Bolt on to quick release advice?
Bikes: 1995 GT Avalanche
I just bought a Zizzo Urbano and was thinking of converting the wheels to quick release.
Does anyone have experience making this conversion or advice on parts needed?
An Amazon link would be nice or any specs I'd need.
Thanks,
Grape
Thanks,
Grape
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x9,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 249 Post(s)
Liked 221 Times
You will need to swap the axles and depending of the hub, either remove the bearing and cups or make sure it fits the sealed bearings.
Cannot say much more since we don't know what wheel/hub you have.
I personally cannot see the advantage of quick release. if it is for puncture repair, just add a spanner to the repair kit you have to carry. Modern bikes are going away from quick release and use through axles that can be removed with multitool.
Likes For Fentuz:
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 452 Post(s)
Liked 405 Times
You can get a conversion kit for $10 and then follow this video:
Paul Pinigis
Owner of Origami Bicycle Company
Paul Pinigis
Palmer
Bikes: Mike Melton custom, 1982 Stumpjumper, Alex Moulton AM, 2010 Dawes Briercliffe, 2017 Dahon Curl i8, 2021 Motobecane Turino 1x12
Quoted: 1646 Post(s)
Liked 1,785 Times
If your axles are 3/8x26 or M10x1:
https://www.amazon.com/Axle-Release/...n=Axle+Release
You screw these on both sides in place of the hex nuts.
Likes For tcs:
