Removing French BB fixed cup
#51
The stein tool is great and well worth owning. The problem is the spanner. I've had good luck with a 15 inch crescent which will set you back considerably less than a $100 (post 32). The back up is the Sheldon Brown tool described above (post 5).
By the way, I have a 70s era Mercier 300 in the build queue. It came to me with a VO bottom bracket and a stronglight 99 crank. The two worked well together.
Likes For TullySteve:
#52
Quoted: 2350 Post(s)
Liked 1,728 Times
^^^^ Suppose you'd want to plug the tubes and stays as well.....
#53
Quoted: 4493 Post(s)
Liked 6,297 Times
#55
Quoted: 1103 Post(s)
Liked 1,310 Times
I tried the Sheldon Brown "tool" method and couldn't get it to budge, the nut side of the tool turned regardless of the torque I put on the sandwich. I did not find the finer pitched bolt that he spec'd in my local Ace, so I was limited in tightening to a course-threaded bolt. Call to my LBS (I do want to do most of this DIY, but I also want to move on here) resulted in an interesting recommendation: He had me plug the spindle hole with a cork (from inside the BB), lay the bike down with the fixed cup down, and fill the fixed cup & BB above with heated Canola oil and leave it overnight. So that's the current status. He is a seasoned vet and was a certified TDF mechanic & lived in France for several years, so I trust him. He said even if I end up bringing it to them tomorrow, this will help immensely.
EDIT: I may have misled you all into thinking TMWKE would use the dog clutch on anything - not so; I remember the first time hearing about the method as he was explaining to a customer that the cup was so stuck that this was the only way forward and it would mean buying a new bit.
Likes For Charles Wahl:
#57
Liked 6,297 Times
The ManWhoKnewEverything at the LBS in my youth used the bolt-through-the-cup method, but he used a thing he called a "dog-clutch" to grab the cup from the inside. It was a cylinder with a hole through it, one end flat and the other had ramped teeth, angled as on a milling cutter. It *always* grabbed, and the cup was *never* usable afterwards.
#58
Bikes: Yes
Quoted: 3228 Post(s)
Liked 3,853 Times
This is what I meant by taking a photo to determine the thread direction. Andy_K , I presume we're looking at a left-hand (French or Italian) threaded fixed cup, since it appears to unscrew clockwise from the exterior?
The one in my picture is ISO (“righty loosey”). It was on a Japanese-built Gitane.
My Bikes
My Bikes
#59
Disraeli Gears
Whoops!, I apologize for associating "left-hand" and "(French or Italian)" in my previous post and the quote above. Being sorta "schizodextrous", I've had a left-right confusion since childhood. Gaffe fixed in my offending post above.
#60
Passista
Quoted: 866 Post(s)
Liked 711 Times
My son is left handed and also has this problem. If you say him "Turn right (or left) now, quick" he often mistakes sides. Doesn't happen if he has a moment to think, though.
#61
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4669 Post(s)
Liked 5,768 Times
I bought a Raleigh International a few years back that had cross threaded cups (how does that happen???) Fixed cup was on the non-drive side! I clamped it on my vise and used the frame to torque it out.
The adjustable cup tools were no match, for this, so I removed the lock ring and filed flats on opposite sides so I could use the vise method.
After running a tap through both sides, I could put in a new English BB with no problem. I haven't built that frame up, if/when I do I'll probably just use that BB and watch to see if it loosens. My backup plan if it loosens is to use some of the proper locktite. Failing that, my backup-backup plan is to ream it out and retap as Italian. Third choice would be to silver braze over the threads and retap, but this frame has one of those beautiful copper colored paint jobs that's in good shape. Maybe at that point it becomes a wall hanger?
I don't think I've ever seen a bike that swapped the fixed and adjustable cup sides like that. They were labelled with english threading. I have no idea how someone forced them in, unless it was done at the factory with power tools and jigs. I'm also amazed that I could retap it and still have useable threads. It seemed like a magic trick.
edit: forgot that pix or it didn't happen:
#62
Death fork? Naaaah!!
In the last extremity I have used a pipe wrench.
I do not recommend it (unless it has become personal...), but it can be done.
Top
Top
#63
Well we got it out in good reusable shape! Combination of the Sheldon Brown tool, overnight soaking in canola, and my LBS used a version of your method to clamp a regular large adjustable wrench to work in concert with the Brown tool and it cracked free. Threads on cup and shell look good, races are clean, on to the next step.
#64
Liked 6,297 Times
You need to buy them a six pack, as you probably know, I would not entrust this to any LBS mainly due to not letting something like this get away from me and many shops don't have a good handle on this sort of thing anymore and, most would not hesitate to butcher it and slap a cartridge in it and say "oh, we don't worry about it, a cartridge is better anyway." BS imo.
Glad it worked out.
#65
For stuck fix cups I got the best results with loads of lubrication (sometimes I had to used Molybdene based lubricants) and a vice. Might be a good idea to have someone help you, applying pressure to the BB shell so it will stay flat on the vice's claw. It is worth trying both directions, I was surprised to learn that a Peugeot PY10 I recently serviced had a Swiss BB and I extra-tightened the cup by trying to unscrew it.
#66
Liked 6,297 Times
I never use the vise method, have seen several nice frames damaged when the frame slips out of the vise, my clamp and cheater setup has never failed or damaged anything, it like the vice, takes practice and patience for a good result.
This is a regular topic here and many different opinions always come up with many here including myself insisting theirs is the best, easiest, fastest, etc.
At the end of the day the method that works best for you is the best method for you to use.
But when someone that has not been there asks for help it seems that many think that someone will be able to do it like they do.
And they may be able to but if not and slipping wrenches and vises are part of the problem then the result may be worse than simple failure when it ends up making the problem worse.
#67
Friendship is Magic
Bikes: old ones
Quoted: 26249 Post(s)
Liked 10,231 Times
It's not used more because people are trying t o save the paint. But even at lower heats, it often will free up a stuck cup.
Likes For 3alarmer:
#68
blahblahblah chrome moly
Quoted: 1162 Post(s)
Liked 2,542 Times
They're exactly like a Helicoil, except they're not coils, and not Helicoil brand. And the right-side one is RH threaded inside and LH threaded outside.
As Albert Einstein almost certainly did not say, "The only difference is that there is no cat."
Mark B
#69
Liked 5,768 Times
Gugie, have you seen those BB thread repair rings that are threaded Ital on the outside and Eng. on the inside? So after you get it tapped Ital, you can still use Eng/ISO cups. Ceeway carries the repair rings. (Go here and scroll down to the bottom.) I have a set, amazing to behold, probably not easy to make. The rings could be fixed with red Loctite to become effectively a permanent part of the frame, and no one need ever know what you did... Maybe ethics demands disclosure in the event of a sale later, but honestly I believe this repair would be good as new — better than new on some frames that had crâp threads to begin with.
Mark B
Mark B
I'm vaguely remembering having someone else told me about these eons ago! BITD I remember one of the LBS's I worked at that reminded me to "put a note in the BB" if I ever retapped to a larger size, so a future owner would know what was going on!
Thanks for the reminder, Ceeway tends to have odds and ends that no one else carries - but Peter's been around longer than our stateside vendors. I might have to look through his 1990's designed website and see what else I can order from him!
Have you retapped English to Italian before? Does one ream a bit to remove threads first, or can you "force feed" an Italian tap on the adjustable side, then use that to center the tap on the fixed side?
#70
Liked 2,542 Times
I have Campy taps, and also a fixed-size reamer for Ital that fits on the Campy tap holder, so the reaming is forced to be concentric (coaxial?) with the thread on the other side. Then, after one side is reamed and tapped, you can put the reamer in the other side of the frame, with the Ital tap now in the good new Ital thread. (FYI for those who don't know, Campy and other good BB taps pilot into each other to ensure the threads are on the same axis. Campy's pilot is the most precise of any taps I've used.)
I don't know who made that reamer; it came to me with my Campy toolkit, which was jam-packed with extras like taps and facer-pilots in all 3 popular (at the time) national standards. (Alas, no Swiss, though I do have a Hozan Swiss tap.) The reamer doesn't look like it's a Campy tool but it was clearly made to fit the Campy tap holder, with a very precise fit. The reaming goes fairly easily, but then the tapping is more work than you're used to if all you've done before is chase already-existing threads. You're removing substantial metal chips, even after reaming. Which is why I can't imagine tapping without reaming first.
I've also seen the "reaming" done with a boring head on a vertical milling machine. (Of course then it's not reaming, it's boring.) It's a very finicky setup on the mill though, probably too time-consuming ($$) for anything but a very expensive frame. It was a custom Ti frame that I saw it done on.
I recently tapped only one side to Ital on a French bike, and the owner asked me to stop there, leave the other side French, against my advice. That'll be a surprise to some mechanic down the road! At least they both are RH thread on the right side, so there's not much risk of turning the fixed cup the wrong way, trying to loosen it.
Mark B.
#71
Liked 1,310 Times
I have tapped English (and French) to Ital, but only by reaming first. Some damaged threads have significant metal loss or a flared/oversized shell, and then maybe you can just force the Ital tap in, but it makes me squeamish to even think about it. Seems like it'd be tough on the tap, tough on the frame.
#72
Disraeli Gears
#73
Old fart
Quoted: 3571 Post(s)
Liked 3,367 Times
It's best to ream first; forcing an Italian thread tap would be difficult. Bicycle Research used to offer a reamer/tap set for this purpose. I've used it several times with good success.
#74
Liked 5,768 Times
With respect: how does this even work? There's only about 1.25 mm difference in the thread (cup) diameter in theory, and Sutherland's says only 1 mm (34.8 vs 35.8), plus the two threads can't "nest" on the drive side because they're in opposite directions. Is this one of those ShelBroCo April Fool's products? I drew this up in CAD, using 1/24" as the thread pitch, and 60 degree (yeah, English is 55 degree or so), and when offsetting the "English" by half a mm, I get overlap between the two thread profiles:
#75
Quoted: 1601 Post(s)
Liked 2,187 Times
Great info on this thread even though we have discussed stuck fixed cups before.
I have a 72 Le Champion that was rendered inoperable by a car back in 2009. It had the same Stronglight BB. Getting the fixed cup out was an exercise of experimentation. Did most of the suggestions above.
The one that worked for me was to leave the Sheldon assembly on the fixed cup to absorb the heat and used a flame to heat the assembly up. I did not burn or brown the paint at all with the result of it coming off reasonably easily comparted the the amount of torque applied on pervious attempts. At the time I was hoping there would be an opportunity for repair. NOT!
