Rear Wheel Hub Design Question
Old 10-22-17, 05:12 AM
3speed
Quoted: 363 Post(s)
Liked 28 Times in 22 Posts
Wouldn't it make sense to have a slightly larger flange on the non-drive side of a rear hub, in order to make the spokes the same length for both sides? Then you could just use spokes of the same length rather than needing two different sets of spokes. Am I missing something, or is it just that it's not a real concern because spoke breakage isn't a very common failure?
I'm looking at the VO touring hub that can be broken down without tools, so you can replace spokes, etc. If companies don't worry about spoke breakage because it isn't a real issue, wouldn't that mean a hub like this isn't really necessary to begin with? Would I be wasting my money for something that isn't really a problem?
3speed is offline
Old 10-22-17, 06:05 AM
BobG
Quoted: 316 Post(s)
Liked 116 Times in 81 Posts
Yep! Phil Wood does exactly that on their rear touring hubs. 57.8 mm on non drive side flange, 54.5 on drive side flange. Here are the results for my wheel on a spoke length calculator...
EDIT: Apparently the flange size difference is only on the older Phil Wood hubs. See posts 17 & 18 below.
File Type: jpg
File Type: jpg
BobG is offline
Old 10-22-17, 06:10 AM
dabac
Quoted: 1074 Post(s)
Liked 295 Times in 222 Posts
It would make sense from the home mechanic’s perspective.
But its not as beneficial for the wheel building factory. They’re already set up to cope with plenty of different spoke length. Having two sent to the build station is no big deal.
Spoke breakage DOES happen. But not that often. And even if both sides take the same length spokes, you still need to have that length available.
dabac is offline
Old 10-22-17, 06:11 AM
andrewclaus
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 674 Post(s)
Liked 738 Times in 429 Posts
I don't have personal experience with that hub, but the video I just saw looks like you have to remove the cassette before you can service the hub "without tools." So you'll still need a cassette removal tool to change spokes.
andrewclaus is offline
Old 10-22-17, 06:20 AM
tmac100
Bikes: More bicycles than I can ride at one time: 2 custom made tourers, a Brompton 6-speed, and an Indian-made roadster.
Quoted: 132 Post(s)
Liked 18 Times in 12 Posts
I presume you are referring to the VO hub mentioned by the OP. FWIW, my PW rear hub does not need a tool to take the rear cassette off the hub. Nice and handy, but then I have not had any spokes break on that 48 spoke hub while riding - only once in an "accident" when the RD went into the wheel after the black idler wheel came off (screw unscrewed.
tmac100 is offline
Old 10-22-17, 10:09 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Dish still is required to get the cluster of all those cogs in, and so an IGH, Dishless, still makes a stronger wheel .
that being said I got a lot of tours done with an old Phil 48 spoke rear freewheel hub, had a couple spare spokes in all 3 lengths ,
in my panniers , only ever needed one, , drive side, naturally ..
only needed to bring freewheel remover, borrowed the Big wrench from a local, then we went to the Pub for pints.
fietsbob is offline
Old 10-22-17, 02:00 PM
Tourist in MSN
Quoted: 3450 Post(s)
Liked 1,449 Times in 1,130 Posts
I agree with dabac, a wheel manufacturer that builds up lots of wheels has no incentive to pressure the hub manufacturers to do that. A wheel builder that only makes a small number of wheels is unlikely to get the attention of a company like Shimano.
I used to buy spokes from a local bike shop, they had a good price on the spokes to build one wheel plus they threw in a few spares. But they moved out of town, other local bike shops want a fortune for enough spokes for a wheel. So now I buy in bulk on line when I build up a wheel. I use Wheelsmith spokes, that means buying a bag of 50 for each length.
I used Sapim nipples for my last two pairs of wheels. On the most recent rear wheel that I built, I used these nipple washers on the drive side. They add about 0.7mm to the length of the spoke that you need.
Round PolyAx (HM) Washers (20 pieces)
By using those nipple washers on the drive side, I could use the same spoke length on both sides. I am not saying that they will always save you from needing two lengths, but in my case they did.
Tourist in MSN is offline
Old 10-22-17, 02:12 PM
seeker333
seeker333's Avatar
Bikes: yes!
Quoted: 282 Post(s)
Liked 38 Times in 36 Posts
Originally Posted by 3speed
Wouldn't it make sense...
It would be nice if only one length spoke was required for a bike but it's not that big a deal to carry spares in 2 or 3 lengths. More important would be to design rear hub spacing/diameter to minimize dish, to increase wheel longevity for loaded touring use. AFAIK the only cassette hub that offers zero dish is the 145mm DT Swiss 540, used by CoMotion for touring singles, which is a $310 hub on sale. Phil Wood used to make the FSA hub with very little dish (in the 7s freewheel version), a custom version sold by Rivendell, which has been discontinued.
The only advantage of the VO GC hub over a Shimano XT is it's replaceable sealed bearings with no possibility of bearing cup wear, so potentially a longevity advantage - but also consider that the VO hub costs as much as 3-4 XT hubs.
Originally Posted by fietsbob
Dish still is required to get the cluster of all those cogs in, and so an IGH, Dishless, still makes a stronger wheel...
AFAIK the only truly dishless IGH is Rohloff Speedhub (29mm flange spacing/100mm PCD both L&R). IGHs generally do reduce dish over cassette hubs but the only one that has symmetric flange spacing and diameter is Speedhub.
You can build with asymmetrically-drilled rims to reduce dish, Velocity sells a couple models (A23 and Synergy, discontinued).
seeker333 is offline
Old 10-22-17, 02:23 PM
FBinNY
Quoted: 5756 Post(s)
Liked 2,524 Times in 1,395 Posts
To start with the effect of flange size varies either the number of spokes and crosses. It's greatest with a radial pattern where all the spokes go to the edge of the flange. It's least, approaching zero, on a full tangent build, ie. 36h x4 where all the spokes come down to the line of the axle. Everything else is in between, but what matters is that actual line the spokes take.
That said, the main goal isn't about spoke length, but bracing angle which determines the tension right and left. In that vein, you'd want to make the right flange bigger, to increase that bracing on that side. Making the left would be counterproductive, make things worse, or at best, having little effect.
FB
Chain-L site
FBinNY is offline
Old 10-23-17, 02:41 AM
3speed
Quoted: 363 Post(s)
No, you can remove the freehub with cassette attached without tools. The point of the hub is largely that you can replace spokes in a pinch without having to use a cassette tool.
3speed is offline
Old 10-23-17, 05:58 AM
dabac
Still, if someone wanted to make a hubset that use all identical spoke lengths, it’d be easy enough to compensate the geometry for the larger diameter NDS flange.
Moving the flange a few mm inwards would retain the spoke path and lateral bracing angle with few to none consequences.
dabac is offline
Old 10-23-17, 08:28 AM
FBinNY
Sorry, but not true with tangent spoke patterns. The spokes lead down close to the line of the axle, so the spoke length is unaffected by flange size.
It same length spokes are desired for some reason, it might be possible by reducing the number of crosses on the right, or on both flanges, then tweaking the flange size.
In any case, the goal of a lower tension different right and left should trump all others. That's done by increasing the right side bracing angle, a goal achieved with a larger right flange combined with reduced cross, ie. The larger flange also mitigates the torsional effects of reduced cross since the spokes pine of action is moved out.
FB
Chain-L site
FBinNY is offline
Old 10-23-17, 09:04 AM
fietsbob
Bikes: 8
[QUOTE=seeker333;19945465. You can build with asymmetrically-drilled rims to reduce dish [/QUOTE]
Though, if rim is narrow all you have is at most is half its width in shifting the holes,
drilling an asymmetric rim extrusion...
(Like drilling a 45mm wide rim, Fairbanks AK, Snow Cats, off center, or the even wider 4" fat bike rims )
fietsbob is offline
Old 10-23-17, 09:09 AM
Tourist in MSN
One thing I find a bit frustrating is front hubs, not rear. I built up a new dynohub wheel last spring, planned to use it on a bike with rim brakes but I thought that some day I might want to be able to use that wheel with a disc so I considered using a disc type hub. I understand why SP used a larger diameter flange on the disc side, but why could they not use the same flange diameter also on the other side? It is an undished wheel, but I still would have had to buy two bags of spokes for that wheel because they used different flange diameters.
https://www.sp-dynamo.com/8-series-pic/PD-8-QR-01.pdf
Since it was for a rim brake wheel, I bought the non-disc version of the hub to avoid the extra cost for spokes.
Old 10-23-17, 03:59 PM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6192 Post(s)
Liked 4,190 Times in 2,351 Posts
I'm not sure where you are getting your dimensions. For the ones listed on their website, they are both 59mm. All the ones I've worked with...3 sets...have the same dimensions on both flanges.
Stuart Black
cyccommute is offline
Old 10-23-17, 05:11 PM
BobG
Quoted: 316 Post(s)
Cycco, I'm using the hub dimensions chart at the PW website. Spoke hole diameters (called hub flange diameter at calculator above) of 57.8 and 54.5 on an 8 speed freewheel hub. All things being equal there should be a 3.3 mm difference in flange diameter.
BobG is offline
Old 10-24-17, 08:33 AM
cyccommute
cyccommute's Avatar
You are working off some very old information. All of their cassette hubs have the same flange diameter and have for more than 10 years. My 2005 FSC hubs have the same flange diameter.
Stuart Black
Old 10-24-17, 08:58 AM
BobG
Quoted: 316 Post(s)
I don't know what to say Stuart. My hub is at least 25 years old but if you click on "Phil Wood hub dimensions" at the home page of the current website it will show the same dimensions that I posted for an 8 speed freewheel touring hub. The same numbers are listed for the cassette versions.
Phil Wood & Co.
https://www.philwood.com/philpdfs/whe...ding_break.pdf
Spoke length came out perfect entering those figure into the calculator. I don't have a caliper to measure the flanges on the built up wheel but eyeballing with a tape measure the left flange appears to be a few millimeters larger.
edit: I see the problem now. Phil Wood is posting old numbers at the pdf file. When you click on the various hubs on the home page your numbers come up. They should delete the pdf link from their homepage! That said, my old hub has the two flange sizes. You are correct, they have been changed!
BobG is offline
Old 10-24-17, 09:10 AM
andr0id
andr0id's Avatar
Quoted: 1422 Post(s)
Liked 7 Times in 5 Posts
A lot of cassette bodies just pop off now with a firm pull.
If you get a few extra bodies, it makes swapping cassettes really easy.
My PowerTaps are like that and they are based on DT hubs which also just pull off.
andr0id is offline
Old 10-25-17, 08:13 AM
cyccommute
cyccommute's Avatar
I noticed that too and haven't had time to post. I'm not sure they should delete the PDF but they should update it. There are still some old freewheel Phils floating around out there.
As for the flange sizes, that's what bothered me about the PDF originally. All of the Phils I have are the same size on both flanges.
Stuart Black
Old 10-25-17, 09:18 AM
LeeG
Quoted: 137 Post(s)
Liked 81 Times in 64 Posts
Spoke breakage is very unlikely when the wheel is built for the intended use but just because a component has different features and costs more doesn't mean it's a waste of money. I have that hub. It goes around with a nice buzz.
LeeG is offline
Old 10-25-17, 09:45 AM
fietsbob
Bikes: 8
IDK SP, but Schmidt ,
has a little dish on the front disc 6 bolt *, to make clearance for the disc, but did not use 2 different lengths, per side.
*they call these the 'classic' now .. a black, 32 hole, the left flange is closer to the hub shell center band..
fietsbob is offline
Old 10-25-17, 09:46 PM
bwgride
Slow Rider
bwgride's Avatar
Quoted: 38 Post(s)
I use Shimano Deore hubs for my bikes and find, with 559 (26") rims, the lengths on both sides are nearly the same for both front and rear hubs. Lengths vary from about 263mm to 266mm, so I just use, and carry, 265mm spokes.
bwgride is offline
zacster
Bicycle Mechanics
16
12-15-13 07:26 PM
westyat7000
Bicycle Mechanics
5
04-20-13 04:20 AM
Invictus35
Bicycle Mechanics
10
02-28-12 02:33 PM
Syncmaster
Bicycle Mechanics
30
10-30-11 12:39 AM
tgypoi
Bicycle Mechanics
13
07-12-11 12:35 PM
