Can I use Shimano Alfine front dynamo hub for touring ?
I have no personal experience but I've heard they are a good inexpensive option for a dynamo hub. There are lots of positive reviews online.
sure, why are you hesitant? it's the nicer line from Shimano, they make a cheaper line too .
still makes power
An Alfine option is is the ability to mount a brake disc. QR axle..
https://bike.shimano.com/en-US/produ...0/DH-S501.html
$90 is hub only , see if you can fidd a built wheel,
We have Wholesale sources for built wheels via Bike shops ,
saves money, and you get help with wiring the bike.
still makes power
Quoted: 3418 Post(s)
Liked 1,434 Times
Yup.
Just make sure you notice if using disk brakes that Shimano uses a pos proprietary centerlock brake rotor rather than the simple industry standard. If touring and you need to remove the disk for travel or if it gets damaged, you have to carry around a special tool and big wrench to remove/install it. Otherwise you end up stuck on the side of the road/potentially have a ruined trip. Personally I’d get a 6 bolt hub for touring. It wouldn’t be a big deal for just riding locally where you can just go home and fix the bike there. ...though it stil leaves you stranded until someone can come get you if you get a bent rotor that needs removal in order to ride the bike home or something.
the same tool as used your shimano freehub lockring, works..
But does not have to be as tight. (should not, as its of aluminum, not steel )
Yes, that special tool, and a large wrench, rather than just the hex on your multi-tool for every other brake disk ever...
Quoted: 223 Post(s)
A lot of folks carry one anyway, and IME the centerlock rotors really aren't bad if you fly your bike a lot. It's a little less fiddly when you pull the rotors off the wheels to avoid damaging them in flight. Also don't need a "large wrench", I have a small insert that lets mine work just fine with any 10mm hex wrench.
The only thing that I'd say is a pain with the centerlock rotors is when you have multiple bikes with different standards...which still isn't that big a deal, when you look at things like all the different bb options etc.
Yes. I used my Shimano generator hub for commuting and touring for years. Eventually the rims wore out, and I just moved that hub to a new wheel.
On the disc brake issue: Yes, it's a small pain to have two separate methods for attaching/removing the discs. But for me, the best solution is to find a rear up that uses the Shimano set-up. I find it much easier and quicker, even though the tools involved take up more space. My current front wheels have Shutter Precision hubs, and my rear wheels have Shimano, disc-ready hubs with their proprietary connection. My regret is that I didn't get front hubs that also used the Shimano method.
I wouldn't call that a "special tool" considering that it already has at least one other use.
With regard to the original question, I've found dyno hub use can extend or change the way touring is done in the following ways:
A. It's handy if for some reason you are delayed by breakdowns or actually any particular thing, or need to go further than originally intended. You can continue after dark with no worries about battery state for lighting, to get where you want to go.
B. Likewise, you can start a little before sunrise if you're plan to go a longer distance in one day for any reason.
C. You can tour much more effectively in seasons with shorter daylight hours. This for me has been great, touring is less restricted by season. I also get to see sunrise and often sunset from somewhere picturesque, which I also greatly enjoy.
D. You can keep battery powered items topped up during daylight hours, if you have the correct equipment, which is readily available, as long as your average speed is not very low.
In short, there are many advantages and no real disadvantages. You don't even have to do any of the above listed. But you can if you want, or suddenly need to.
As for the tool, you have to go to a specialty shop and buy a tool that’s only good for the specific purpose of removing that one(or two) particular part. If that’s not a special tool, I don’t know what is...
I’ll trade you hubs if you want. My bike has the stupid Shimano Alfine with center lock. It’s a newer wheelset and I’m sure it has less than 1,000mi on it. I see it as my only real risk on tour. I’m not likely to have a BB fail, or get stranded due to a rear spoke breaking, so not carrying those tools isn’t a big deal to me, but brake disks can get bent easily and this stupid brake disk could well screw me some day. I’m replacing it either way. Let me know if you’d want to trade. If the flange diameters are at least really close, it’s as simple as just relacing the new hub into the wheel and you don’t even need spokes. Mine’s a 32 spoke.
Clark W. Griswold
Quoted: 4230 Post(s)
Liked 3,841 Times
Yes you can, you can use a dynamo hub on pretty much any bike. We just did a really nice conversion on someone's road bike though we went with a SON hub and extra spokes in the front (28 vs 24) but it was an awesome set up. Clean and sexy. I haven't used the Alfine dynamo or any Shimango dynamos but haven't seen or heard anything bad about them other than maybe weight and that isn't really an issue, I would really worry about.
My Single Speed/Fixed Gear RandoCross Fun Time Machine runs a Shutter Precision hub and Supernova lights and my touring bike is running a SON hub with Busch and Müller lights and a Sinewave charger and my commuter bike will be running a Kasei dynamo hub (I was talked into it because Merry Sales was out of SP hubs and they said this was the same so maybe just rebranded or something but I trust them after over a 100 years in business) and some B&M lights.
My only issue would be the Supernova tailight could be improved with some reflectors to help spread the rear light out a little more and help make it brighter and maybe some other mounting options for the rear light. Other than that the front light has been excellent (my mounting could have been improved to remove some tire shadow but I am happy.
Basically I am super sold on dynamo lights and really wish they were more common here in the Americas. Generating my own light and power is sofa king cool. Never running out of light or having to charge lights is excellent and also the charging on my touring bike will be quite nice.
Slow Rider
I currently use the Alfine dynamo on my touring/gravel road/commuting bike. Works very well.
It does have the center-lock disc brake. However, once my current disc brake is replaced, I will install a 6-bolt disc brake adapter and use the more commonly available, and less expensive, 6-bolt version discs. Here's an example of the 6-bolt adapter (e.g. DT Swiss 6-bolt disc adapater)
https://www.google.com/search?safe=o...er+center+lock
I carry such an adapter should I need one on tour.
Quoted: 223 Post(s)
I don’t know you or what strength you may possess, but I think that if you can get those lockrings off with just a short hex wrench, you might not be putting them on to spec. There’s a certain abount of torque called for when installing them, and there’s a reason they’re designed for use with long handled wrenches. Otherwise they’d be smaller and come with a hex wrench hole rather than a large wrench fitting.
I'd actually consider trading but I've got no use for the hub. Why don't you just get a couple adapters for 6 bolt rotors? I'm pretty sure those are a thing.
Good to know about the torque thing. Maybe I’ll carry the lock ring tool and adapter you speak of until I can replace my hub. Kind of annoying to take up the extra space and weight, but at least they’re small tools, and well worth it if I bend a rotor. Better that than stranded. The trade thing was for Rob, but hey, I’m open to any trade if anyone is interested. I’ve considered the centerlock adapter, but would rather just have a hub intended for what I want rather than use a workaround. And not that the Alfine is bad, but when I have the spare “bike stuff” budget to replace it, I’ll get something nicer than the Alfine anyway.
For what it's worth, I have flown my bike around with me a few times now and reinstall the discs after every flight, and I keep a small set of RoboGrip pliers in my tool set, which has been very effective at tightening up the disc brakes. Still not as light as a hex wrench, but when I'm trying to turn a bunch of bike parts into a touring machine in a short amount of time, I'll take speed and convenience. And those pliers come in handy other times as well.
