Very slight play in rear hub = acceptable
Quoted: 75 Post(s)
I repacked the hubs on all my bikes (part of my spring maintenance routine) and after reinstalling the rear wheel on my road bike (Shimano 105 hubs) I was able to detect a very slight amount of play in the hub. I'm talking the amount you have to recheck a couple of times to assure yourself it is actually there. The skewer is closed and appropriately tight. Is a tiny amount of play in the rear hub acceptable, or should I disassemble and readjust? Normally I'm pretty OCD but this is such a tiny amount that I could not detect it with the wheel off the bike. The wheel spins true and smooth.
It's not the work of redoing it, I'm just curious as to if there is any reason to redo it.
Quoted: 75 Post(s)
Thanks for the reply. With the wheel on the bike, on the stand, when I hold the seat stay and rock the rim back and forth, the play is barely perceptible by feel.
Yeah, it wouldn't take much to fix, and I probably will do that. I was just wondering if it really matters for such a tiny amount of play.
Probably fine but I try to set mine up so I feel that play with the qr about 60% closed. Then when I close it the rest of the way it takes the play out.
It's a quick fix. Just grab your cone wrenches.
Really Old Senior Member
I'd just crank down on the QR a bit more.
Quoted: 2026 Post(s)
Liked 1,095 Times
If the play is only .5 mm at the rim, a 1/4 turn at the cone will probably ruin the bearings. I find I have to adjust the cone and locknuts in only low single digit degree increments to refine the bearing play.
Likes For HillRider:
Quoted: 1422 Post(s)
Liked 7 Times
With a top quality Campy or Dura Ace hub, you might want to go 1/8 turn to dial something in perfectly.
Liked 1,095 Times
Not really. Shimano axles are 10x1mm, so 1/4 turn = .25mm (0.01") of adjustment. If it's already loose, there's no way that's going to make it tight enough to ruin anything.
Close enough may be good enough if you are working in a rush but we aren't.
On the subject of Campy hubs, they are adjusted with the wheel firmly clamped in the dropouts so getting to the point of exactly zero rim play, but not tighter, is very easy. Shimano hubs require a bit more finesse and "Kentucky windage" to get exactly right.
Quoted: 75 Post(s)
Thanks everyone.
The point I was trying to get at was is there a downside to leaving that tiny amount of play? Will it cause any damage or problems over the next 1,000 miles or so before I check the hubs again?
Agreed that the final adjustments are very small, a couple of degrees with the cone wrench. I like HillRider's analogy to Kentucky Windage and that is what happened, I was getting close and undershot on getting out that last bit of play. I can easily correct it but was more interested in what would happen, if anything, if I left it until the next time. My wheels get serviced each spring and checked again about mid-season.
Wheel Bearing adjustment by Jobst Brandt
There is a chance of damage. There should be a small amount of preload when the wheel is installed.
Thanks everyone.
Play is bad. It willeventually score the cups races because with a loose adjustment all the weight on the wheel is concentrated on a couple of bearings. With a properly adjusted bearing all the weight is equally distributed over all the bearings.
Back in the day i used to see destroyed campy cones and rsces because the racer boys who were obcessed with minimising friction set their bearings loose thinking it would make a difference.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Bikes: Cannondale SR's and ST's from the '80's
Quoted: 340 Post(s)
Liked 46 Times
What I have found to often be the case is that there may exist a tad of play at one spot in the rotation, say with the valve stem at 12 o'clock for example, but there may be no discernible play when the valve is at 3 or 6 or 9 o'clock. When I encounter this, I leave well enough alone, as removing the play at one position may result in a bit of a tight situation at another location in the revolution of the wheel.............
Super Moderator
Quoted: 1173 Post(s)
Liked 923 Times
TINY amount of play when wheel is in rotation. I noticed that the axle is VERY slightly bent, and wondering if that's the cause.
Left the tiny play in because when taking it out, the bearings began to "groan".
Advanced Slacker
Quoted: 2749 Post(s)
Liked 2,516 Times
Quoted: 497 Post(s)
Liked 622 Times
1/4 turn is WAY too much for what the OP describes. I did a series of experiments once on the effect of tightening quick releases vs. cone adjustments and what the OP describes would be removed by 1/32 (one spoke hole) turn of the cone. As ot the question, this amount of play at the rim is not going to cause damage or increase wear. Better to have a little play than have binding as the hub rotates against the axle.
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1105 Post(s)
Liked 213 Times
Internet is always full of different opinions - here's my 2c:
If a hub is not pitted/damaged, I always set it to zero play.
Testing when the quick release is tightened, of course - for hubs with a quick-release mechanism.
I use two old spacers to tighten against them, so I don't have to re-mount the whole wheel then fine-tuning the preload.
Never had any problems or premature wear that way - hubs last over a decade if regularly serviced.
The thing is - 1/16 of a turn of the nuts is used to eliminate any play. Looking for that spot when the play is just gone, without any extra preload "on top" of that.
Yes, many hubs have a spot in their rotation where the play just exists - even when the axle looks perfectly straight when rolling it over a flat surface.
Even with those, I aim for zero play even on that "just one spot of the whole rotation."
A little bit of play is better than too much preload, definitely.
Still, I'd say that zero play (without too much preload) is better than a bit of play.
Just in case - to state the obvious:
When the wheel is mounted, the rim might move a bit as it flexes, but the play is noticed as completely free movement, without any resistance, then you feel it "hit" and afterwards, any extra movement is just flexing. Not sure if I've explained it properly (or whether it needs explaining in the first place ).
A long, detailed, boring and tedious demonstration of how I've been doing it over the years - any corrections are welcome:
Quoted: 1935 Post(s)
Liked 2,148 Times
There will never be a consensus to your question. For everyone who leaves no play and 30 years later the hubs are perfect, there will be someone who leaves a slight amount and 30 years later the hubs are perfect.
It is ironic that no one has ever developed a tool to measure pre-load on cup/cone adjustments. I’m of the opinion that good quality hubs operate at low enough ranges of stress and heat that it is probably moot as long as it is not too tight or too loose.
My personal preference is to adjust so there is a skosh amount that disappears, or not perceivable, when the skewer is tighten. It also makes the most sense to me. It has prevented the bike from swerving to far to the right or to the left.
John
John
Quoted: 4742 Post(s)
Liked 3,860 Times
My personal preference is to adjust so there is a slosh amount that disappears, or not perceivable, when the skewer is tighten. It also makes the most sense to me:
John
John
I've noticed some hubs are harder to adjust perfectly than others. I suspect thread type and quality makes a real difference. Some hubs feel as though there is a randomness to the adjustment; that even with the cone not moving at all, tightening the locknut results in varying outcomes at the rim. Campys tend to be a joy to work on. Perhaps this is due to very accurate cut threads as opposed to the rolled threads common on Japanese bikes. (Rolled threads are the stronger and more durable. Also less prone to stress crack starting so the axles are less likely to break.) So I roll with it. I set lower standards of "good enough" for those harder to adjust hubs. Having just written this, I had the thought that the best hub I've ever owned for staying perfect forever is a beautiful Sanshin Pro-Am where I replaced the cones with Campy. (It was my training wheel for my 9k/year racing days. Many wet fender-less rides.) The Campy cones were a force fit the first time on as the V-shaped threads had to get "rolled".) Those Sanshins were some of the best traditional hubs ever made and the replacement cones were from that Italian company known for its quality.)
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3846 Post(s)
Liked 6,437 Times
If I can't remove the play by tightening the skewer (without over tightening it), then it's time to readjust the hub. I don't like to ride with any play in the hub.
Quoted: 4171 Post(s)
Liked 3,791 Times
