NEW tubular stretching ideas?
I bought new Tufo tubulars(for my '86 Trek 2000. They are impossibly tight, no possibility of me getting them on the rims. I have no spare rims, clincher or otherwise, and I doubt these tires would go on any 700c rim in their current state.
I find 10,000 old posts telling me that tubulars need to be pre-stretched. I get that. I find 1,000 telling me to put them on old rims. No can do. I've read that pumping them up to pressure, without being on rims, is a bad idea for a couple of reasons. I've tried stretching them by hand.
I need other ideas for stretching these tires. Jokes are fine, but seriously, I want to use them before the snow arrives in Minneapolis.
Likes For jimh12345:
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times
Put them around a broomstick, stand on it while twisting another rod at the other end with your hands? Or find somewhere where you can hang them, with enough room/height for you to hang on the tyres yourself?
Not sure the twisting will do much good for a tubular or any tyre for that matter, so maybe ditch that part of the suggestion.
Quoted: 2337 Post(s)
Liked 2,820 Times
here is what i did....put something soft on the floor so you can put the rim on it and push.
put the valve in and with the valve at 12 oclock start puting the tire on evenly on both sides. (no air in the tire at all) get it on a bit and hold both sides and push down, stretching the tire. hold for as long as you can and them put the next section on, keep doing this until you get the whole tire on....it can take 5 or 10 minutes......then inflate the tire to 100lb or so and let it sit at least over night. then you can take it off and tape/glue it on.
if gluing here is the best tutorial i have seen (and it show the stretching sorta) Tubular Tire Mounting Cement Gluing Adhesion by Yellow Jersey; Thoughts on a Front Wheel
Quoted: 1088 Post(s)
Liked 1,022 Times
How do you stretch by hand? When dealing with an unstretched tire that had to go on that day and was too tight we'd put two feet on the bottom and pull up by hand, took some actual force. If we had time to let them stretch then put in the valve and start working the tire around with both hands just like normal, when you hit a certain point where you can't get more on by hand use a spring clamp on the rim to keep the tire from popping off on one side and use the tire levers along the other. You don't have to put real space between the levers, just keep moving them along, first one then the other till the tire pops on. If you have to put this much work in though, really take the time to stretch the tire for several days at full pressure or you'll make a mess with the glue.
Blamester
I installed tufo tubs recently and they where tighter than I remembered.
Can you use a lever to get them on dry.Pump them and leave for a while.
Or you can pump them before install just don't go crazy.
Quoted: 1607 Post(s)
Liked 2,216 Times
You can surely find a rim, doesn't have to be a tubular rim.
Quoted: 3808 Post(s)
Liked 6,679 Times
I take it you've tried to install them on your existing rims without glue or tape? If not, I suggest using a toe strap or a zip tie to hold a section in place while you tug like mad (or use a tire iron) to install around the rest of the rim.
I've tried manual stretching using leg muscles. Maybe Captain America could do it, I couldn't get enough stretch to make even a noticeable difference. These tires are TIGHT. Some combination of clamps, zip ties and levers might eventually get it there. I'm trying to think of a way to stretch it, maybe by making some sort of expandable jig. ...
I tried everything, stretched them as hard as I dared, tried zip ties, levers, hot air gun. There is no way these can be mounted; the amount of force it would take to get that last inch would destroy the tire or damage the rim. I don't think all my stretching made a bit of difference. I Googled these tires and found some other complaints about how hard and stiff they are. Most people were able to get them mounted somehow, but some said they couldn't be stretched and would be no good as a spare.
They are Tufo 700 24 S33 Pro. Something is wrong here; either a material has been substituted or there's a dimensional error. I'm returning them to Amazon.
Can anyone recommend a current tubular that's not difficult to mount but still has good puncture resistance?
WGB
Bikes: Panasonic PT-4500
Quoted: 1799 Post(s)
Liked 2,334 Times
I installed valve first. Got as far as I could with fingers. Then used two steel Park tires levers until I hit the wall again. Then got my son's to help. I held the tire against my waist. He used the levers and I used my thumbs. Lot of muttering bad words. Key is to have an assistant willing to listen but having just one extra hand can make all the difference. Having someone help might save the install.
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,059 Times
I had to REALLY exert myself to stretch some Conti tubs onto dry rims. Contis are known to be tight in many clincher models and this is the first pair of Conti sewups I have tried...also VERY tight! But a combo of pre-stretching and then doing as others suggest "anchor" them at the sections when you get them on (I used tape but toe-straps, sure, whatever works) and work your way to the "Hail Mary" section when you have to grunt and roll them on. Was filled with a feeling of victory, soon faded...
One bit of materials trivia: heat causes MOST rubber to shrink, not to expand. I thought this would be my secret weapon but after having tucked the Contis into a plastic bag and then in my freezer for an hour: no difference I could tell. Neither better or worse, just colder!
I've mounted tubulars several times, no big deal, I know the drill. I tried stretching these with the knee-shoulder method, really layed into it, it made no difference at all. Tried working my way around the rim and using zip ties at intervals. I had a way rigged up to stretch it, hard, as I went, plenty of leverage. Could not even really get close - there was no way it was going to happen without damage or injury.
I don't know what Tufo is thinking here; maybe their manufacturing quality has suffered due to the virus. But there's no reason mounting tires should be this difficult. I'm sending these back to Amazon tomorrow.
Then I'll take a little more time to find a better tire that can actually be pre-stretched and mounted by one person.
Liked 6,679 Times
Yeah, seems like there's something defective with those tires. Send 'em back!
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
I'm a firm believer in using a rim (preferably tubular, but I've used a clincher on occasion) and with a large tire iron and very large screwdriver. Just work it on inch by inch. And immediately inflate to 100lbs. pressure. Then, I've been riding nothing but Vittoria Rallys for the last fifteen years, and have gotten spoiled.
Syke
“No one in this world, so far as I know — and I have searched the records for years, and employed agents to help me — has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.”
H.L. Mencken, (1926)
Syke
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,194 Times
My advice is to not give up--- but it certainly does seem as if you've really given it your best shot so far.
As far as a tire recommendation, I've also ridden Continental Gatorskin tubulars and not had any flats, but--- YMMV. They were easy to mount.
Bob
Bob
I really appreciate the sanity checks from you guys sharing your stories. Now I don't feel bad about sending these back for a refund. Tufo has gone off on some sort of weird tangent here. Maybe they're trying to get known for making the 'toughest' tire regardless of the tradeoffs.
I'm not going to damage these nice classic rims with big screwdrivers, or end up with a tire glued on crooked. These go back today.
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 345 Post(s)
Liked 174 Times
I’ve had good luck with Veloflex tires. The Vittorias I’ve used have also been easy to mount. I do not even consider tires with a reputation for being tight no matter how good the price.
Quoted: 3464 Post(s)
Liked 2,828 Times
Make sure they are not 650c
I always found brand new tubular tyres to be very hard to stretch on to a rim. I always put my foot in one end and slowly physically stretched them by pulling with my hands. I would immediately after try stretching then on to a rim without glue, just dry. You can usually manage after a bit to get it on the rim. Then inflate it hard and let it sit over night. Usually that does the trick for when you go to glue them on. They ride fabulously but I haven’t used them in twenty years because of all the typical issues.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Or ask local bike shops.
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 296 Post(s)
Liked 675 Times
I just found this thread because I've got the same issue.
New pair of Tufo S33 Pro 24 Tubular with Tufo 19mm Road Tape.
(Red stripe version because it's £10 cheaper)
Fitting them to Mavic Monthlery Route 700c (21.5mm).
Watched the very nice Tufo Youtube video and it looks fairly easy.
Comes to actually putting the tyre on the rim and no way.
Tried stretching it by putting feet either side of the valve and pulling with both hands, no obvious progress.
Then I had an idea: ratchet luggage strap
Turned a bench upside down - the bench legs are 3 feet apart.
Put a folded towel round one leg and I'm stretching the tyre round that with the ratchet strap round the other leg.
I'll leave it for several hours to see if it works, but I should be able to ratchet it out as far as required.
Wheelman
Quoted: 296 Post(s)
Liked 675 Times
Unfortunately I'm just getting back into bikes after about 25 years off, so I've only got the 2 rims I'm trying to put the tyres on.
And it's my first go at fitting tubular.
I did try dry mounting on the other rim but it wasn't going to go on.
Hence the search for how to stretch them.
I'm fairly certain the ratchet will solve the issue though.
A fun thread. I'm picturing a Monty Python skit about "mounting the unmountable tire" wherein a series of escalating attempts all end in disaster.
I returned those Tufos, and bought some very ordinary tubulars (Servizio Corsa, from YellowJersery.com). They went on without any great difficulty, just like I remembered from years ago. They run true and feel good. Unforturnately, one did go flat after not too many miles; a sharp piece of road cr@p stuck to it and burrowed in (I probably can't ride inner city streets with these tires). So, I got to mount another - again, no problem.
I used to use Panaracer Practice Dual Tour Guard tubulars, with kevlar. They were mountable, and lasted forever. But I never liked the red sidewalls and don't want to go back to that look.
Wheelman
Quoted: 296 Post(s)
Liked 675 Times
Yep, I'm prepared to not like the red colour after a while, luckily my Holdsworth is red so it might work.
If I like tubulars I might get some 'better' ones when I've got more idea what I'm doing.
Also S33 Pro 24mm on Wiggle.co.uk:
black - £29.68
tan stripe: £21.99
red stripe: £18.99
So the red has a £10.69 advantage
Those have to be about the cheapest tubulars around.
black - £29.68
tan stripe: £21.99
red stripe: £18.99
