Tire Stretch ???
Bikes: Cannondale R600 and Beater MTB
Quoted: 9 Post(s)
Tire Stretch ???
I had a Michelin tire in reserve that I was not able to get on the rim by normal means. I got a KoolStop tire jack thing and was able to easily get it on and did not pinch the tube. The question is, if I make it for several rides without having a flat, will the tire have stretched enough that I would be able to get the tire back on the rim without the KoolStop gizmo? I do not have any room in my below-the-seat bag to carry it. Kindly - Don
Quoted: 504 Post(s)
Liked 637 Times
Should Be More Popular
Quoted: 22571 Post(s)
Liked 8,918 Times
Quoted: 6177 Post(s)
Liked 4,794 Times
A definite maybe.
Still depends on how good you are at keeping the rest of the tire bead of the side you are try to get on or off pushed to the middle of the rim so it'll give you the least trouble.
But it does seem that as mileage on the tire goes up, that they do get easier to get on and off. Or maybe I just get on better terms with the individuality that tire wants to express! <grin>
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
How could any of us know that? Try and see for yourself.
Quoted: 365 Post(s)
Liked 418 Times
My experience is that wire beaded tires tend to loosen with use, so used tires can be easier to get on the rim. However, when I was running Michelin ProRace3 tires on Campy rims, it was always a b!tch and a half to get the tires on the rims, no matter how old they were. Sorry, it was quite some time ago, I'm not sure if the tire had wire or kevlar beads, I've heard that kevlar bead tires do not stretch. Eventually I gave up on that tire/rim combo, I switched to Vittoria Rubino Pro Slicks. It was not that hard to get those tires back on the rim on the side of the road.
If it was me, I wouldn't ride without the tool unless I knew from experience that I could get the tire back on the rim without it. Speculation (especially speculation from people on the internet) wouldn't be good enough for me to risk leaving the tool at home. If you can't fit it in your saddle bag, can you put it in a jersey pocket? Handlebar bag? Frame bag?
Quoted: 215 Post(s)
Liked 299 Times
I was runnign a wheel and tire set a while back that was super hard to get the tires on and off. Sometimes took over a day because I would tire my hands so much I had to stop. Note: I used all manner of tools. The combination was almost impossible. The worst when new, but only marginally better if worn.
I was runnign tubeless, but still took a spare tube and such. But I questioned the reasoning as there was zero chance I could have got the tire on and off on the side of the road. Of course it was unlikely I would need to. I carried tire plugs and used them a few times. And I even carried a boot if I slashed the tire. But realistically, I would have had to phone a friend.
If replacing a tube is likely, I would carry the tools you know will work. Like other suggested, try at home with the tools you currently carry and see how it goes.
Likes For Mtracer:
Cheerfully low end
Quoted: 644 Post(s)
Liked 1,044 Times
You can’t assume it will stretch. I ran a set of Compass (now Rene Herse) 26ers and they were horrible to take on and off through their full lifetime of many thousands of miles. Still a pain when I took them off to replace them (with different tires that are easier to work with).
Otto
Otto
Pennylane Splitter
Bikes: Yes
Quoted: 1783 Post(s)
Liked 1,436 Times
Different brands/models of tires work differently with different brands/models of rims. When I buy a new tire I check it at home and if its not easy to get on/off the rim its going to be worse on the side of the road in the middle of nowhere. I'll take the tire (and usually the wheel, too) back to the LBS and get another brand/model and try that out.
Quoted: 1079 Post(s)
Liked 1,019 Times
In my experience, most lower level tires don't really stretch, higher end tires that use softer rubber compounds with higher thread count cotton casings will stretch over time and use. Had to use a tire jack to get my daughter's Challenge cross tires installed the first time last week and it was still an effort. We did over an hour in the woods on them and a couple days later another 20 miles on the local trail and yesterday I was able to easily swap out the tubes for latex tubes using one thin tire lever to make sure the tube wouldn't pinch. Some combinations will always just be awful and nothing will fix the problem other than a different tire.
Over the hill
Quoted: 995 Post(s)
Liked 1,203 Times
As mentioned above, the only way to find out is to try it. One trick I learned years ago that still seems to impress riding buddies: Put the wheel on the ground with the last bit of unseated bead on the ground. Grasp the tire with both hands (one on each side) near the top and push down HARD as if trying to pull the tire down. Repeat that again with the hands a few inches down, then again a few inches down, etc. until you reach the bottom of the tire. Then try to finish seating the bead. Most of the time, that makes it easy enough for me to do with my bare hands... except for a few kinds of tubeless tires.
It's like riding a bicycle
Likes For urbanknight:
Quoted: 18349 Post(s)
Liked 4,502 Times
I'm not as excited about the new generation of "tubeless-ready" rims. They have a little middle dip. And, you have to really get the tire worked down into that center recess.
The old cloth tape can be problematic with some tires. I'd encourage finding some kind of plastic tape that you like.
Veloplugs are a unique option.
https://www.velocityusa.com/product/...ries/veloplugs
They don't fit all rim types, but can minimize the thickness of the rim tape. Although, I've put a thin layer of electrical tape on top of them.
Old fart
Quoted: 3582 Post(s)
Liked 3,394 Times
Get a VAR bead jack to carry on rides. It's more portable than the Kool Stop and includes tire levers for removing the tire from the rim.
Never saw that one before, I may have to give that a try. Every since I severed a bunch of tendons and nerves in my hand installing tires has become less fun than ever.
climber has-been
Quoted: 3406 Post(s)
Liked 3,538 Times
Ride, Rest, Repeat. ROUVY: terrymorse
Old fart
Liked 3,394 Times
There is also this TyreKey.
https://www.crankbrothers.com/products/speedier-lever
