Suntour XC Pro Hub, Axle Replacement or Cold set frame?
Old 06-07-22, 10:38 PM
Piff
Piff's Avatar
Quoted: 469 Post(s)
Liked 227 Times in 147 Posts
Hi,
Haven't been on here for a while! But, back into the fray.
There's a 90s mountain bike I'm interested in that has 135mm. Unfortunately, the wheelset I'd like to use with it is 130mm OLD. Plus, the hub is a Suntour XC Pro (freewheel variety), which I'm assuming may take a special axle?
Would it be recommended to simply cold set the bike from 135mm to 130mm? Or is the axle swap easy?
Thanks.
Piff is offline
Old 06-08-22, 12:19 AM
icemilkcoffee
icemilkcoffee's Avatar
Quoted: 884 Post(s)
Liked 781 Times in 471 Posts
Axle swap is easy enough. But are you sure you want to run a freewheel hub on a mountain bike? These are prone to bent axles even on road bikes.
icemilkcoffee is offline
Likes For icemilkcoffee:
Old 06-08-22, 06:06 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3119 Post(s)
Liked 2,345 Times in 1,389 Posts
If the axle is sufficiently long, you could just use spacers to fit the wheel into your frame. @icemilkcoffee's point about bent axles is valid, but you could minimize this risk by putting the spacers on the non-drive side and re-dishing the wheel.
JohnDThompson is offline
Likes For JohnDThompson:
Old 06-08-22, 06:43 AM
delbiker1
Mother Nature's Son
delbiker1's Avatar
Quoted: 694 Post(s)
Liked 1,011 Times in 593 Posts
I do not know mountain bikes, but is the frame steel?
delbiker1 is offline
Old 06-08-22, 10:56 AM
esasjl
Bikes: '84 Chas Roberts, '91 Peugeot Galibier, '90 Gitane Leader, '51 Dayton Elite, '90 Verago ATB, '08 Dawes Sardar
Quoted: 13 Post(s)
Liked 100 Times in 27 Posts
Respacing the non-drive side and redishing as suggested will also even up spoke tensions and improve wheel robustness. I'd also consider an outrigger bearing supporting the freewheel.
esasjl is offline
Old 06-08-22, 09:08 PM
Piff
Piff's Avatar
Quoted: 469 Post(s)
The bike won't be used really as a mountain bike, so I'm not worried. Mostly intended as a do-anything commuter, pleasure rides, and fire roads.
Good to know, would this be serviceable? New Shimano Rear QR Axle for 135mm Drop-outs w/ Cones & nuts Y3CE98020 Y3CC11000 | eBay
Yep, steel! Though quite thin steel...probably best not to bend it I suppose.
The outrigger bearing is an interesting idea...but perhaps a bit beyond me. Re-dishing sounds like a good idea.
Piff is offline
Old 06-08-22, 09:44 PM
WelcomeSir
Liked 11 Times in 5 Posts
I've cold set 2 different road bike frames from 126mm to fit modern 130mm hubs. One of the frames I actually bent from 126mm to 130mm, back to 126mm, and recently back to 130mm. If I did that within a 5 minute period I'm sure it would be a bad story, but I've ridden it extensively without a problem. Steel is real!
Check out RJ the Bike Guy's video titled "Check and Align a Bike Frame" on Youtube. It shows how to make sure the frame is evenly spaced after cold setting. I would have more confidence making the chainstay and seatstays smaller in your case than to "bow" them outward like I have. Road bike chain/seat stays are more likely thinner walled and diameter tubes than a mountain bike so you should be OK. Just my opinion, though.
The long axle and washer/spacer idea is a good idea as well.
Good luck!
WelcomeSir is offline
Old 06-08-22, 10:00 PM
70sSanO
70sSanO's Avatar
Quoted: 1797 Post(s)
Liked 1,927 Times in 1,185 Posts
I’ve re-dished a number of wheels doing a 126/130 conversion. I have yet to run out of spoke threads, but I don’t have the background re-dishing 2.5mm. Since it has been suggested by others, I would have to assume it will work.
Re-dishing with NDS spacers to 135mm OLD definitely makes a stronger wheel.
Since you can do whatever you want, you don’t have to go to 130mm or 135mm. Some mfg’s made frames to accommodate both by setting the dropouts to 132.5mm; they also did this at 128mm in the late 70’s.
You can build a wheel to 132mm or 133mm (with NDS spacer(s)) and not change the bike’s dropouts. You’ll just re-dish a little less. You have to get a new axle anyway. Cut it to the length you need.
John
70sSanO is offline
