of these.
No prob.
No prob.
Looks like someone in Poland is machining reproductions and selling them on eBay for a fair price.
Quoted: 702 Post(s)
Liked 672 Times
Not sure if any of these would work but it's worth looking into......
https://www.mcmaster.com/wrenches/op...rement~metric/
Quoted: 656 Post(s)
Liked 469 Times
Likes For plonz:
Quoted: 3510 Post(s)
Liked 2,924 Times
Please don’t use pliers or vice grips for anything on your bike aside from tightening cables. Use the right tool.
I *personally* wouldn't listen to anyone recommending pliers or vice-grips for this job--up to and including your LBS.
The wrenches linked above on eBay are nice. You can even get originals for a good price.
Likes For smd4:
Quoted: 1106 Post(s)
Liked 1,327 Times
Headset parts are one of the places on a bicycle where unfortunately form often trumps function.
A good open-end spanner should have jaws long enough to hold eight points of that nut, so you don't actually need the special tool; handled properly it won't mark them.
For some headsets the AT508K, a slip-joint plier with replaceable curved soft jaws is a good one - they are commonly available on that auction site.
Quoted: 2323 Post(s)
Liked 4,988 Times
Yep, I did the same and works great. Worth the small outlay in cash in my book.
Steel is real...and comfy.
Likes For jamesdak:
Liked 2,924 Times
Liked 2,924 Times
I would support the use of a properly-sized adjustable wrench over the use of pliers. But I'd prefer to use the proper tool.
Quoted: 566 Post(s)
Liked 1,048 Times
*If* water pump/slip joint pliers are going to be used, liberally wrap the jaws with electrical tape. It’s worked for me in the past.
Bikes: 86' Centurion Ironman
Quoted: 628 Post(s)
Liked 316 Times
Likes For markwesti:
Liked 2,924 Times
Likes For smd4:
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,896 Times
Also, the nuts on that headset are aluminum and a poorly fitting wrench or set of pliers would scar them up something terrible.
Liked 2,924 Times
Liked 11,896 Times
Reminds me I went to recycling center/dump the other day and there is a section of bikes a guy picks up and disperses throughout Asia. I have ran into him in the past. Nice guy. There was a bike in the pile with a nice frame (No markings), wheels off to the side, no handlebars and a complete set of shimano 600 components attached. Can't take anything.........
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
The standard eight-point, 32mm locknut flats are featured on most vintage bike's headsets, and the earlier Shimano alloy headsets are no different.
While the Shimano headset has some metal scalloped away from the wrenching area, the normal contact points (nearer to the corners) for the wrench are left intact, so work perfectly with standard wrenches.
Since alloy headset wrenching flats tend to get dented at the corners (rounded in extreme circumstances), Shimano developed a wrench shape interface that better supported multiple corners. It's a better headset wrench for delivering greater torque with less damage near the corners to the wrenching flats.
In lieu of any special tools, and wanting to achieve better tightening using less wrench torque, I first tighten the headset normally, but at reduced torque.
Following this, I reposition the wrenches to different pairs of flats, and repeat the tightening at reduced torque.
What happens is that the threaded bits ovalize slightly in response to pressure against any opposed pair of flats, allowing each subsequent tightening effort to move the wrenched pieces tighter together, finally arriving at full tension as if much heavier torque had been applied initially.
The above process is especially useful when any cable hanger or reflector bracket needs to be kept centered while the wrench tightening is going on, since the centering peg or flat within the hanger/bracket's 1" hole usually allows a lot of off-center freeplay on the steerer's groove or flat, thus allowing unwanted rotation of the hanger/bracket.
One can use reduced torque on just the top wrench while using an elbow, knees or thigh/hip to prevent the handlebar from drifting out of alignment with any cable hanger or bracket while the threaded parts are moving and settling into final tightness and position. The hanger/bracket can often be held from turning using only a bare free hand as the top nut is secured from different pairs of flats at a reduced torque level.
It does help further if all threads and adjacent flat surfaces are greased first, and if several re-positionings of the wrench(es) are used to arrive at final tightening.
So the Shimano headset wrenches are ideal, but not necessary if good, normal headset tools are at hand.
Likes For dddd:
